Backup oil/fuel pressure switch/light
Martin Pohl
PostPosted: Sun Dec 23, 2007 4:27 am    Post subject: Backup oil/fuel pressure switch/light Reply with quote
I am in search of an additional oil and fuel pressure switch that I will run in parallel to the Rotax-supplied sensors. The sensors feed the Dynon EMS-120 while the 2 additional switches shall drive backup warning lights.
They should be normally closed (while at low pressure) and should switch at a pressure of approx. 0.8bar/12psi (oil) resp. 0.15bar/2psi (fuel).
Does anyone know a source for such switches? Or how did you install your backup-lights?
Cheers Martin
Martin Pohl
Zodiac XL QBK
8645 Jona, Switzerland
http://www.pohltec.ch/ZodiacXL/Main.html
Roger Lee
PostPosted: Sun Dec 23, 2007 12:12 pm    Post subject: Re: Backup oil/fuel pressure switch/light Reply with quote
Hi Martin,
I have a Flight Design CTSW. I have the Dynon D-100 and the D-120. No additional back up switches needed. They wire into the D-120 which will give you an alarm (audible and visual) and I have two dash mounted red warning lights. These warnings come right from the oil and fuel pressure sensors.
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056
Martin Pohl
PostPosted: Fri Dec 28, 2007 9:22 am    Post subject: Re: Backup oil/fuel pressure switch/light Reply with quote
Hi Roger
Thank you for your posting. I did not know that both oil pressure sensor and fuel pressure sensor do have a separate connector for an additional warning light. That sounds perfect.
I will get my Rotax in February 2008 and hope to have the same sensors.
Cheers
Martin
Martin Pohl
Zodiac XL QBK
