wing tip
cjhukill(at)cox.net
PostPosted: Sun Dec 16, 2007 5:07 pm    Post subject: wing tip Reply with quote
I'm about to fit the wingtips to the wing, and I need to determine the neutral aileron position to align and trim the length of the trailing edge of the tip with the aileron. Does the neutral position that is set with the rigging of the wing bellcrank give a true neutral, or does the aileron need to be set to trail with the flap for a accurate neutral position? On the RV8, I had to wait until the wing was mounted to the fuselage, install the flaps and rig to full up, then adjust the aileron trail to the flap trail to get a true neutral. Am I better off waiting until this scenario on the 10 as well?
Chris Hukill
(what, more fiberglass!)
recapen(at)earthlink.net
PostPosted: Sun Dec 16, 2007 5:22 pm    Post subject: wing tip Reply with quote
On my 6A, I had an airfoil template that I used for the ailerons, flaps and tip - even prior to inatallation of the wing to the fuse - and it hasn't needed to be changed since I installed the wing.
I was planning to do the same again......
rnewman(at)tcwtech.com
PostPosted: Sun Dec 16, 2007 5:38 pm    Post subject: wing tip Reply with quote
Chris, Other's will have to chime in, especially those flying. When I did my wing tips I used the "neutral jig" which sets the aileron neutral position, checked and aligned the flaps to the ailerons and then set my wing tip trailing edges to the ailerons. I believe I had the "old version" of wing tips as they were about 3/4" longer than the aileron, but none the less, I had to cut the upper and lower wing tip surface at the trailing edge to pull the wing tip into alignment with the aileron. I used a long straight edge to align the wing tip to the aileron and used it as a clamping jig while the resin dried. I remeber cutting about 3" forward from the trailing edge to give the upper and lower tip skin some compliance so I could easily align it with the aileron. When I was done it came out swell.
Here's a picture when it was all done.
-Bob Newman
TCW Technologies
www.tcwtech.com
 Filesize:  107.92 KB
 Viewed:  408 Time(s)
Tim Olson
PostPosted: Sun Dec 16, 2007 6:10 pm    Post subject: wing tip Reply with quote
I would get it all in the wing rack and get the flaps installed
so they're all the way retracted, and then align the ailerons
to them and then mount the wingtip so it aligns with the flaps
and ailerons. That way when you're in cruise it's all lined
up nicely. If you just did it rough now, chances are it won't
be aligned well later and you may end up with the famous
"droopy aileron" syndrome have to deal with that later.
Chris Hukill
jim(at)CombsFive.Com
PostPosted: Mon Dec 17, 2007 5:21 am    Post subject: wing tip Reply with quote
Bob,
That is one sweet workshop!
Jim C
(40192)
Date: 2007/12/16 Sun PM 08:37:53 EST
Subject: Re: wing tip
-Bob Newman
TCW Technologies
www.tcwtech.com
cjhukill(at)cox.net
PostPosted: Mon Dec 17, 2007 9:22 am    Post subject: wing tip Reply with quote
I just got off the phone to Vans, and was told that the rig on the 10 is to put the flaps all the way up against the hard stops at the rear spar, which is the reflex position, then rig the aileron to trail with the flaps, then the tip to the aileron. The bellcrank jig is used only to center the bellcrank, not to rig the aileron. Thanks to all.
Chris Hukill
