AGM longevity (was: Odyssey % of charge)
william.p.dube(at)noaa.go
PostPosted: Fri Feb 24, 2006 5:31 pm    Post subject: AGM longevity (was: Odyssey % of charge) Reply with quote
There are four main reasons why AGMs wear out.
1) Loss of electrolyte
2) Grid corrosion
3) Sulfation
4) Paste degradation
If you overcharge an AGM excessively, it will lose electrolyte and
dry out. This is NOT why they wear out in airplanes and cars (typically.)
Typically, AGMs go bad because they are not properly charged. If you
don't over charge them a little bit on a regular basis, the negative
plate gets further and further behind the positive plate. The negative
plate then sulfates and you lose capacity and cranking power. (In the
short term, you lose capacity simply because the negative plate is not
fully charged.)
Why you don't need to add water to an AGM is that the oxygen and
hydrogen gas recombine in the separator to form water. This
recombination process is not 100% efficient, and it causes the negative
plate to take slightly less charge than the positive plate when you
re-charge the battery. Each cycle gets the negative plate a bit more behind.
Occasionally, you need to purposely overcharge the battery to let the
negative plate catch up with the positive plate. A couple times per
year, you bring the battery up to 14.8 volts and let the current taper
off to less than an amp. You then push in a constant current of about 4%
of the amp-hr rating of the battery for about an hour. This cleans off
the negative plate.
High-end voltage regulators do something like this (like on boats
and motor homes). Every time you start up the engine, it charges up the
battery to normal voltage, then it gives the battery a slight overcharge
for a few minutes. Makes the big expensive AGM batteries last much longer.
>>>> What causes the other types of failures, just in case you wanted
to know. <<<
Excessive overcharging will cause the loss of electrolyte. Severe
discharge, causing reversal of a cell or two, will also cause
electrolyte loss.
Grid corrosion occurs if you leave the battery on float for a long
time. The oxygen gas formed eats at the grids that support the paste.
Sulfation is caused by leaving the battery discharged for extended
periods of time. Not fully charging the battery and leaving that way
will also cause sulfation.
Paste degradation is caused by repeated severe and/or deep
discharges. Cranking the battery flat over and over is a good way to
cause paste degradation.
Brian Lloyd wrote:
Robert L. Nuckolls, III wrote:
>>Having a smart energy monitor is necessary in a system where you will
>>have irregular charge/discharge cycles and want to know how much is left
>>in the battery.
> Agreed . . . but how does this happen on an airplane and how
> often might one expect to encounter it? . . . and are there
> less complicated and more positive ways to achieve the desired
> mission/maintenance conditions?
Oh, I agree that you don't need a complex energy monitor nor do you need
a fancy charger. OTOH, I have had experience with batteries failing due
to overcharge in hot weather and failing to charge properly in cold weather.
>>If you always recharge the battery to full every time,
>>you can have a much simpler energy monitor that isn't quite so smart.
> Yup.
>>The biggest issue as I see it is that you need to make sure you don't
>>overcharge the battery in summer but that you do actually charge the
>>battery in winter. That implies temperature compensation.
> Agreed . . . and it's not clear that we have really practical
> ways to achieve that. The LR-3 from B&C offers a battery temp
> sensor option. But it's not clear to me that this option will
> produce really meaningful differences in battery performance for
> most of our fellow airplane drivers.
I believe that this is one of the key reasons why current crop of
"sealed" AGM aircraft batteries have such a poor service record. Flooded
cell batteries shrug off overcharge by just boiling off excess water
which gets topped off by the owner or mechanic. AGMs build up pressure
in the case and valves open and relieve the pressure, letting the water
go to the atmosphere. The AGM battery, having no excess
electrolyte/water, quickly quits working. I have never had an AGM
battery (Concorde especially) survive longer than two years in a
standard aircraft electrical system.
Brian Lloyd
brian-yak(at)lloyd.com
brian
PostPosted: Fri Feb 24, 2006 7:50 pm    Post subject: AGM longevity (was: Odyssey % of charge) Reply with quote
the negative plate.
Right. This is called an equalization charge.
Hmm. The big, expensive AGM and gel-cell batteries I used on my boat
came with warnings from the manufacturer to never do an equalization
charge, that the normal charging regimen would ensure proper charging.
So when it comes to batteries, I read and follow the manufacturer's
recommendations.
Good information by the way.
Brian Lloyd 361 Catterline Way
brian-yak at lloyd dot com Folsom, CA 95630
- Antoine de Saint-Exupery
Brian Lloyd
klehman(at)albedo.net
PostPosted: Sat Feb 25, 2006 6:22 am    Post subject: AGM longevity (was: Odyssey % of charge) Reply with quote
This is one I've never heard of before.
The manufacturer of my wee AGM specifies a float voltage which I've been
using. This implies that a pulse type battery maintainer might be better
or maybe that they should not be float charged continuously while in
storage?? These are small but somewhat pricey Dekka batteries on a Z-14
architecture so there is no plan to periodically replace them - just
flog flog them until noticeable starting performance suffers.
thanks
Ken
brian
PostPosted: Sat Feb 25, 2006 9:11 am    Post subject: AGM longevity (was: Odyssey % of charge) Reply with quote
Follow Deka's instructions for maintaining the battery. My larger 245AH
8D Deka AGMs say don't give them an equalization charge. Flooded cell
batteries benefit from a periodic equalization charge.
Brian Lloyd
alexpeterson(at)earthlink
PostPosted: Sat Feb 25, 2006 7:07 pm    Post subject: AGM longevity (was: Odyssey % of charge) Reply with quote
to let the negative plate catch up with the positive plate. A
couple times per year, you bring the battery up to 14.8 volts
and let the current taper off to less than an amp. You then
push in a constant current of about 4% of the amp-hr rating
of the battery for about an hour. This cleans off the negative plate.
Bill, excellent post! What would be your recommendation for a charger to
accomplish this periodic overcharging method for cleaning the negative
plate? I suspect that this is what my PC680 needs after two years.
Alex Peterson
RV6-A N66AP 719 hours
Maple Grove, MN
brian
PostPosted: Sat Feb 25, 2006 7:50 pm    Post subject: AGM longevity (was: Odyssey % of charge) Reply with quote
Before you opt for an equalization charge make sure this is supported by
the manufacturer.
As for an equalization charge, you can accomplish it with any adjustable
power supply that will allow you to set the voltage to that specified by
the manufacturer for performing an equalization charge. Typically an
equalization charge takes around two hours over and above the time
required to bring the battery up to full charge.
Brian Lloyd
PostPosted: Mon Feb 27, 2006 5:14 pm    Post subject: AGM longevity (was: Odyssey % of charge) Reply with quote
I know a little bit about batteries. Check out my other hobby.
<http://www.KillaCycle.com>
and my daily driver <http://www.haritech.com/wabbit.html>
Bill Dube'
>the negative plate.
recommendations.
PostPosted: Mon Feb 27, 2006 5:18 pm    Post subject: AGM longevity (was: Odyssey % of charge) Reply with quote
You are correct. They should not be continuously float charged for
longest life.
AGMs typically have very small self-discharge. If your airplane doesn't
have some continuous drain (like the clock or avionics memory) then the
AGM should stay quite well charged for 6 months or so. If you put on the
float (or pulse) charger for a couple of days every few months, that
should keep up the AGM just fine.
Bill Dube'
thanks
Ken
PostPosted: Mon Feb 27, 2006 5:54 pm    Post subject: AGM longevity (was: Odyssey % of charge) Reply with quote
Here is an example of a high-end battery charger. Zivan sets these up to
giver precisely the correct charge algorithm for the specific brand and
type of battery.
http://www.zivanusa.com/BC1BatteryCharger.htm
They use this sort of high-end charger on fork lifts, golf carts,
etc where they care about battery life. Take a look at the charge curves
on some of these chargers and you will get an idea of the right way to
charge a battery.
I own a Zivan NG3 that I used for my electric car when I had Optima AGM
lead-acid batteries in it. It ran the curves that I spoke of in the
previous post. In an EV, you typically have over $1000 in batteries that
you want to last as long as possible. Thus, you buy a charger that will
run the "perfect" charge cycle. These high-wattage chargers typically
cost more than $1000, so adding the brains to do the proper charge
doesn't change the final cost of the charger very much and saves you a
bunch in batteries.
If you have an AGM that is a little tired, you can try the
overcharge that I outlined in the previous post. If it has sulfation or
a undercharged negative plates, it will perk up a bit. Crank the plane
up, let it charge normally (like on a flight) and then give it another
overcharge. It should crank even better.
If it is running out of water because your voltage regulator is set
too high, the overcharge will not help. You will not notice a difference
in cranking voltage. Thus, there is no point in doing a second go at it.
You should probably just get a new battery.
To do the overcharge, I use a bench power supply and set the voltage
and current exactly, but you won't have one probably. A good substitute
is a 15 volt, 2 or 3 amp Toshiba laptop AC adapter. You can pick one up
on Ebay for about $10.
http://cgi.ebay.com/Toshiba-Laptop-Power-Adapter-DC15V-2A_W0QQitemZ6853456587QQcategoryZ31517QQrdZ1QQcmdZViewItem
or
http://cgi.ebay.com/Toshiba-Laptop-Power-Adapter-PA2426U-for-T-Series-NIB_W0QQitemZ6852048387QQcategoryZ31517QQrdZ1QQcmdZViewItem
or
http://cgi.ebay.com/GENUINE-TOSHIBA-LAPTOP-AC-ADAPTER-PA2450U-POWER-CORD_W0QQitemZ6852574714QQcategoryZ116318QQrdZ1QQcmdZViewItem
Cut off the computer connector and attach a pair of clip leads. (The
shield is negative.) Disconnect one of the battery leads and connect up
the Toshiba laptop supply. Leave it on for a 3 or 4 hours. Should do the
trick. Don't leave it connected for more than a few hours or it will dry
out your battery. When the Toshiba power supply is no longer warm to the
touch, disconnect it.
Bill Dube'
Alex Peterson
Maple Grove, MN
hdwysong(at)gmail.com
PostPosted: Mon Feb 27, 2006 6:14 pm    Post subject: AGM longevity (was: Odyssey % of charge) Reply with quote
Cool bike, Bill! I must admit that I bookmarked your web page
(alongside www.deadmike.com) to use when "she" starts telling me that
flying airplanes upside-down is too dangerous. Wink
D
Bill Dube'
