		| Author | Message |
		| wild.blue(at)verizon.net Guest
				|  Posted: Sat Feb 25, 2006 12:32 pm    Post subject: hard starting |   |
				| Hey Val--
 When I was a kid, a lucky friend had an Austin Healey.  Fun!  One day he
 came by and said it had developed a misfire--what could be The Problem?
 Being highly experienced know-it-alls who read all the magazines, after
 driving it really fast and blipping the throttle about 10,000 times, we
 concluded it needed an engine overhaul.  So, we tore the engine down,
 replaced rings, bearings, points, condenser, rotor, cap, seals (and the
 clutch, too, I seem to recall), ground the valves, rebuilt the carburetors
 etc.  Everything we could think of.  New battery and muffler (no doubt a
 $500 Italian after-market go-fast variety), too, I think.  Started her up
 and guess what--it still had the misfire!  Crikey!  Took it down to the
 local gas station where they put it on the scope and immediately found a bad
 spark plug--impossible!  It was equipped with brand new $500 per Golden
 Lodge spark plugs my friend had installed just before the misfire
 developed--that couldn't possibly be The Problem!  Five minutes and two
 bucks later it ran great--just like it did before he installed the $500
 Golden Lodge plugs.
 Don't recall, but in retrospect I suspect my friend (not me--no way!)
 dropped the offending plug during installation.
 OTOH, one of the primary problems we've seen with hard starting/misfiring
 -52's and CJ's isn't the plugs--it's that they're mostly still equipped with
 their original issue and now shot ignition harnesses.  Both the Russian and
 Chinese wires have comparatively short service lives because of the
 materials they use(d). Over There They have calendar service life limits on
 most consumables, but We just rely on Condition and ignore the TIS limits.
 So, while we ignore--and exceed--the TIS limits, oil, water, fuel etc
 collect in the ring, cause the wires to deteriorate (as in turn to goo) and
 finally, fail.
 If you're experiencing hard starting or misfires, one of the first things to
 do is check the wires.  If they're bad (very likely if OEM) replace them
 with high quality 5mm US wire.  Not surprised at all that your conversion
 kit makes a big improvement, Dennis.
 There is no question that auto plugs (and wire) are way cheaper than the
 aviation variety.  OTOH aviation plugs and wires don't look like auto stuff
 and cost more for some very good reasons.  Aviation plugs last a very long
 time and are a relatively minor cost item.  But if you drop a plug it is
 ruined (cracked or broken porcelain), regardless of brand.  Don't work so
 well in Austin Healeys or airplanes.  A harness that has turned to goo isn't
 much good, either.
 Do some diagnostics before you overhaul.  I'll give you my buddy's phone
 number if you need advice--I might even still have some magazines laying
 around.  A nomex flight suit and helmet might help, too.  Just kidding.
 Jerry Painter
 Wild Blue Aviation
 425-876-0865
 http://mysite.verizon.net/res0cs5r/index.html
 | |  |  | - The Matronics Yak-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Yak-List
		| Back to top |  |
		| Valkyre1(at)comcast.net Guest
				|  Posted: Sun Feb 26, 2006 7:15 am    Post subject: hard starting |   |
				| Thanks Jerry-
 You've given me some more things to think about on  the spark plug kit installation, an entertaining story, and a good laugh. A  great way to start the day. ( I suspect your "friend" is a bit more careful  these days too.)
 -Val
		| Back to top |  |
