Manifold Pressure Fitting
Bill Schlatterer
PostPosted: Thu Nov 22, 2007 9:35 pm    Post subject: Manifold Pressure Fitting Reply with quote
Ron, there was a fitting in the Vans kit with a 1/8 hose end on it for a manifold fitting but I also needed a manifold pressure source for my P-Mag so I just modified a 90 degree bulkhead fitting to do both. I took two short 3/16 bolts, cut the heads off, and used a 40(?) drill in a drill press to go right through the bolt to make it hollow. Then I just drilled the bulkhead fitting and threaded it for the 3/16 bolts and put a little JB Weld on it to be sure. Used regular manifold line (#6 I think) to right rear cylinder. Be sure to put the restrictor in. Total time was about 20 minutes as I remember it. Pictures should tell the story.
Hope this helps.
Bill S
7a finishing finishing finishing ,......
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of McGANN, Ron
Sent: Thursday, November 22, 2007 4:21 PM
Subject: Manifold Pressure
G'day all,
Happy thanksgiving to the guys across the pond!
I know this has been discussed in the past, but listers have been using 'Do Not Arch. . . ' so diligently that the archive trail is pretty fragmented (ie useless). Where does one find an adapter for the 1/8" tube (into the GRT EFIS) to the 3/32" restrictor at the manifold pressure bulkhead fitting??
Ron
-187 finishing
"Warning:
The information contained in this email and any attached files is
confidential to BAE Systems Australia. If you are not the intended
recipient, any use, disclosure or copying of this email or any
attachments is expressly prohibited. If you have received this email
in error, please notify us immediately. VIRUS: Every care has been
taken to ensure this email and its attachments are virus free,
however, any loss or damage incurred in using this email is not the
sender's responsibility. It is your responsibility to ensure virus
checks are completed before installing any data sent in this email to
your computer."
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
 Filesize:  186.51 KB
 Viewed:  327 Time(s)
 Filesize:  137.44 KB
 Viewed:  321 Time(s)
