Switch Failure
bruceflys(at)comcast.net
PostPosted: Sat Feb 25, 2006 6:01 am    Post subject: Switch Failure Reply with quote
FWIW, I found this message on the GlaStar e-mail group:
Just thought that I would pass this along for everyone's edification. I
noticed that my strobes were not working the other day so I checked the
fuses and sure enough, the strobe fuse was blown. I replaced the fuse and it
popped as soon as I flipped the master switch on. I traced the wire from the
fuse panel to the toggle switch and there was no chafing or problems
visible. I disconnected the wire that goes to the strobe power supply from
the strobe switch and tried it again, POP! Now I'm looking right at the 18"
of wire that goes from the fuse panel to the strobe switch and it's
undamaged. The wire that goes to the power supply is disconnected and the
switch is in the OFF position yet there is a dead short! I removed the
switch and checked the continuity between the terminals and the body of the
switch and sure enough, the switch was shorted internally. I replaced the
switch with one of my spares and all was back to normal. I took the switch
apart and found that the moving contact rocker inside the switch was
touching the switch body. I'll include a photo of the switch guts for your
amusement, you can see the arcing on the switch cover. The switch is from
B&C and is a CARLING brand. I'll be sure that I carry a spare in my parts
bag.
rv8ch
PostPosted: Sat Feb 25, 2006 9:57 am    Post subject: Switch Failure Reply with quote
bag.
Can you put the photo on imageshack.us and send us a link? First time
I've heard of someone with a failed switch.
Mickey
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
Mickey Coggins
http://www.rv8.ch/
nuckollsr(at)cox.net
PostPosted: Sat Feb 25, 2006 1:16 pm    Post subject: Switch Failure Reply with quote
At 08:54 AM 2/25/2006 -0500, you wrote:
<bruceflys(at)comcast.net>
bag.
Please if you can. Send me the switch, removed with care to avoid
disturbing it's condition. I'll reimburse you for any expense.
It's VERY seldom we get to do an autopsy on field failures. So
much of what's seen by technicians in the trenches is simply viewed
as a maintenance issue with no interest in root causes. This makes
our jobs as systems designers exceedingly more difficult. We cannot
avoid or fix a condition for which we have no knowledge.
Your cooperation in an effort to understand would be appreciated more
than you know.
sportav8r(at)aol.com
PostPosted: Sat Feb 25, 2006 5:14 pm    Post subject: Switch Failure Reply with quote
An argument for switching the ground lead, vs the hot side, unless a stuck-on condition is dangerous? Just a thought...
-Bill B
PostPosted: Sat Feb 25, 2006 6:48 pm    Post subject: Switch Failure Reply with quote
-Bill B
How would this be better? The same failure might then leave you with
some accessory running where you couldn't turn it off. Of course, this
gives rise to the secondary argument about having pullable breakers
accessible to pilots, etc.
I think I'd rather have it function exactly as described and get
OFF line and out of consideration. A second order consideration
in the failure tolerance equation is not to increase workload. The
switch died (albeit in what must be a really bizarre fashion) and
the fuse did its job. All done.
