rstone4(at)hot.rr.com Guest
Posted: Sat Dec 29, 2007 1:45 pm Post subject: Sump drain valve |
Members,
Does anyone know what the size is for the little O ring seal on the fuel sump drain valves on the ZodiacXL?
Bob Stone
Harker Heights, Tx
ZodiacXL w/Jabiru 3300
gfmjr_20(at)HOTMAIL.COM Guest
Posted: Sat Dec 29, 2007 2:38 pm Post subject: Sump drain valve |
Bob--
If they are the SAF-AIR drain valves I used the o rings MS29513-006 from Aircraft Spruce
George May
601XL 912s
| Quote: | From: rstone4(at)hot.rr.com
Subject: Zenith-List: Sump drain valve
Date: Sat, 29 Dec 2007 15:44:23 -0600
Members,
Bob Stone
Harker Heights, Tx
blank>http://www.matronics.com/contribution
arget=_blank>http://www.matronics.com/Navigator?Zenith-List
p://forums.matronics.com
| Share life as it happens with the new Windows Live. Share now! [quote][b]
bryanmmartin
Posted: Sat Dec 29, 2007 4:48 pm Post subject: Sump drain valve |
I just took one down to the auto parts store and went through their
O-ring bin and found a perfect fit. I don't recall the part number but
it seem to be a standard size.
robert stone wrote:
| Quote: | Members,
Bob Stone
Harker Heights, Tx
Bryan Martin
Zenith 601XL N61BM
Ram Subaru, Stratus redrive
_________________ --
Bryan Martin
do not archive. |
japhillipsga(at)aol.com Guest
Posted: Mon Dec 31, 2007 8:37 am Post subject: Sump drain valve |
Bob, I had a drip problem with both of mine. Could not find out the exact size. Called Spruce, talked to Tim, asked him for several various sizes. He sent a bunch and I Trial & Error until I found new ones that fit. A whole little bag of O rings of different size was only a couple bucks. ACS will work with you. Hope you had a fine Christmas and best regards, Bill
