by0ung(at)brigham.net Guest
Posted: Sun Dec 02, 2007 4:11 pm Post subject: Tail boom support. |
The best idea I have seen for the tail boom support was Eric Weaver's.
He had a 6 inch irrigation saddle/tee fitting that clamped around the pipe
and in the 2 inch tee fitting he used a piece of 2 inch pipe that was
attached to a floor mounted fitting.... when he removed the plane from the
trailer he had a way to remove the support from the floor fitting and
mounted it to a swiveling wheel.
Boyd
