hansconser(at)gmail.com Guest
Posted: Thu Feb 23, 2006 9:12 am Post subject: RV10-List Digest: 24 Msgs - 02/22/06 |
| Quote: | Time: 08:34:00 AM PST US
Subject: RE: Installing aux fuel tank
Before this goes off the deep end, it is not about support. I happen to
agree with Tim, the question does not need to be there, but if do not
archive appears anywhere in the email stream then the message does not
get in there, and my point was that it might be worth an extra 11
thousand 1's and 0's to be stored if the responder clicks on the wrong
message and does not get in there. But by posting do not archive after
wards and not in the original message then not only are we wasting the
storage space of the original message, but also valuable bandwidth at
each of the 1000's of ISP's that we all belong to, to just see a
message
that says do not archive. There is a monthly reminder that is sent out
to each of us with the rules and guidelines, and too waste additional
bandwidth sending an email saying do not archive after the archive has
already taken place is pointless. So with that being said if we all
looked at the rules, then this would be a non issue,
In this particular case I do believe that the question itself should
not
be in the archive, but the answer needs to be, and that is all I was
referring too.
Dan
Do not archive because it is just the ramblings of a builder in
withdrawal during the work day
Do you really think this makes sense? I have read this three times and
I have no idea of what you are trying to say.
Hans
