FWF wiring
jfrjr(at)roadrunner.com
PostPosted: Wed Dec 12, 2007 6:44 pm    Post subject: FWF wiring Reply with quote
Need advice on wire runs in the engine area. Is it okay to run the CHT/EGT wires in the same bundle as the lower plug wires as they run aft? How does one attach that bundle/bundles----with Adel clamps to a rocker cover screw, or something else? Can all the CHT/EGT lines run thru the firewall at the same location? Any and all advice/pictures welcomed. Jay Rowe (about to finish FWF) 40301
[img]http://promos.hotbar.com/promos/promodll.dll?GetPromo&El=&SG=&RAND=19881&partner=seekmo&/p.gif[/img]
 Filesize:  49 Bytes
 Viewed:  2314 Time(s)
rnewman(at)tcwtech.com
PostPosted: Wed Dec 12, 2007 7:11 pm    Post subject: FWF wiring Reply with quote
Jay, I'm not as far on my -10, However, In our Glastar all CHT and EGT cables are bundled together with the lower spark plug wires and run aft together to the magnetos, then the cht/egt bundle runs with some other wires together thru the firewall. 8 years running with no issues.
-Bob Newman
TCW Technologies
www.tcwtech.com
 Filesize:  49 Bytes
 Viewed:  2315 Time(s)
PostPosted: Wed Dec 12, 2007 8:51 pm    Post subject: FWF wiring Reply with quote
[quote] Thanks Bob, I'll follow your lead. Jay
 Filesize:  49 Bytes
 Viewed:  2310 Time(s)
