Craymondw(at)aol.com Guest
Posted: Thu Dec 13, 2007 7:33 am Post subject: GL 2FT nose wheel |
My nose wheel developed a shimmy so I took apart the nose wheel assembly and noticed the Allen stop bolt and the wear pad hold on screw were both lose allowing the plate to move that allowed the nose wheel to easily move from side to side. The holes in the aluminum plate that the wear pad was glued to where slightly elongated and part of that wear pad between the bolt and the screw area delaminated. I would suggest roughing up the aluminum plate before gluing the wear pad on. I reinstalled the screw and Allen bolt with star washers. I took the suggestion about using shims on the axle cap/ shaft assembly so that the long through bolt could be torque down with the larger axle nut called for by Glasair Corp.
See AOL's top rated recipes and easy ways to stay in shape for winter.
| - The Matronics Glasair-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Glasair-List |
