Tim_Lewis(at)msm.umr.edu Guest
Posted: Sun Nov 18, 2007 6:05 pm Post subject: Pullable 60 Amp Breaker |
Over the years I've looked without success for a pullable 60 Amp breaker. The other day I noticed one in a friend's Glastar (an early two-weeks-to-taxi pathfinder). I crawled under the panel, jotted down the part number, and found several sources on the net. The part number is 413-K14-LN2, made by ETA. I bought one from Pacific Coast Avionics (part number "ETA-60". They have a 75 Amp version, too.
Use with caution, of course. Pulling the breaker when the alternator is putting out significant current can ruin the alternator (V = L*di/dt, I suppose).
[img]cid:part1.03070702.07050801(at)msm.umr.edu[/img]
Tim Lewis -- HEF (Manassas, VA)
RV-6A N47TD -- 900 hrs
RV-10 #40059 under construction |
| Description: |
| Filesize: |
2.68 KB |
| Viewed: |
813 Time(s) |
