nuckolls.bob(at)cox.net Guest
Posted: Sat Jan 05, 2008 12:40 pm Post subject: Small battery limited to 3 amp charge rate ? |
At 02:15 PM 1/5/2008 -0600, you wrote:
| Quote: | Wondering how this works ? Help appreciated!
I have a 7ah battery on a separate bus for EFIS(alternate power) that is
not directly connected to the main bus during starting or normal
operations. However, I do have a charging circuit off the main bus
through a D25 diode which should put 14.4 - .6 or 13.8 volts to the small
battery during normal operations to keep it charged. It is a fused
circuit and intended to be hot anytime the main bus is on. That way the
Aux Bat should be always charged, available to run the EFIS before and
during starting with no draw on it, and not drain back if the main bus is
off. And no switching required during normal ops.
The Z35 Light Aux Bat
figure
<http://www.aeroelectric.com/PPS/DCPwr/Z35K_Light_Aux_Battery.pdf>http://www.aeroelectric.com/PPS/DCPwr/Z35K_Light_Aux_Battery.pdf
is similar except that I think it is intended to be turned on after
starting and not be available from before to after starting.
My question: It was just pointed out to me that the 7ah battery has a 3
amp charging limit (per B&C spec sheet) and I am wondering if there should
be a resistor in this circuit to limit the charging current? I see that
the full size batteries do not have a charging limit. Is there any
danger if the smaller 7ah is fully discharged that it could draw enough
charging current to damage it without a limiting resistor.
If it does require a resistor for the small battery, wouldn't the same
thing apply to the Z35 figure since you could easily have a fully
discharged aux bat, start the airplane, and then hit the switch putting
full current to the fully discharged battery?
The only time the recharge limit might be exceeded
is if the battery is connected to and alternator-supported
bus after being completely discharged. This should be a
rare event and you should be aware of it before it happens.
I.e., you were forced to use the aux battery sans alternator
until the battery was at or nearly depleted.
This scenario generates a maintenance event that includes
repairing the failed alternator and might as well include
putting a smart charger on the aux battery to GENTLY return
it to it's 100% state of charge.
On the rare occasion that you find it useful/necessary
to recharge the aux battery using ship's alternator, then
yes . . . the battery will see an out-of-spec recharge
rate for a short period of time. But we wouldn't expect
to see it happen often.
If you use this battery in a repeated charge/discharge mode
of operation . . . like to be the sole source of energy
for running a radio in a sailplane, then it's prudent and
even practical to acquire a recharging system that pampers
the battery for the purpose of extending service life.
However, in the case we're considering, the aux battery
may be replaced in an few years never having been deeply
discharged over the lifetime of its service. It's my
considered judgement that adding the extra gee-whiz
components for pampered recharge only adds to parts
count and pilot/maintenance workload and would contribute
no measurable increase in service life of the battery.
Bill Schlatterer
Posted: Sat Jan 05, 2008 3:02 pm Post subject: Small battery limited to 3 amp charge rate ? |
Thanks Bob, with no chance of sparks and a rare shot at battery damage ($35)
it would seem the answer is to simplify as usual.
Thanks Bill S
bobf(at)feldtman.com Guest
Posted: Sat Jan 05, 2008 3:03 pm Post subject: Small battery limited to 3 amp charge rate ? |
I'm getting sorta tired of replacing my Concorde attery in the Glastar every 14 months or so cause they just won't hold a charge. I need something more reliable than that. -- I know I know - avoiding long times in between useage, cold weather, deep discharge (like starting) short flights - all that stuff. Without getting into too much of a commerical war - does folks have preferences for Concorde vs gill (now Teledyne Continental) etc?
And yes I am using an off the shelf Auto zone recharger - maybe that is the problem although it has the setting for different types and automatic shutoff etc.
bobf
On 1/5/08, Robert L. Nuckolls, III <nuckolls.bob(at)cox.net (nuckolls.bob(at)cox.net)> wrote:[quote] --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net (nuckolls.bob(at)cox.net)>
| Quote: | amp charging limit (per B&C spec sheet) and I am wondering if there should
no measurable increase in service life of the battery. [quote][b]
cjensen(at)dts9000.com Guest
Posted: Sat Jan 05, 2008 4:07 pm Post subject: Small battery limited to 3 amp charge rate ? |
Bob,
Get a 680 or 925 Odyssey and be done with your worries. If its not a 6 cylinder, then the 680 should be ample for your needs. Highly and uniformly recommended.
Chuck Jensen
[quote] --
schaefer(at)rts-services. Guest
Posted: Sat Jan 05, 2008 6:19 pm Post subject: Small battery limited to 3 amp charge rate ? |
What Bob is also hinting at is that a "RESISTOR" current limiter does not
allow for proper care and feeding of a battery. The smart battery tenders
that allows proper recovery from a battery in any arbitrary discharge state
is fairly complex and is managed by very smart devices. (Current limited
profiles initially followed by low float current and constant voltage).
If you never let the battery get significantly discharged you do not need to
worry about this complexity. If the fuse popped, check the condition of your
battery, and recover or replace it.
Posted: Sun Jan 06, 2008 6:12 am Post subject: Small battery limited to 3 amp charge rate ? |
Bob F.
I amend my earlier posting and concur with Bob N.(I'll bet he feels relieved). It looks like a system problem more than a battery problem. Nonetheless, the Odyssey is a heck'va battery.
Chuck Jensen
Posted: Sun Jan 06, 2008 8:40 am Post subject: Small battery limited to 3 amp charge rate ? |
Appreciate the valuable information - indeed the Odyssey looks super! I do have a Fluke, which I trust - so will make the various measurements. Flad I asked the question so the entire list can learn about this ever so common problem with airplanes - battery problems! Main problem is I don't fly enough!
bobf
On 1/6/08, Chuck Jensen <cjensen(at)dts9000.com (cjensen(at)dts9000.com)> wrote:[quote] Bob F.
Chuck Jensen
