dvanlanen
Posted: Sat Jan 05, 2008 10:53 am Post subject: Access Hole Covers |
Here is a dumb question for the list. I am priming my faying surfaces with zinc chromate. I am planning to have my airplane professionally painted when complete. Do I need to prime the faying surfaces between the removable access hole covers and the skin around the access holes, or do the professional paint shops remove the access covers before painting?
Dave Van Lanen
601XL - Elevator [quote][b]
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Sat Jan 05, 2008 12:24 pm Post subject: Re: Access Hole Covers |
Depends on the paint shop and the wishes of the owner of the aircraft. I would suggest removing the covers and having them painted separately. That way the whole surface of the cover will be painted as well as the area on the skin under the screw heads. You will also avoid the issue of having to break the paint around the cover/skin and screw head/skin interfaces. I prefer stainless steel machine screws rather than painted heads because in use the paint on the heads will chip.
I did spray primer around the inside of the inspection holes cut in the skin.
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
Posted: Sat Jan 05, 2008 12:34 pm Post subject: Access Hole Covers |
It's a good question Dave,
It's likely they'd be removed if you've got a good paint shop. I masked
behind the inspection hole surfaces and painted wings and covers
separately. I think this is
the only way a good paint job can be done. Masking behind inspection
holes begins by taping behind the edges, then taping the tape to close
without touching any metal.
It's awkward but doable,
see link for painting solutions at www.macsmachine.com/html/Paint.htm
Dave VanLanen wrote:
painting?
Dave Van Lanen
601XL - Elevator
