Posted: Fri Feb 24, 2006 8:01 am Post subject: Comm Antenna placement |
Fellow Listers,
I have a Comant bent whip com antenna that I am planning for the underside of my 6A.
I know that I want to keep it away from the exhausts so I was initially planning on installing it in the first bay outboard of the elevator pushrod tunnel - right under the copilot seat.
Where are the rest of you putting it?
Ralph Capen
RV6A N822AR (at) N06 90% done/to go
rv8striker(at)hotmail.com Guest
Posted: Fri Feb 24, 2006 9:21 am Post subject: Comm Antenna placement |
Ralph,
I've got the same antennas but they're on an -8. Mine are also on the belly
and they both work great in that position. I know that if you mount more
than one, they need to be placed several feet apart. The "radio heads" on
the list could explain why that needs to be done and what the distance
should be. I ended up putting one ahead of the other several feet apart
based upon advice from a avionics shop.
Steve Struyk
St. Charles, MO
RV-8, 32 Hours
HCRV6(at)comcast.net Guest
Posted: Fri Feb 24, 2006 10:32 am Post subject: Comm Antenna placement |
I put mine on the belly about eight inches forward of the baggage bulkhead and just outside the elevator pushrod tunnel on the left side. This gave it lots of ground plane area and was far enough from the radio head. It works great in this location. I have never had a com problem even on the ground in locations where others with belly mounted antennas have sometimes had reception difficulties.
Harry Crosby
RV-6 N16CX, 183 hours
-------------- Original message ----------------------
Fellow Listers,
6A.
Ralph Capen
Gary.A.Sobek
Posted: Fri Feb 24, 2006 10:45 am Post subject: Comm Antenna placement |
I have two of the same antenna that your are planning. Mine are located
just forward of the Wing Spar as close to the outboard side as the could be.
You may need to move inward 6" or so to clear the landing gear on the -6A.
They work great in this location. This location simplifies installation
in that you do not need to route the coax aft of the spar.
Gary A. Sobek
"My Sanity" RV-6 N157GS O-320 Hartzell,
1,832 + Flying Hours So. CA, USA
http://SoCAL_WVAF.rvproject.com
----Original Message Follows----
Reply-To: rv-list(at)matronics.com
To: rv-list(at)matronics.com, rv6-list(at)matronics.com, RV7A(at)yahoogroups.com
Subject: Comm Antenna placement
Date: Fri, 24 Feb 2006 10:59:50 -0500 (GMT-05:00)
Fellow Listers,
of my 6A.
Ralph Capen
c.ennis(at)insightbb.com Guest
Posted: Fri Feb 24, 2006 11:27 am Post subject: Comm Antenna placement |
Ralph,
I put mine behind the rear baggage bulkhead, on the centerline..works like
a charm.
Charlie Ennis
