JetPilot
Posted: Thu Nov 29, 2007 5:42 pm Post subject: Piano Hinge Lubrication ... |
Do you guys lubricate the piano hinges on the control surfaces of your Kolbs ? I have read reports of these wearing on the elevator and rudder over time. If so what type of oil do you use on them ?
Mike
Kolb MK-III Xtra, 912-S |
jb92563
Joined: 23 Mar 2007 Posts: 314 Location: Southern California
Posted: Thu Nov 29, 2007 9:39 pm Post subject: Re: Piano Hinge Lubrication ... |
A dry lube like graphite spray would be good.
Wet sticky lubes get dirt and grit mixed in them and cause faster erosion of the metal parts....definitely not a good thing.
_________________ Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
Do Not Archive |
