gareywittich2000(at)yahoo Guest
Posted: Fri Nov 16, 2007 2:06 pm Post subject: VS Skin Question |
Greetings:
I have an "older" Emhennage Kit (with an older Dwg 6PP
for the VS) and just saw a "newer" Dwg 6 for the Vert
Stabilizer. Where the VS Skin meets the 2 bottom Ribs
(VS-705 and VS-704), it says - "Leave open for
empennage fairing attach ....." Are these 6 places
(each side of VS Skin) dimpled for nutplates or what
???? Otherwords what should I do to these 6 places
while building the VS, if anything ??? Do not have
the "newer instructions" that explain what goes on at
these places.
Thanks for your help, Garey
Be a better pen pal.
Text or chat with friends inside Yahoo! Mail. See how. http://overview.mail.yahoo.com/
| | - The Matronics RV8-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
flightlogic(at)shaw.ca Guest
Posted: Fri Nov 16, 2007 7:13 pm Post subject: VS Skin Question |
Gary,
I built the older emmpanage and put in nut plates on both sides. I'm not
sure if it's right yet because I haven't got to the point where the fairing
is placed.
David Thomas
vhimsl(at)roadrunner.com Guest
Posted: Sat Nov 17, 2007 1:25 am Post subject: VS Skin Question |
I am mounting the tail fairing among other things before moving my extremely
slow built RV8 to a hanger for final assembly and yes, I am getting close.
I must have a 'really' old 6pp because mine makes no mention of leaving open
spots for the fairing. Pity, as Drawing 43 clearly shows where I need to
mount the fairing.
No matter, as (sneak peak) the fairing will attach (dwg 43) with 509-8r8
screws into k1000-08 nutplates mounted to those locations. You will fit the
fairing to your assembled tail section and drill through the fairing (it is
somewhat translucent) through the VS or HS, deburr, and then mount the
nutplates. This is most easily accomplished by having NOT done anything
prior. So...
I would recommend you do nothing to those spots until instructed to do so in
the plans which I believe is the finish kit.
Vince H.
RV8 - Finish
