sreeves(at)gw.med.sc.edu Guest
Posted: Mon Jan 14, 2008 6:36 pm Post subject: Alternator / Charging issue |
A while back my alternator decided to start cycling on and off every
now and again, mostly when under load. It will never do it during a
day flight, and only during the day when running strobes. I can
induce it at night fairly easily sometimes with the navs, fuel pump,
landing light, and panel lights (no strobes needed..they seem able to
induce the problem by themselves). I was returning from Miss. a few
nights ago and it decided to do this. I shut down the strobes and
everything was fine (as usual). I turned the strobes back on and the
last 30 min or so of the flight was uneventful.
I installed a new B&C battery yesterday and the problem occurred
again yesterday evening 1 time near the beginning of the flight, and
more so on the ground after I landed and had the engine at idle
power. I stayed in the pattern since I had a "known" electrical issue.
Here are few things I may have forgotten to mention, and I can't be
sure if this could be a cause of my problem.
2) I notice both my EI voltmeter as well as the Dynon (backup to my
gyro ) are reporting about 13.5V when in flight. I would assume
this should be around 14.5 or so. I think before this problem it
did. Funny the little things you start to notice when you actually
have a problem.
3) The main problem is that if under load, the system will "shut
down" the charging system intermittently and then come back
online. Sometimes in a rapid (5 secs or so) succession or sometimes
in more erratic unpredictable intervals. Like the flight back the
other night, it acted up then stayed online for the remainder of the
flight. I'll see the voltage annunciator come on and the voltage
drop to 11.8 or 12...then it will go back up to 13.5. It may stay
for a while...the remainder of the flight...or maybe 10 secs. It's crazy.
I thought I had the alternator tested at one time and was told it was fine.
I also just replaced my main solenoid (it was going bad..wouldn't
connect when I turned the master on). That's fine now, but that
didn't help the problem either.
This problem is driving me crazy. Any and all input would be appreciated.
I'm almost convinced I'm never going to find the root if this
thing. Thanks again.
Steve Reeves
Glasair 38SR
Dick Sipp
Posted: Mon Jan 14, 2008 9:01 pm Post subject: Alternator / Charging issue |
Steve,
I saw nearly identical symptoms on my RV4. It turned out to be a poor quality crimp on the b lead connector on the alternator.
Dick Sipp
RV10 N110DV
bakerocb
Posted: Tue Jan 15, 2008 5:11 am Post subject: Alternator / Charging issue |
1/15/2008
Hello Steve, Suggest that you check the wiring, particularly the ground
wire, on your voltage regulator.
'OC' Says: "The best investment we can make is the effort to gather and
understand knowledge."
Time: 06:36:07 PM PST US
Subject: Alternator / Charging issue
have a problem.
Steve Reeves
Glasair 38SR
nuckolls.bob(at)cox.net Guest
Posted: Tue Jan 15, 2008 8:52 am Post subject: Alternator / Charging issue |
At 09:34 PM 1/14/2008 -0500, you wrote:
A while back my alternator decided to start cycling on and off every now
and again, mostly when under load. It will never do it during a day
flight, and only during the day when running strobes. I can induce it at
night fairly easily sometimes with the navs, fuel pump, landing light, and
panel lights (no strobes needed..they seem able to induce the problem by
themselves). I was returning from Miss. a few nights ago and it decided
to do this. I shut down the strobes and everything was fine (as
usual). I turned the strobes back on and the last 30 min or so of the
I installed a new B&C battery yesterday and the problem occurred again
yesterday evening 1 time near the beginning of the flight, and more so on
the ground after I landed and had the engine at idle power. I stayed in
Here are few things I may have forgotten to mention, and I can't be sure
2) I notice both my EI voltmeter as well as the Dynon (backup to my gyro
) are reporting about 13.5V when in flight. I would assume this
should be around 14.5 or so. I think before this problem it did. Funny
the little things you start to notice when you actually have a problem.
3) The main problem is that if under load, the system will "shut down"
the charging system intermittently and then come back online. Sometimes
in a rapid (5 secs or so) succession or sometimes in more erratic
unpredictable intervals. Like the flight back the other night, it acted up
then stayed online for the remainder of the flight. I'll see the voltage
annunciator come on and the voltage drop to 11.8 or 12...then it will go
back up to 13.5. It may stay for a while...the remainder of the
was fine.
I also just replaced my main solenoid (it was going bad..wouldn't connect
when I turned the master on). That's fine now, but that didn't help the
problem either.
I've never encountered a system problem that was not
fixable.
You don't say what kind of alternator. External or internally
regulated?
wgill10(at)comcast.net Guest
Posted: Tue Jan 15, 2008 8:05 pm Post subject: Alternator / Charging issue |
Hello Steve,
The 13.5 volt output appears to be too low, possibly due to a bad diode.
The intermittent nature also could be due to excessive leakage from one
or more of the other diodes when the alternator gets hot. It might be
wise to take it to an alternator overhaul shop to be checked vs. the
local auto parts establishment. What type of alternator do you have? Any
cooling via blast tube? Please let us know what you find. Thanks.
Bill
Posted: Fri Jan 18, 2008 12:09 pm Post subject: Alternator / Charging issue |
At 10:50 AM 1/15/2008 -0600, you wrote:
<nuckolls.bob(at)cox.net>
Steve,
I'm going on vacation tomorrow morning early. Didn't see
a response as to what kind of alternator we're trying
to troubleshoot.
| Quote: | >A while back my alternator decided to start cycling on and off every now
>and panel lights (no strobes needed..they seem able to induce the problem
>by themselves). I was returning from Miss. a few nights ago and it
>decided to do this. I shut down the strobes and everything was fine (as
>up then stayed online for the remainder of the flight. I'll see the
>voltage annunciator come on and the voltage drop to 11.8 or 12...then it
>will go back up to 13.5. It may stay for a while...the remainder of the
> it was fine.
>problem either.
fixable.
regulated?
269.19.2/1224 - Release Date: 1/14/2008 5:39 PM
incoming mail is certified Virus Free.
Checked by AVG.
( -Thomas Paine 1776- )
