Grab-bar FW penetration
jonlaury(at)impulse.net
PostPosted: Wed Feb 22, 2006 12:12 am    Post subject: Grab-bar FW penetration Reply with quote
I think this was discussed in Vol 11 of the AC, but I loaned my copy to a friend.
Re the "grab bar" method, I recall that Bob said to fill the tube with firecaulk after all the wires were pulled. Now I see people are looking for the appropriate size firesleeve for their grab-bar conduit.
How does one use the firesleeve and get an air tight seal?
John
rv8ch
PostPosted: Wed Feb 22, 2006 1:48 am    Post subject: Grab-bar FW penetration Reply with quote
Hi John,
Here's how these guys recommend doing it. I'm planning
on doing the same thing on mine.
http://www.epm-avcorp.com/fwalinst.html
Here is my USD 30.00 "custom" towel bar:
http://www.rv8.ch/article.php?story=20060222102305941
Mickey
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
Mickey Coggins
http://www.rv8.ch/
nuckollsr(at)cox.net
PostPosted: Wed Feb 22, 2006 6:26 am    Post subject: Grab-bar FW penetration Reply with quote
friend.
No sealant inside the firesleeve . . .
See:
http://aeroelectric.com/articles/Firewall_Penetration/firewall.html
< with experiment. >
< --Lawrence M. Krauss >
PostPosted: Wed Feb 22, 2006 11:56 am    Post subject: Grab-bar FW penetration Reply with quote
Subject: Re: Grab-bar FW penetration
From: Robert L. Nuckolls, III (nuckollsr(at)cox.net)
Date: Wed Feb 22 - 6:26 AM
No sealant inside the firesleeve... So the last picture shows a piece of firesleeve wrapped around the wire bundle and the hose clamp "seals" it to the bundle? No sealant necessary?Next question: At Home Depot, there are 3-4 3M fire sealant/barrier caulks to chose from. Some are intumescentand some are not. Which one for FW's? I would guess that you don't want intumescent caulk expanding between FW layers during a fire. Mine is a composite firewall using Rohacell foam/glass sandwich for structure and Fiberfrax for fire protectionwith an aluminum sheet over the Fiberfrax for a wipeable surface.ThanksJohn
friend.
See:
Bruce(at)glasair.org
PostPosted: Wed Feb 22, 2006 3:19 pm    Post subject: Grab-bar FW penetration Reply with quote
John,
3M (CP-25) caulk is used around the firewall because the foam contracts when
heated so you want to use an intumescent calk here. Around the fire sleeve I
would not expect any shrinkage so a non intumescent calk would be my choice.
You might look at RTV-88.
Bruce
www.glasair.org
PostPosted: Wed Feb 22, 2006 6:20 pm    Post subject: Grab-bar FW penetration Reply with quote
to the bundle?
correct
that's what the 'big' guys do . . .
I've not researched their range of products and I'd
have to run them by my power plant guys at RAC. I think
others on the list have made suggestions about this . . .
PostPosted: Thu Feb 23, 2006 9:44 am    Post subject: Grab-bar FW penetration Reply with quote
Mickey, Bruce, and Bob,
Thanks all, for your help.
John
