Engine Vibration
Goto page 1, 2  Next
Gtblu
PostPosted: Sun Dec 30, 2007 4:52 pm    Post subject: Engine Vibration Reply with quote
Hello Listers and Happy New Year.
Many users of Rotax 912 uls Engines talk of vibration between abut 4400 and 5000 revs which you get used to after a while. However the top end of that vibration is now creeping up to 5300 revs. Its incredible consistant even to the point of the vibration stopping if extra load is put on like a turn or up elevator. It feels to me similar to bearing float of the crankshaft in a vehicle, but is more obvious in the air especially those magical early mornings with no turbulance.
This engine has been recently split and a new sprag clutch put in (100 hours ago) but bearings were checked and not replaced. The engne has done 729 hours in a Slepcev Storch and runs very sweetly above this moving revs line, currently about 5300 rpm.
It has always run with a little noticable vibration on bothe left and right when doing a mag check. ( Left and right is not entirely accurate as the plugs that operate on each switch are shared top and bottom left and right.
I will check plugs, carby sync, carby's generally, air filters, prop alignment but before I started I thought I'd put this out there for others experience on engine vibration. Its not violent, but its very noticable on a still day especially increasing revs from rough to smooth and as it is changing in nature I need to asses it a little more meticulously.
Any thoughts?
all the best for 2008
regards
Geoff Bell
thilo.kind(at)gmx.net
PostPosted: Sun Dec 30, 2007 6:02 pm    Post subject: Engine Vibration Reply with quote
Hi Geoff,
sounds to me like a prop issue - you should check angle on the blades. Been there myself...
Good luck
Thilo
-------- Original-Nachricht --------
Datum: Sun, 30 Dec 2007 16:52:05 -0800
Von: "Gtblu" <gtbjbell(at)gmail.com>
An: rotaxengines-list(at)matronics.com
Betreff: Engine Vibration
Any thoughts?
regards
Geoff Bell
Slepcev Storch
912 uls 731 hours
http://forums.matronics.com/viewtopic.php?p=155064#155064
Psssst! Schon vom neuen GMX MultiMessenger gehört?
Der kann`s mit allen: http://www.gmx.net/de/go/multimessenger?did=10
PostPosted: Sun Dec 30, 2007 6:03 pm    Post subject: Engine Vibration Reply with quote
Hi Geoff,
Good luck
Thilo
Any thoughts?
regards
Geoff Bell
Slepcev Storch
912 uls 731 hours
Gtblu
PostPosted: Sun Dec 30, 2007 6:53 pm    Post subject: Re: Engine Vibration Reply with quote
Thanks Thilo, Yes for it to change so quickly (within two weeks) suggests dirty prop maybe, lots of insects at the moment due to wet warm weather.
Thanks.
regards
Gt
Johann G. Johannsson
PostPosted: Sun Dec 30, 2007 7:56 pm    Post subject: Engine Vibration Reply with quote
Hello Geoff.
Happy New Year to you.
Do you have an IVO Prop on your Slepcev Storch?
I had this problem on my Kolb ultralight, which was caused be a faulty
prop. There was no way to adjust the propeller, it was balanced and tracked
perfectly, but nothing worked. Finally sent the prop to Ivo for
replacement. Problem solved.
Just a thought.
Best regards,
Johann G.
Iceland.
Zenith 701.
revs
as
right.
others
on
Any thoughts?
regards
Geoff Bell
Slepcev Storch
912 uls 731 hours
Johann G.
Iceland.
Flying Zenith 701.
Roger Lee
PostPosted: Mon Dec 31, 2007 8:56 am    Post subject: Re: Engine Vibration Reply with quote
Hi Guys,
If you have never balanced your prop it should be done. It should be statically balanced first. This means off the plane with the hub and all. Then you should make sure it is tracking properly. This means each blade is turning in the same plane while rotating. Last, but the most important every prop on a plane should be dynamically balanced. This means using an instrument to check the vibration against its weight and balance while it is running at its cruise rpm. You should also check the blades to make sure they are the exact same pitch with a prop protractor.
When I got my Flight Design CT I put a Warp drive on it. When it was dynamically balanced it was .33" out. That's a lot. Weight was added to one side and now it's only .01 out. Huge difference. The .33" out of balance was not felt in the stick. If you can feel a prop out of balance through the stick then it is way out. This is hard on many different parts of your engine and even the mounts. If you have never statically and dynamically balanced your prop that would be a priority if it were me. The longer a system runs out of balance to bigger the toll later.
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056
hgmckay
PostPosted: Mon Dec 31, 2007 4:42 pm    Post subject: Engine Vibration Reply with quote
Roger:
Tracking and setting the pitch on my three blade prop assembly is not a real
problem. I do this on my plane with the plane level and in the hanger.
However, do you have any good ideas on how to set up a three blade WoodComp
prop, Klassic 160/3/R (hub and bolts) for static balance? Seems to me one
would need a mating flange to bolt the prop/hub assembly to. This assembly
would then need to be concentrically bolted to a shaft that is in a bearing
assembly that allows free rotation of the entire setup. Then, how does one
statically balance a three blade prop?
The other question is, how on earth does one dynamically balance such a prop
assembly (three blade) while running at cruise speed?? Kind of hard to do in
the air!! The WoodComp manual that came with the three blades states " each
propeller (blades and hub) was factory assembled from blades with the same
weight and center of gravity, then carefully balanced. Make sure you insert
each blade into the appropriate opening in the center hub, blades and
openings are numbered and MUST NOT be mixed under any circumstances!" No
clarifying statement as to whether this is a static or dynamic balance. I
suspect it is a static balance, but I don't really know. If this is not
sufficient, again I ask, how does one ordinary LSA pilot dynamically balance
such an assembly??
Hugh McKay
Allegro 2000
Rotax 912UL
N661WW
ami(at)MCFADYEAN.FREESERV
PostPosted: Tue Jan 01, 2008 1:57 am    Post subject: Engine Vibration Reply with quote
<<again I ask, how does one ordinary LSA pilot dynamically balance
such an assembly??>>
Try:
http://www.smartavionics.com/pb/pb.html
Duncan.
Thom Riddle
PostPosted: Tue Jan 01, 2008 4:49 am    Post subject: Re: Engine Vibration Reply with quote
Hugh,
The Woodcomp props are statically balanced at the factory, as you suspected. Unfortunately, over time they get nicks etc. which will affect the static balance a bit. Dynamically balancing a prop/engine requires expensive equipment and competent technician. The prop/engine combination balance check is done while running. Here is a decent FAQ on the subject.
http://www.dssmicro.com/faqs/fqprpbl.htm
As you might expect, DSSMICRO sells this equipment for doing prop balancing.
I've not found any one in our area that does dynamic prop balancing and the equipment is too expensive unless you are going into the prop balancing business.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
hgmckay
PostPosted: Tue Jan 01, 2008 6:32 am    Post subject: Engine Vibration Reply with quote
Thom:
What you have stated is what I suspected. I don't know how many LSAs have
had their props dynamically balanced, but I suspect little to none, and the
reason being the complexity and cost of doing so. I would imagine that good
careful assembly of the WoodComp prop (or any other prop) and hub together,
with careful setting of the pitch on each blade and good care of the blades
(barring something nicking or damaging a blade) would be sufficient for the
Sport Pilot. Unless there is some damage to the blades or a real indication
of a prop vibration problem, I would expect many hours of good flying. I
would imagine though that if one would get damage to one of the WoodComp
blades, you would need to replace all three as well as the hub because they
are factory balanced as a unit.
No, I'm not going into the prop balancing business!
Hugh
Thom Riddle
PostPosted: Tue Jan 01, 2008 6:48 am    Post subject: Re: Engine Vibration Reply with quote
Hugh,
I've corresponded with the Woodcomp folks and they said they can replace a single blade given the serial number of the blade you want to replace because they keep records of exact weight of each blade they manufacture, as balanced. It will be the same as the original in static balance. The serial number is the same for each of the blades on a given prop plus a blade number, which is also required for single blade replacement.
Happy New Year!
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
Roger Lee
PostPosted: Tue Jan 01, 2008 8:28 am    Post subject: Re: Engine Vibration Reply with quote
Hi Hugh,
Your Woodcomp was statically balanced at the factory. Aircraft Spruce and a few other people sell a very simple static balance device that utilizes a bubble balancer on a string. This set up works well enough for those who's props weren't done or wants to check theirs once a year.
Even though your prop is statically balanced, everything forward of the mounting plate on the gearbox i.e. nuts, bolts, washers, spinners and the such are not and none of these are in balance when turning 5000 rpm. All props should be balanced on the plane spinning at cruise rpm. You go out to the pad and chalk the wheels and tie it down. The balancer then can measure vibration that you can not feel. There has to be someone in your area that does this for other aircraft. Just start asking around with the service shops and I'm sure someone knows of a person who can do a dynamic balance.
Get on the web and type in prop balancing + your town.
The instrument that does this does cost $2K and up, but people who service aircraft should know of someone who has this instrument. Dynamic prop balancing is a regular aircraft maint. function. When I started to look I didn't know of anyone in my area. After a little search I found 4 people who did this. Prices were from $175-$250. Takes about an hour.
Think of a dynamic prop balance that is not done like this.
If someone smokes cigarettes or is a diabetic it does not take their life right now, but over a long time period it causes many other problems and an early death. A static balance only for your engine and gearbox is not enough. My Warp Drive was static balanced at the factory, but way off when mounted on the plane with hardware and running.
Gentlemen,
Keeping your engine and plane in good health makes your flying safer, but also extends the life of all your aircrafts components. Don't wait until it breaks to fix it. A little preventive medicine can go a long way in your safety and your pocketbook.
Roger Lee
Tucson, Az.
Cell 520-349-7056
PostPosted: Tue Jan 01, 2008 8:50 am    Post subject: Engine Vibration Reply with quote
<<It will be the same as the original in static balance>>
In theory. The practice is that the blades that have been in service will
have settled-in at the roots and, if wood or wood cored, have probably
changed weight or shape too.
I tried this balance numbers-game replacing one blade on a 3-blade GSC; the
imbalance present made is unserviceable before rebalancing.
Similarly, I have just reassembled an almost new Arplast 3-blade composite
which required the equivalent of 2 grammes at one of the tips to make it
statically balance; this is actually a lot of imbalance and would be very
apparent on a static balancer at the factory.
Duncan McF.
Thom Riddle
PostPosted: Tue Jan 01, 2008 9:10 am    Post subject: Re: Engine Vibration Reply with quote
Here is a good website link that discusses dynamic prop balancing with photos of the equipment etc.
http://www.dvatp.com/aviation/maintenance/dynamic_balancing
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
hgmckay
PostPosted: Tue Jan 01, 2008 9:16 am    Post subject: Engine Vibration Reply with quote
Roger/Thom:
Thanks for all of your input on the matter of vibration and balancing of
props. I will inquire as to who may do this type of balancing in my area.
By the way, I noticed an additional "blob" of fiberglass that was definitely
added and sanded on the inside of my Allegro 2000 fiberglass spinner. I
assumed this was intentionally done to balance the spinner.
Roger/Thom, if one would weigh each of the attaching (6) bolts, nuts, and
washers, and assuming each item was within an ounce or less of each other,
and these items rotating concentrically on a bolt circle of 75 mm (912UL
gearbox mounting plate) at say 5000rpm, do you think 6 ounces of eccentric
mass at a radius of 37.5mm rotating at this speed could be actually
physically counterbalanced?
Hugh
Mark Burton
PostPosted: Tue Jan 01, 2008 9:21 am    Post subject: Re: Engine Vibration Reply with quote
Howdy folks,
With regard to the expense of dynamic prop balancing equipment. My company, Smart Avionics, used to sell a balancer (the PB-1) that was aimed at the homebuilt aircraft market. It was cheaper and had more functionality than the low range DSS product. Quite a few PB-1 units were sold all around the world and I have had lots of good feedback and success stories from the people who used them.
I don't make that balancer anymore but I am working on a new balancer that I expect to be available in the first quarter of 2008. Price is not yet fixed but it will provide good value for money. If you are interested, please take a look at www.smartavionics.com in a couple of months.
Happy New Year,
Mark
trigo(at)mail.telepac.pt
PostPosted: Tue Jan 01, 2008 9:36 am    Post subject: Engine Vibration Reply with quote
Hi Mark
I am one of the guys waiting for your PB-2, not only for my homebuilt but
also for my microlight
Carlos
[quote] --
hagargs(at)earthlink.net
PostPosted: Tue Jan 01, 2008 10:01 am    Post subject: Engine Vibration Reply with quote
I have had my prop (airmaster on a 914) dynamically ballanced after I had
balanced my carbs out with my mercury manometers (the only way to go, nuts
to the white suited hazmat people) no moving parts and no calibration
concerns.. After that the engine ran like a turbine from 1800 rpm up.
There seems to be a lot of frettng about doing this. The process is is
very easy and straight forward. When I had my prop done I was taken aback.
The apparatus used was the same type used by the technicians in the plant I
work in to balance large motors. Just substute "rotating machinery" for
"propeller" and there are innumerable people who know how to do this.
Bolt an accelerometer and a photo eye to the engine. Put a reflective dot
on the back of one of the prop blades and run the engine up to the
specified RPM. The machine does the rest telling you where to put the
weights and how much. Now if your spinner back plate is already
pre-drilled at 30 degree intervals and you have a 9 series engine (bolt
holes on the gear box are in just the right place for the photoeye and
accelerometer) the job is a piece of cake. The biggest hassle and most
time consuming chore is taking the spinner on and off to add another
washer/weight to the spinnner backplate otherwise the job would have taken
about 15 minutes after the prep work is done. A gross, medium, and fine
balance is done adding smaller amounts of mass at different locations
until the desired response is obtained. The people at Phoenix Composits
did mine and I don't believe it was much away from $100.
Steve Hagar
Mesa AZ
[Original Message]
To: <rotaxengines-list(at)matronics.com>
Date: 1/1/2008 9:30:11 AM
Subject: Re: Engine Vibration
Hi Hugh,
Roger Lee
Tucson, Az.
http://forums.matronics.com/viewtopic.php?p=155353#155353
randy(at)romeolima.com
PostPosted: Wed Jan 02, 2008 7:46 am    Post subject: Engine Vibration Reply with quote
I'm just starting to lurk here as I consider starting a Kitfox Super Sport
with a 912. In terms of prop balancing, our EAA Chapter bought one of the
balancers referenced below and we make extensive use of it. This can be a
great goal/project for a chapter, see the below link for details...
http://www.eaa105.org/Programs/programs.htm#PropBalancing
Our members LOVE this program, and reducing vibration helps extend the life
of all components on the plane, especially in the FWF area.
Randy Lervold
www.rv-3.com
www.rv-8.com
hgmckay
PostPosted: Mon Jan 14, 2008 2:13 pm    Post subject: Engine Vibration Reply with quote
Roger:
I have tried to find some one near here (Charlotte and or Hickory, NC) that
can dynamically balance my Allegro 2000 that has a 3 blade WoodComp prop. I
have found that no one will do it for a number of reasons two of which
follows:
1. They do not balance props that have a gearbox between the engine
propeller drive.
2. There is no place on the WoodComp aluminum hub to attach balance weight.
At least one shop said they would look at my plane if I would fly it down to
their shop. I don't fully understand why the gearbox and the gears would be
a problem. Anyway, right now I have run into a dead end on this matter, and
don't fully know why.
Hugh
Goto page 1, 2  Next
Page 1 of 2
