Troy Maynor
Posted: Sun Nov 18, 2007 11:46 am Post subject: RE Throttle Cables |
Michel, Troy and all
We are also using a 1.5 mm dia piano wire, along with many Rotax fellow
fliers.
Best regards,
Gilles>>>>>>>>>>>>>
Thanks Gilles,
And can you tell me where I can find this size wire? As long as it's music
wire, will it work? What is the metalurgic properties? Is it stainless? Do
you think .055" would work also?
Troy Maynor
N120EU Europa Monowheel Classic
Left to finish:
Paint,(some) interior,engine install, (some) wiring.
Weaverville, NC USA
winmail.dat |
1.81 KB |
551 Time(s) |
Gilles.Thesee(at)ac-greno Guest
Posted: Mon Nov 19, 2007 10:07 am Post subject: RE Throttle Cables |
Troy Maynor a écrit :
| Quote: | And can you tell me where I can find this size wire? As long as it's music
Troy,
I believe it is plain old piano wire.
| Quote: | Is it stainless? Do
It will certainly depend on your outer case.
But it will be better than a stranded cable with regard to buckling at
throttle lever.
Best regards,
Gilles
http://contrails.free.fr
rob(at)hyperion-ef.com Guest
Posted: Mon Nov 19, 2007 11:44 am Post subject: RE Throttle Cables |
Moments ago I took delivery of McMaster-Carr part number 9495K92, “Type 302/304 stainless steel spring wire 0.059” diameter, ¼ lb coli, 27’ coil” at US$5.32 plus shipping. I’ll post another note if I have any problem fitting the stuff but it should fit fine.
(.059 inch = 1.5 mm)
Best regards,
Rob Housman
Irvine, California
Europa XS Tri-Gear
S/N A070
Airframe complete
_____________________________________________
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com)] On Behalf Of Troy Maynor
Sent: Sunday, November 18, 2007 11:40 AM
Subject: RE Throttle Cables
fliers.
Best regards,
Gilles>>>>>>>>>>>>>
Thanks Gilles,
And can you tell me where I can find this size wire? As long as it's music wire, will it work? What is the metalurgic properties? Is it stainless? Do you think .055" would work also?
Troy Maynor
Left to finish:
Weaverville, NC USA
h&jeuropa
Posted: Tue Nov 20, 2007 6:53 am Post subject: Re: RE Throttle Cables |
Hi Troy,
We tried to find piano wire to fit in the Europa supplied housings but were unable to make that work. We purchased piano wire from McMaster but it comes rolled in a 6" diameter coil and we were unable to get the wire straight enough to work in the housings.
So we purchased Bouden cables from ACS, PN 05-15500. To connect to the carbs & throttle housing we used conduit adjusters from Lockwood PN BR03K. Had to drill them out to fit the ACS cable but the system works very nicely. Also lubed the Bouden cable assemblies with graphite lube.
Eric Trombley had a post on the forum several years ago on how he did this.
Jim & Heather Butcher
rparigor(at)suffolk.lib.n Guest
Posted: Tue Nov 20, 2007 2:37 pm Post subject: RE Throttle Cables |
Hi Jim
"So we purchased Bouden cables from ACS, PN 05-15500. To connect to the
Eric Trombley had a post on the forum several years ago on how he did this."
Question:
When you reduce friction on the throttle with solid piano wire, will the
carb springs snap the throttle to full bore? (as per Europa Service
Bulletin #7)
I can see that solid wire can reduce the possability of kink (bulge) near
throttle, but "when" one solid cable breaks at the throttle termination,
is the spring going to be able to overcome friction of solid cable and
open to full bore?
Someone a while back mentioned he used Motorcycle clutch cable, and it
would allow a quite good push without kinking. My experiance with solid
wire cables (lawnmowers, snow blowers, go carts and mini bikes and manual
choke cables for automobiles), is terminations tend to eventually fail
without warning. On the other hand clutch cables have pretty much proven
to be very reliable.
Of course a 2 cable per carb push / pull would probably be a winner!
Ron Parigoris
Posted: Tue Nov 20, 2007 4:27 pm Post subject: RE Throttle Cables |
Check what the race car people use, there are some interesting twisted
metal tape cables that are very low friction, and pushj pull
Graham
rparigor(at)suffolk.lib.ny.us wrote:
Hi Jim
Question:
Bulletin #7)
open to full bore?
Ron Parigoris
Graham Singleton
Tel: +441629820187
Mob: +447739582005
topglock(at)cox.net Guest
Posted: Mon Dec 03, 2007 7:16 am Post subject: RE Throttle Cables |
Perhaps I'm not clear on the process, but, what would one use to connect
the solid cable to the standard Europa throttle arm? Are the stock
fittings available without cable inserted?
Jeff - Baby Blue
346hrs
h&jeuropa wrote:
Hi Troy,
http://forums.matronics.com/viewtopic.php?p=147464#147464
h&jeuropa
Posted: Tue Dec 04, 2007 6:49 am Post subject: Re: RE Throttle Cables |
Hi Jeff,
Sorry I omitted the rest of the setup. At the throttle lever, each cable is wrapped around a cable bushing (Lockwood #2711 or 2710; ACS CF2710 - the catalogs are a little confusing - you need one to fit AN3 bolt and .078 dia wire-pretty sure it's the Lockwood 2711). You'll need two of them. Wrap the cable very tightly as there isn't much room in the throttle lever housing. I secured the ends of the cables with Cable End Fittings (Lockwood BR06 - or perhaps a lawnmower end from the local hardware store) and also used some Araldite for extra security. Place one cable on either side of the throttle lever like the factory setup. At the carb end, the Rotax supplied fittings will accommodate the .078 wire.
Hope this helps.
Jim
Posted: Tue Dec 04, 2007 9:44 am Post subject: RE Throttle Cables |
Thanks, Jim...
Jeff - Baby Blue
h&jeuropa wrote:
Hi Jeff,
Hope this helps.
Jim
http://forums.matronics.com/viewtopic.php?p=150335#150335
