901 Engine Starter Engaged with Spark Plug Wire Disconnected
Ivor Phillips
PostPosted: Sun Feb 26, 2006 9:02 am    Post subject: 901 Engine Starter Engaged with Spark Plug Wire Disconnected Reply with quote
Assuming you have a key switch and not toggles, then there is a slim chance that the Ignition modules have been damaged, They are quite robust so you may be OK!
connect every thing back up and test,
Ivor Phillips
