John75142
Posted: Sat Jan 19, 2008 4:22 pm Post subject: Question |
On the Horz. Stab. the plans call for a fairlead to go in the cutout of top skin. My question is what is this fairlead 7C5-1 and what do you make it out of.
Scratch building 701
CREATIVE SIGNWORKS
1168 Byron Rd.
Kaufman, Tx 75142
John & Mindy Short
972-962-7464
Cell: 214-240-3815
www.creative-sign-works.com
creativesigns(at)embarqmail.com (creativesigns(at)embarqmail.com)
_________________ John Short |
dougsnash(at)yahoo.com Guest
Posted: Sat Jan 19, 2008 8:59 pm Post subject: Question |
I'm using 1/8 inch nylon from Aircraft Spruce. I
can't piture exactly what the fairlead your refering
to looks like right now as the plans are in my -30 Deg
C shop. The fairlead should be a piece of the nylon
(plastic) with a hole drilled into it for the cable
and it will be riveted in place.
Hope this asnwers your question.
Doug MacDonald
CH-701 Scratch Builder
NW Ontario, Canada
Do not Archive
--- John Short <creativesigns(at)embarqmail.com> wrote:
| Quote: | On the Horz. Stab. the plans call for a fairlead to
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
DRAGONFUEL(at)aol.com Guest
Posted: Sat Jan 19, 2008 11:09 pm Post subject: Question |
a fairlead is a plastic or other smooth hard surfaced guide and bearing for control cables to slide through. Often several attached to bulkheads and other structure in the open rear fuselage to guide the cables as they control the rear (or in the wing for ailerons) control surfaces. Can be used with any cable system.
Bob Archibald
Start the year off right. Easy ways to stay in shape in the new year.
amyvega2005(at)earthlink. Guest
Posted: Sun Jan 20, 2008 8:51 am Post subject: Question |
it is 1/8 Nylon you order in 12"X12" SHEETS FROM Aircraft Spruce. part No. 03-51100
Juan
John75142
Posted: Sun Jan 20, 2008 12:46 pm Post subject: Question |
Thanks to all.
Posted: Sun Jan 20, 2008 1:48 pm Post subject: Question |
and like most commodity items that the aircaft stores sell, this one is also available from Mcmaster.com:
8539K13Nylon 6/6 Sheet 1/8" Thick, 12" X 12"In stock at $9.95 Each
Just make sure that you are standing well back from the curb as they may deliver before you get off the phone...and the shipping charge will be reasonable!
Always check them for something that can be defined specifically
Juan Vega <amyvega2005(at)earthlink.net> wrote:[quote] --> Zenith-List message posted by: Juan Vega
it is 1/8 Nylon you order in 12"X12" SHEETS FROM Aircraft Spruce. part No. Be a better friend, newshound, and [quote][b]
