Mark Colbeck
Joined: 04 Nov 2007 Posts: 29 Location: Cochrane, Alberta, Canada
Posted: Fri Jan 04, 2008 11:40 am Post subject: Throttle Controls CH701 |
Hey guys maybe someone can point me in the right direction? I have purchased a throttle cable from Aircraft Spruce (3 foot Friction lock) for my 701 Pilot side. I will use the standard T-Handle for the passenger side. My issue is that the cable all be it nice, is to long. I cannot seem to locate a shorter length than 3 feet. I do want a friction lock and one that looks half decent, even if I can put a custom handle on it. Any suggestions. Brian Unruh I like what you have done and the set up. Is that a custom length for the cable?
Mark
_________________ CH701
70% Complete
www.mykitlog.com/mcolbeck |
nyterminat(at)aol.com Guest
Posted: Fri Jan 04, 2008 11:51 am Post subject: Throttle Controls CH701 |
Mark, Pull the center cable out and then cut the outer casing to the lenght that you need. Clean upn the edges of the cut and reinstall the center cable.
Bob Spudis
N701ZX/ CH701/140hrs
| Quote: | | Quote: | Hey guys maybe someone can point me in the right direction? I have purchased a
Mark |
Mark Colbeck
Posted: Fri Jan 04, 2008 11:58 am Post subject: Re: Throttle Controls CH701 |
Thanks Bob I will look at it tonight. I figured there had to be an easy way but I was concerned with pulling on the outer casing or pinching the cable.
70% Complete
rpf(at)wi.rr.com Guest
Posted: Fri Jan 04, 2008 12:15 pm Post subject: Throttle Controls CH701 |
I have a friction lock throttle that came with my FWF kit, from Jabiru, for
my 601xl. It was a about five feet in length but I was able to pull out the
solid inner cable and cut off (with a cut off wheel) the flexible housing to
the length I needed. Then cut the solid inner cable accordingly.
Randy
dougsnash(at)yahoo.com Guest
Posted: Fri Jan 04, 2008 12:30 pm Post subject: Throttle Controls CH701 |
Mark, I'm at a similar point to you. I also purchased
a 3' universal friction throttle from Aircraft Spruce.
The length of this cable can be easily shortened by
pulling the center core our and carefully cutting the
outer sleaving to length. Then insert the core back
in and cut it to length.
The attach the cable to the throttle bellcrank, I am
going to use B-Nuts (also from Spruce). I cut the arm
of the belcrank just bellow where the original T
throttle arm was supposed to go through. I then
knotched it and welded a 1/8" (I think) tab in such a
way that the arm length remained the same length but
now provided me with a flat tab as opposed to a round
tube. The B-Nut goes through the tab and allows
attachment of the solid wire from the cable.
For the right side throttle, I am going to use a
similar set up but rather than a friction cable, I
picked up a T-handle cable that I think was about 8'
long. Same idea, cut to length.
I have not yet worked out how the cable is going to
pass through my firewall as I'm pretty sure the
Canadian inspectors will not accept the as designed
slot method.
Hope my description is of some help. Sorry, I don't
have any pics handy or any accurate part numbers as I
am at work right now.
Doug MacDonald
CH-701 Scratch Builder
NW Ontario, Canada
--- Mark Colbeck <mark(at)masterpieceliving.ca> wrote:
Mark
CH701
60% Complete
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
walt.cannon(at)boeing.com Guest
Posted: Sat Jan 05, 2008 1:11 pm Post subject: Throttle Controls CH701 |
I took a slightly different approach on the throttle cable length issue.
Instead of cutting & shortening, I just routed it in a nice gentle 360
degree circle under the panel before it exited the firewall. That way I
was left with the threaded factory end and rubber seal boot.........WC
