ronlee(at)pcisys.net Guest
Posted: Wed Dec 26, 2007 2:18 pm Post subject: Synthetic brake fluid and Viton O-rings |
I plan on changing out to the higher temp synthetic transmission fluid
discussed here (Mobil 1 Synthetic ATF) and in addition will change
over to the Viton O-rings
The following website has the o-ring listed:
http://www.romeolima.com/RV3hq/Maintenance/maintenance.html
"Standard MS replacement for the caliper o-rings is MS28775-218.
The Viton O-ring upgrade is 2-218V-75 "
I can't state which brake assembly this is for other than it may be the
typical Vans brake.
What other O-rings might be needed for the master cylinders (?) is
unknown.
Ron Lee
Dennis Glaeser
Joined: 10 Jan 2006 Posts: 53 Location: Rochester Hills, Michigan
Posted: Wed Dec 26, 2007 3:17 pm Post subject: Synthetic brake fluid and Viton O-rings |
I'm using DOT 4 brake fluid - which is glycol based and therefore does not
burn. On Doug Reeve's VAF site, do a search for DOT 4 Brake Fluid. I
bought a seal kit from an RV'er named Charlie Kuss which had all the EPDM
O-rings for the brake caliper, brake cylinders, and even the Matco parking
brake if you need it. I don't know if he still has kits, but he would have
all the sizes needed.
After seeing the brake line failure fire that Ed Anderson posted recently,
I'm glad I went with the DOT 4 fluid.
Dennis Glaeser
Date: Wed Dec 26 - 2:18 PM
typical Vans brake.
unknown.
Ron Lee
klwerner(at)comcast.net Guest
Posted: Wed Dec 26, 2007 5:32 pm Post subject: Synthetic brake fluid and Viton O-rings |
Hi Dennis,
Doesn't glycol absorb moisture from the atmosphere in high humidity areas?
Wouldn't it have been easier to get the newer/higher flashpoint fluid instead of changing all these seals?
Give my greetings to the Kids..., and I guess now we won't see you here in ABQ again.
Konrad
Posted: Wed Dec 26, 2007 5:46 pm Post subject: Synthetic brake fluid and Viton O-rings |
| Quote: | After seeing the brake line failure fire that Ed Anderson posted recently,
That thread on DOT fluid just made this more confusing. It seems that
DOT Brake fluid is not good in aircraft brake systems.
Ron Lee
acepilot(at)bloomer.net Guest
Posted: Wed Dec 26, 2007 5:56 pm Post subject: Synthetic brake fluid and Viton O-rings |
I was always under the impression that 5606 hydraulic was the way to
go. I thought DOT was corrosive to aluminum??? Might be FOS (full of
sh**) on this one, but I do seem to recall 5606 was the way to go
Scott
http://corbenflyer.tripod.com/
Gotta Fly or Gonna Die
Building RV-4 (Super Slow Build Version)
Ron Lee wrote:
> recently,
Ron Lee
khorton01(at)rogers.com Guest
Posted: Wed Dec 26, 2007 6:05 pm Post subject: Synthetic brake fluid and Viton O-rings |
The viton seals apparently will withstand much higher temperatures
than the original seals, so they might be a good thing even if the
brake fluid you use didn't need them. If you ever get the brakes
really hot, and the O-ring in the caliper let go, you would lose the
brake on that side. That might lead to an accident even if the brake
fluid didn't catch on fire.
Kevin Horton
On 26-Dec-07, at 20:31 , Konrad L. Werner wrote:
[quote] Hi Dennis,
areas?
here in ABQ again.
Konrad
Dennis Glaeser
Posted: Fri Dec 28, 2007 7:49 am Post subject: Synthetic brake fluid and Viton O-rings |
Hi Konrad,
The glycol does absorb water - but that is considered good because then the
water doesn't separate out and then corrode the stuff at the low points in
the system. There was a big discussion about this a while back (I found it
by searching). Changing the seals was pretty easy. I guess I like the idea
of no flashpoint best of all
We will like having the kids closer (1.5hrs by RV!) Depending on when they
actually leave, and when I get mine flying, I may get a chance to make a
trip out west. We'll see.
Dennis
Hi Dennis,
areas?
in ABQ again.
Konrad
Posted: Fri Dec 28, 2007 8:30 am Post subject: Synthetic brake fluid and Viton O-rings |
Dennis,
Wouldn't it be better if any brake fluid does not attract (and absorb) any potential water in the first place?
Wouldn't the commercial and military guys adopt automotive Dot-X, if it were the better way to go? Just curious...
One cause in regards to brake fires could be the rather tight wheel pants which restrict the dissipation of heat from the brake rotors.
I think the newer brakefluid with it's higher boiling point is sufficient (as designed), if one does not "ride" the brakes all the time...
Other then that, I don't know much about the other intricacies between car and airplane brake systems and their potential pro's and con's?
Cheers,
Konrad
matronics(at)cencula.com Guest
Posted: Sun Dec 30, 2007 10:30 pm Post subject: Synthetic brake fluid and Viton O-rings |
For a *very* thorough writeup of DOT brake fluid and it's corrosive
properties, please reference a NIST document:
http://www.brakestrips.net/docs/nistir6233_absrpt.pdf
The short answer seems to be that plain DOT fluid exceeds the corrosion
resistance spec for aluminum by a factor of 10.
Additionally, all automotive ABS modules that I'm aware of are made from
aluminum which would further indicate that there's no problem with DOT
brake fluid and aluminum compatibility.
Mike Cencula
RV-7A fuse
Scott wrote:
rv9jim(at)juno.com Guest
Posted: Tue Jan 01, 2008 1:32 pm Post subject: Synthetic brake fluid and Viton O-rings |
Hi Ron,
You only need to replace the O-Rings in the calipers as that is
where the heat is generated. The rings on the inside of the aircraft are
fine as they stand.
Jim Nelson
Changing fluid and O-Rings
Posted: Tue Jan 01, 2008 5:00 pm Post subject: Synthetic brake fluid and Viton O-rings |
Thanks Jim, I was thinking that was the case. I have one set of O-rings
for the Cleveland master cylinders so I need to get another set for the
passenger brakes. That and the Viton O-rings plus some Mobil 1
synthetic ATF fluid and I can redo my brake system later this month.
Ron Lee
| Quote: | Hi Ron,
fine as they stand.
| Quote: | Jim Nelson
jimmy(at)jhill.biz Guest
Posted: Mon Jan 07, 2008 1:06 pm Post subject: Synthetic brake fluid and Viton O-rings |
So I don't have to remove wheel pants to get brake ser. no., could someone
tell me the correct part number and supply source for the Viton 75 O-rings?
Can then have them on hand and ready. (RV8A)
Thanks.
Jimmy
Posted: Mon Jan 07, 2008 5:55 pm Post subject: Synthetic brake fluid and Viton O-rings |
randy(at)romeolima.com Guest
