fstringham
Posted: Thu Jan 03, 2008 3:06 pm Post subject: AeroElectric-List:Engine GND |
Ok so here is the set up...RV7A....SD-8 on the Vac pad....FWF Ground block just right of upper center on the firewall.
I have a clear run for the engine GND from the port side upper bolt on the SD-8 to the FWF ground block. Is this acceptable and will it produce a good engine GND.
Fran (at) SGU....RV7A.....finishing up the last zillion items before RV grin Time
frank.hinde(at)hp.com Guest
fstringham
Posted: Fri Jan 04, 2008 6:42 am Post subject: AeroElectric-List:Engine GND |
Frank1
Hey whats up or is that down...good grief with your acro ability I never know what your attitude might be. Thanks for the response....now off to the garage to getter dun......................or is that accomplish the task!!!!
Frank2
[quote] From: frank.hinde(at)hp.com
Date: Thu, 3 Jan 2008 23:39:58 +0000
Subject: RE: AeroElectric-List:Engine GND
.ExternalClass .EC_hmmessage P {padding-right:0px;padding-left:0px;padding-bottom:0px;padding-top:0px;} .ExternalClass EC_BODY.hmmessage {font-size:10pt;font-family:Tahoma;} Hey thats what I did and I made it from Corvallis to St George and back....
Yup that will work just fine. Use #2 welding cable for the ultimate in flexibility.
Frank1
RV7a 245 hours
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Frank Stringham
Sent: Thursday, January 03, 2008 3:02 PM
Ok so here is the set up...RV7A.....SD-8 on the Vac pad....FWF Ground block just right of upper center on the firewall.
ist">http://www.matronics.com/Navigator?AeroElectric-List
ics.com
.matronics.com/contribution
ist" target=_blank>http://www.matronics.com/Navigator?AeroElectric-List
p://forums.matronics.com
blank>http://www.matronics.com/contribution
| [b]
