pg 20-6 inboard bottom wing skin nutplate
jchang10
PostPosted: Thu Nov 22, 2007 8:33 am    Post subject: pg 20-6 inboard bottom wing skin nutplate Reply with quote
Happy thanksgiving! i know it's a holiday, because i always end up with
a problem on the start of a holiday.
http://www.jline.com/log/aviation/build/airframe/wings/photos/sec20/IMG_5509.html
http://www.jline.com/log/aviation/build/airframe/wings/photos/sec20/IMG_5510.html
The above photos show the bottom inboard wing rib. You can see where one
of the nutplate hole patterns in the skin, lines up right between a
notch in the rib flange.
On page 20-6, it calls for a K1100-08 here, which matches the hole
pattern pre-punched into the bottom skin, but this will make for an
awkward rivet in the notch without a shim or another type of nutplate.
Nothing in the archives about this. What am i missing or did i do wrong?
Jae
40533 - back to the wings
#40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011
n8vim(at)arrl.net
PostPosted: Thu Nov 22, 2007 8:50 am    Post subject: pg 20-6 inboard bottom wing skin nutplate Reply with quote
Here's a photo of mine; I was told to just rivet it (the rivet will expand slightly):
[img]cid:part1.07070904.04040503(at)arrl.net[/img]
-Jim 40384
Jae Chang wrote:
--> RV10-List message posted by: Jae Chang <jc-matronics_rv10(at)jline.com> (jc-matronics_rv10(at)jline.com)
Happy thanksgiving! i know it's a holiday, because i always end up with a problem on the start of a holiday.
The above photos show the bottom inboard wing rib. You can see where one of the nutplate hole patterns in the skin, lines up right between a notch in the rib flange.
On page 20-6, it calls for a K1100-08 here, which matches the hole pattern pre-punched into the bottom skin, but this will make for an awkward rivet in the notch without a shim or another type of nutplate.
Jae
 Filesize:  56.63 KB
 Viewed:  457 Time(s)
drfred(at)suddenlinkmail.
PostPosted: Fri Nov 23, 2007 9:02 am    Post subject: pg 20-6 inboard bottom wing skin nutplate Reply with quote
Jae;
I went out and looked at my wings. Did the same thing. Just put the
nut plate over the end of the gap. Just like Mr Hein's pics.
Fred
40515.
Having fun with fiberglass. .......
Jae
jchang10
PostPosted: Fri Nov 23, 2007 3:32 pm    Post subject: pg 20-6 inboard bottom wing skin nutplate Reply with quote
ok, thanks James and Fred for confirming!
Jae - 40533
Fred Williams, M.D. wrote:
<drfred(at)suddenlinkmail.com>
Jae;
Fred
40515. Having fun with fiberglass. .......
#40533 RV-10
