Question for Bob or ?
s.hamer(at)verizon.net
PostPosted: Tue Feb 21, 2006 8:14 pm    Post subject: Question for Bob or ? Reply with quote
I've wired up my RV-6 per figure Z-11 (mostly) and when I turn on the master switch, I'm seeing 11.5 volts on my voltage gauge. If I add the E-Bus switch it goes to 12.1. With just the E-Bus switch on, my gauge shows zero volts. I have an external shunt in the position as shown in figure Z-12, between the alternator and the starter contactor. With the master switch off, I'm wondering how the gauge would get any juice?
With this limited information, can anyone tell me where I messed up or is this what I should be seeing? Just doesn't seem right.
Steve Hamer
Apple Valley, Ca.
nuckollsr(at)cox.net
PostPosted: Tue Feb 21, 2006 10:20 pm    Post subject: Question for Bob or ? Reply with quote
Okay, that's about right for an e-bus driven voltmeter seeing hte main
bus through the normal voltage drop in the bus isolation diode.
I would expect this . . . the switch is bypassing the diode
and the voltage jumps up about .5 volts.
You lost me. Z-11 suggests you wire the voltmeter to the e-bus
and the voltages you cite agree with what I'd expect for voltage
readings with the alternator off.
The shunt is for the ammeter which never reads anything until
the alternator is running and taking battery recharge and system
loads. When you say "my gauge shows zero volts" are you meaning
to say "zero amps"? The ammeter will be zero until the engine
is started and the alternator turned on.
< with experiment. >
< --Lawrence M. Krauss >
PostPosted: Wed Feb 22, 2006 6:58 am    Post subject: Question for Bob or ? Reply with quote
Bob,
My voltmeter is powered by the -buss. With just the e-bus switch on, I'm
reading zero volts and zero amps. The gauge still has power to it at that
time because the backlight is still on.
Steve
