cabin heater muff style
Don G
PostPosted: Thu Jan 03, 2008 4:18 pm    Post subject: cabin heater muff style Reply with quote
OK Gents...Just finished up a heater muff for my 912 speedster. I thought if anyone was going to undertake such a project, I might post these pics .
Total weight as shown on the scales was 2 lbs. And the Heater valve I fabricated of steel was 12 oz my itself...the single heaviest component.
All hardware is included on the scales except the scat hose clamps..which I didnt have the right sizes on hand, and the cable to operate the valve. Worked out pretty good...I just hope it heats!
 Filesize:  61.7 KB
 Viewed:  814 Time(s)
 Filesize:  61.29 KB
 Viewed:  901 Time(s)
 Filesize:  44.32 KB
 Viewed:  848 Time(s)
 Filesize:  196.81 KB
 Viewed:  980 Time(s)
 Filesize:  67.21 KB
 Viewed:  838 Time(s)
Don G.
Central Illinois
Kitfox IV Speedster
Luscombe 8A
RV9A
andynfultz(at)bellsouth.n
PostPosted: Thu Jan 03, 2008 10:01 pm    Post subject: cabin heater muff style Reply with quote
Don,
That is a really neat intallation. Please do let us know how it works.
Andy F.
shinco(at)bright.net
PostPosted: Fri Jan 04, 2008 2:07 am    Post subject: cabin heater muff style Reply with quote
Andy:what did U use at the fire wall.4 the heater control box??this
looks like a neat set clean set up.good deal.I would like to may B build
one for my FF2 with the 582 engine I think it all so would work 4
me..Thanks Steve Shinabery N554KF KF2 little 582
Andy Fultz wrote:
Don,
Andy F.
Lynn Matteson
PostPosted: Fri Jan 04, 2008 6:12 am    Post subject: cabin heater muff style Reply with quote
Looks like a good set-up, Don. However, I'm concerned about the
exhaust pipe wrapping. In "Tony Bingelis' on Engines", he states: "I
don't recommend wrapping exhaust pipes with one of those automotive
"Exhaust Insulating Wrap" kits regardless of the claims made for
them." He goes on to cite one example of failure. I've thought about
this practice, and haven't come to any conclusion myself, but if Tony
disapproves of it, that's a pretty good sign.
Anybody else have any proof of this being a bad idea?
Lynn Matteson
Grass Lake, Michigan
flying w/450+ hrs
post these pics .
component.
Don G.
Central Illinois
Kitfox IV Speedster
Luscombe 8A
http://www.geocities.com/dagger369th/my_firefly.htm
http://forums.matronics.com/viewtopic.php?p=155823#155823
http://forums.matronics.com//files/scoopfront_955.jpg
http://forums.matronics.com//files/oncan_139.jpg
http://forums.matronics.com//files/valve_146.jpg
http://forums.matronics.com//files/heaterdone_119.jpg
http://forums.matronics.com//files/weight2lbs_476.jpg
Lynn
Kitfox IV-Jabiru 2200
N369LM
Fox5flyer
PostPosted: Fri Jan 04, 2008 6:39 am    Post subject: cabin heater muff style Reply with quote
I read something about this Lynn that stated the exhaust pipes, especially
those closest to the cylinders, need cooling. By wrapping them they keep
the heat inside, which is good for the engine compartment, but the metal
gets too hot which changes the metallurgy properties and reduces it's useful
life. This isn't my opinion, just repeating what I read and I don't know if
it is true or not. FWIW.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 355+ TT
"Nothing will ever be attempted, if all possible objections must first be
overcome".- Samuel Johnson
Tom Jones
PostPosted: Fri Jan 04, 2008 6:45 am    Post subject: Re: cabin heater muff style Reply with quote
I'm glad to see some more heater ideas. My first attempt at building one was a bust...no heat. My modification made a tiny bit of heat. I have the third generation installed but too snowy to fly and test now. keep us updated on the performance Don!
Tom Jones
Classic IV
Ellensburg, WA
Don G
PostPosted: Fri Jan 04, 2008 9:33 am    Post subject: Re: cabin heater muff style Reply with quote
Thx Gents...Well, before starting on this project I did a search of the archives from this list and alot of the dope I read influenced the design.
I have not installed them, but I have a sack of pot scrubbers on the bench!
The Valve on the firewall is a simply flapper type air diverter valve that opens and shut via a cable on the panel. it diverts the hopefully warm air either into the cabin or out thru the round outlet pointed down to exit thru the bottom of the cowl. I fabricated this myself from mild steel sheet and brazed it together. It is kind of a copy of other aircraft diverter valves I have seen in the past.
Lynn, In regards to the exhaust wrap. I have Tonys Book, and I am aware of his statement on pipe wraps. However, I also know if this products usage in many certificated applications and how effective it can be to reduce under cowl temps. My decision to use it on my craft was based on the close proximity of the coolant hoses to the exhaust pipes. The craft operated for about 100 hours without the wrap on the pipes, and the damage to the heater hoses was begining to show up. Also damage to the firewall blanket where the rear exhaust pipes come very close. I considered the really good airflow under the cowl that a round cowled KitFox has, and determined that was was needed was something to more or less "sheild" the hoses and blanket from the pipe, not necessarly to reduce the under cowl temps. Hence, I opted for the wrap. Since installing it..about 80 hours ago..I have kept a close eye on those hoses, and am very happy with the result. Only time will tell if there is any detrimental effects on the pipes due to holding in too much heat, and if it happens, I figure that a cracked pipe is a better failure than a busted coolent hose.
I will keep you posted on the long term effects.
Don G.
Central Illinois
Kitfox IV Speedster
Luscombe 8A
RV9A
Lynn Matteson
PostPosted: Fri Jan 04, 2008 4:14 pm    Post subject: cabin heater muff style Reply with quote
Well, Don, if the wrapping proves to be a problem, you can also do
away with it, and just install a standoff shield on the coolant hoses
or other affected items. Of course the simplest and most direct
method is the wrap of the exhaust pipe, as you did.
When I worked for the Chrysler Proving Grounds Wind Tunnel, we would
often install thermocouples on a particular part like the catalytic
convertor. We would then put another t'couple on the CC shield,
another on the floor pan, the carpet, etc. All of the thermocouples
were "stacked" that is, all in line with each other vertically. It
was surprising how the temperature dropped behind the shield, on the
floor pan, etc.
Now would not be a good time to mention the Jabiru doesn't have
cooling hoses, eh? I didn't think so. : ) Besides, the Jab's got
their own problems: )
Lynn Matteson
flying w/450+ hrs
the design.
the bench!
there is any detri!
Don G.
Lynn
N369LM
Lynn Matteson
PostPosted: Fri Jan 04, 2008 4:15 pm    Post subject: cabin heater muff style Reply with quote
To quote Tony Bingelis a little more regarding the failure of a
wrapped exhaust system: "A local Mustang II equipped with a mild
steel exhaust system suffered complete failure of the pipes in all of
the bend areas. His thermal wrapped pipes had completely burned
through." Reference is "Tony Bingelis on Engines," pages179-182.
Just to throw in an observation of my own, I've never seen a race car
with the pipes wrapped. I've seen the ads for the wrapping, but never
seen it in use. And you'd think if any group of engine enthusiasts
would be going for that last horse, it'd be race cars. And while I'm
pretty new at this aviation thing, I haven't seen the certified
planes with wrapping on their exhausts, either....those that I've
seen anyway.
Maybe a better method of retaining heat (to raise the efficiency of
the cabin heat muff) would be ceramic coating? While Tony does not
mention ceramic coating, he does list Jet Hot Coatings in his sources.
The other thing about the wrapping is that water/ice/snow can be
trapped under the wrapping, further causing problems...I know, how
long is ice going to last at 1400°? Not long, I'm thinking: )
On Jan 4, 2008, at 9:37 AM, fox5flyer wrote:
<fox5flyer(at)idealwifi.net>
especially those closest to the cylinders, need cooling. By
wrapping them they keep the heat inside, which is good for the
engine compartment, but the metal gets too hot which changes the
metallurgy properties and reduces it's useful life. This isn't my
opinion, just repeating what I read and I don't know if it is true
or not. FWIW.
Deke Morisse
Mikado Michigan
first be overcome".- Samuel Johnson
Lynn
N369LM
kitfoxmike
PostPosted: Fri Jan 04, 2008 5:03 pm    Post subject: Re: cabin heater muff style Reply with quote
Something you might want to think about is to have the air passing through the heat muff all the time, in other words let the air dump when you turn off the heat. I don't know if your valve does that or not. That way the heat around the muffler doesn't get to hot and burn out the muffler.
Don G
PostPosted: Fri Jan 04, 2008 7:21 pm    Post subject: Re: cabin heater muff style Reply with quote
Roger that Mike... the valve has 2 outlets..when it is closed to the cabin, it is diverted thru the outlet pointed down. I didn't stick a short hose on it yet. Don't think it will be needed but I made it so I could just in case. It would need to be about 6 inchs long and go straight down to the under-cowl opening. I believe this will also help keep some heat away from the lower motor mount rubbers, which as you know are real close to the muffler can. I am sure your 912 speedster is just like it. my motor mount rubbers show a little heat brittle on the edges closest to the can now. This heat muff oughtta help that some.
And Lynn, yes, I understand and agree, in fact, in addition to the wrap on the rear pipes that come so close to the firewall blanket, I installed small alum sheilds against the firewall over the blanket because with the wrap on, it just about touchs the blanket right on the bend. The heat had already cooked 2 black spots on the blanket in that 1st 70 hours.
And when I read Tonys book, I also considered that the EGT temps could get a bunch higher on the Mustang which probably had a 320 or a 360 in it, than on a 912, particularly when you have mixture control in the cockpit. Plus, he specified they were mild steel headers, not stainless like mine. These considerations gave me a little more confidence it the application.
As for the wraps on certified birds, they are pretty popular in alot of areas, especially the further south you get. I also believe they are required on a Aztec, and come standard on some models of Bonanza's.
When I was in College, at Spartan in Tulsa, we had wraps on most all of the 150's on the flight line. Of Course back in the heyday of Aviation..the early 70s, Those birds didnt cool off all day long, every day, as their flight training program was very very busy.
Don G.
Central Illinois
Kitfox IV Speedster
Luscombe 8A
RV9A
Lynn Matteson
PostPosted: Sat Jan 05, 2008 7:07 am    Post subject: cabin heater muff style Reply with quote
Gotcha, Don...sounds like you've done your homework. Smile
Now about that firewall blanket. I talked with Skystar about the
placement...major portion on the engine side or major portion on the
cabin side, and they told me that most builders were putting the
major portion on the inside, because of concerns about getting oil
soaking. I actually ripped the stitches off the 1/2 side and tossed
it, using the full blanket on the cabin side.
How are others dealing with the blanket, if at all?
Lynn Matteson
flying w/450+ hrs
Bonanza's.
Don G.
Central Illinois
Kitfox IV Speedster
Luscombe 8A
Lynn
N369LM
john(at)leptron.com
PostPosted: Sat Jan 05, 2008 7:54 am    Post subject: cabin heater muff style Reply with quote
Lynn,
I did what you have explained. I have no blanket on the engine side and the
side in the cockpit still looks good after 10 years.
John oakley
Don G
PostPosted: Sat Jan 05, 2008 8:22 am    Post subject: Re: cabin heater muff style Reply with quote
Lynn,
REALLY?....this sounds very interesting...and more logical in fact.
Explain to me what you mean about the 1/2 side?
And major portion?...I am confused with these terms.
I am also sure I would like the whole dang think inside the cabin.
I think this is the first aircraft I have seen with a blanket on the firewall on the engine side. I thought it looked outta place!
Don G.
Central Illinois
Kitfox IV Speedster
Luscombe 8A
RV9A
Guy Buchanan
PostPosted: Sat Jan 05, 2008 10:06 am    Post subject: cabin heater muff style Reply with quote
Mine has no noise attenuation, just the stainless bulkhead,
and I don't mind at all. I do have good noise cancelling headphones,
though. My firewall's constantly a mess from leaky injection banjos
and weeping seals so I'm very glad I don't have anything permeable on
the outside of it.
Guy Buchanan
San Diego, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
Lynn Matteson
PostPosted: Sat Jan 05, 2008 10:17 am    Post subject: cabin heater muff style Reply with quote
Does your blanket extend below the ...never mind, I just looked at
you pictures and see that it does extend all the way down to the
bottom of the firewall inside the engine compartment. It sounds like
you got your plane with the blanket already installed if not entirely
finished. Is there any of the firewall blanket showing inside the
cabin, that is, on the back side of the firewall? If it does, that is
what I'm calling the 1/2 side, as it is only half as long as the side
that has the rudder pedal bumps.
I'm not sure what the proper terms are, but just for the sake of
discussion, let's call the side that contains the bumps (my term) for
the rudder pedals, the full side, or the long side. The other side is
the short side (what I called the 1/2 side), and only comes halfway
down the firewall. These two sides are sewn together, forming a
pocket that slides down over the firewall. It can be installed with
either the short side, or the long side facing the engine. I was
nervous about having either side facing the engine where it is
subject to heat, oil or gas contamination, or whatever. When I called
the old Skystar Co., they told me that some builders would cut the
short side off, and install the blanket entirely within the cabin,
that is, on the back side of the firewall. You just have to push the
rudder bumps inside-out, so to speak, and it fits perfectly. When I
did my plane, I cut holes where the engine mount contacts the
firewall and thence the airframe. I didn't want to have anything,
much less fabric, between the engine mount and the airframe, except
the firewall. If the blanket is between these items, eventually the
fabric will compress, and leave you with loose engine mounting bolts.
Hope I've explained it ok.
Lynn Matteson
flying w/450+ hrs
On Jan 5, 2008, at 11:22 AM, Don G wrote:
Lynn,
Don G.
Central Illinois
Kitfox IV Speedster
Luscombe 8A
http://forums.matronics.com/viewtopic.php?p=156145#156145
Lynn
N369LM
