Posted: Sat Jan 05, 2008 10:01 pm Post subject: hangar lighting |
There was some discussion last month about hangar lights so I thought
there might still be some interest in this.
One of my neighbors just bought some 400 W metal halide low-bay lights
for his business & hangar for a pretty good price & they appear to be
high quality. The only downside is this seller sells them in lots of 10
(4 is all you should need in a 50x50 hangar).
Search ebay for item 120205873311 then go to this seller's store to pick
the right light. Be sure to check the input voltage. He's got some that
are 120/240 volt & some that are 277/480 volt.
cjensen(at)dts9000.com Guest
Posted: Sun Jan 06, 2008 6:02 am Post subject: hangar lighting |
Go with the highest voltage available to the hangar. In general the cost to run them is inversely proportional to the voltage. A 240v light will cost twice as much to run as a 480v unit....and a 120v unit, putting out the same light, will break the bank. We shouldn't try wiring 220v/440v ourselves unless we really know what we're doing. 220v can burn and kill, 440v can burn, make body parts explode and then kill you. High voltage wiring is way more dangerous than flying (which ain't).
Chuck Jensen
tomasz(at)korwel.net Guest
Posted: Sun Jan 06, 2008 8:01 am Post subject: hangar lighting |
That's probably because you can't see neither air nor electricity. Keep
in mind that in Europe we have 200V in every outlet and 400V (3 phases)
is nothing unusual in bigger houses. So read some manual, do some risk
evaluation and go ahead
Tomasz
Chuck Jensen
Posted: Sun Jan 06, 2008 8:13 am Post subject: hangar lighting |
Don't you think that assessment is a little overstated? 240V will be
slightly more efficient due to less resistive loss in the wire, but for
lighting, watts is watts and that's how you get billed for electricity.
It also raises issues if you will be using existing wiring, if you worry
about safety (switching issues) and electrical codes (number of conductors).
Since 120V will kill you dead, is 240V really more dangerous? And in
order to get hit by 240V, you've got to get across both hot legs in the
circuit. It's much more likely that you'll get between one of the legs
(120V) & neutral or ground, instead of between the legs. 440V *can* burn
(if you get between both hot legs), but very few of us is likely to have
available 277V or 440V in a typical hangar. That's why I mentioned being
sure to order the right voltage.
Bottom line is that any voltage likely to be used for power in a house
or building can be dangerous & you should either know what you're doing
or get assistance.
Thoughts?
Chuck Jensen
n616tb(at)btsapps.com Guest
Posted: Sun Jan 06, 2008 8:30 am Post subject: hangar lighting |
Hi Chuck,
[quote] --
Posted: Sun Jan 06, 2008 8:34 am Post subject: hangar lighting |
Tomasz, electricity does not scare me because I can't see it. I'm only afraid of the shocking results when one does not exercise due caution.
To a degree, I should amend the statement about voltage killing--its really amps that does the job. Low voltage at high amps is still a problem. In general, when we see 480v service installation, there's usually a couple hundred amps behind it--therein lies the danger. You are correct that Europe does have higher voltages as a routine matter, but the amps are lower at the same time. In short the threat does not escalate directly proportional to the voltage increase alone. Ex. 120v 10 amps is roughly equivalent to 240v 5 amps.
Yes, 120v can kill, but its highly unusual unless you like taking a bath with while blow drying your hair! We used to have an electrician that would check light sockets by wetting his finger and sticking it in the socket...smiling all the while. No thanks. But I noticed he didn't check 220v circuits that way....
Chuck Jensen
Posted: Sun Jan 06, 2008 8:50 am Post subject: hangar lighting |
[quote] --
Posted: Sun Jan 06, 2008 9:05 am Post subject: hangar lighting |
| Quote: | Yes, 120v can kill, but its highly unusual unless you like taking a
Explaining this needs far more text that I'm able to clearly produce in
English, but two things matter:
a) your conductivity
b) path of current through your body.
If you wet your finger and use it to connect two wires the water on your
finger creates conductive layer _on_the_surface_ of your skin so neither
the path is long (1/2 inch maybe) nor the current going through your
body is big - nothing can happen to you. Different story if you touch
only hot wire and the current goes through your entire body to the ground.
I remember touching 500V in the laboratory, it was a standard routine
our professor used to demonstrate how it works. No effects. _BUT_ we had
highly isolating mats on the floor, so there was no current going
through us.
Long story short:
a) never work on live circuit
b) if you have to work on live circuit use rated tools and wear your
boots! (rubber layer on bottom isolates you from the ground)
c) never touch two wires at once
and you'll be safe.
Higher voltage has one good effect - lower amperage requires thinner,
lighter and cheaper wires and it greatly reduces risk of overheating
circuit and fire.
Tomasz
klwerner(at)comcast.net Guest
Posted: Sun Jan 06, 2008 9:17 am Post subject: hangar lighting |
Chuck,
"Used" too... ??? Did Sparky fry himself with a smile on his face?
Just wondering...
Snip....
We *USED* too have an electrician that would check light sockets by wetting his finger and sticking it in the socket...smiling all the while. No thanks.
Snip...
Posted: Sun Jan 06, 2008 10:04 am Post subject: hangar lighting |
Konrad, nope, he didn't fry himself....we just upgraded our electrician to one that could afford an circuit tester.
To the rest of the posters, I acknowledge their correctness in the grounding, circuit path through the body, et al being important determinant factors whether they'll write about you on page 7 of the local newspaper with a small picture of you 40 years ago (if you pay extra money).
Electricity is kind of like Tony S.--showing him the proper respect and you'll have not problem.
Chuck Jensen
truflite(at)yahoo.com Guest
Posted: Sun Jan 06, 2008 1:51 pm Post subject: hangar lighting |
A little electrical theory here.
E = I x R
I = E / R
R = E / I
E=voltage
I=amperage
R=resistance
P = I x E
P=watts or power consumed
If you double the voltage, you halve the amperage for
the same power consumed.
The Edison meter on your house or hangar measures P or
watts. The only gain by going to a higher voltage is
that you can use a smaller guage wire or put more
lights on a circuit. There is an efficiency factor
involved with alternating current (AC) called power
factor but with most HID lighting, 86% is the usual
number so using the above formuli works for comparison
purposes.
Dave Nellis
30 years + electrician
7A wings in mid Febb.
Chuck Jensen
Vanremog(at)aol.com Guest
Posted: Sun Jan 06, 2008 2:52 pm Post subject: hangar lighting |
In a message dated 1/6/2008 1:53:27 P.M. Pacific Standard Time, truflite(at)yahoo.com writes:
| Quote: | The only gain by going to a higher voltage is
purposes.
You've got your Ohm's law down well, but it drives me nuts when a 30 year electrician still can't spell gauge and formulae. ;o)
Sorry, nothing to do on a stormy day.
Do not archive.
N1GV (RV-6A, Flying 883hrs, O-360-A1A, C/S, Silicon Valley)
Start the year off right. Easy ways to stay in shape in the new year.
khedrick(at)frontiernet.n Guest
Posted: Sun Jan 06, 2008 5:18 pm Post subject: hangar lighting |
Dave
Thanks for the lesson. I appreciate it. I am very weak when it comes to
this stuff.
Keith
E = I x R
I = E / R
R = E / I
E=voltage
I=amperage
R=resistance
P = I x E
purposes.
Dave Nellis
Chuck Jensen
Posted: Mon Jan 07, 2008 2:37 am Post subject: hangar lighting |
Yeah, I am a good electrician and so so with grammar.
My wife says she can dress me up, just can't take me
out of the house.
Dave Nellis
--- Vanremog(at)aol.com wrote:
Standard Time,
comparison
purposes.
;o)
Do not archive.
Valley)
**************Start the year off right. Easy ways
to stay in shape.
http://body.aol.com/fitness/winter-exercise?NCID=aolcmp00300000002489
Looking for last minute shopping deals?
bmeyette(at)gmail.com Guest
Posted: Wed Jan 09, 2008 12:15 pm Post subject: hangar lighting |
And here's some useful info from his ad:
"If you need help deciding what type lights are right for your application
you can use the following basic guidelines: 1) High Bays with an aluminum or
acrylic reflector are used when your mounting height is 16 foot or above. 2)
Standard Aluminum or Acrylic lowbays are used when your mounting height is
between 10 and 16 foot. If you need a basic layout of your area use the
formula listed below (Length x width) over (Fixture spacing squared)=
Fixtures needed. An average spacing for this fixture is 15 foot. So just
multiply the length times the width of your area and put that number over
225 and you will have a close ideal of the number of fixtures you will need
for a 75 foot candle light level. This is the light level typically used in
Machine Shops and other close work areas. If you have a question please feel
free to email me or give me a call on my 800 number at 800 785 0473."
