Magneto P-leads
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Engines-List
dean.psiropoulos(at)veriz
PostPosted: Sun Nov 11, 2007 12:01 am    Post subject: Magneto P-leads Reply with quote
I did a test on my magneto P-leads (one mag on left side, electronic on
right side)with an ohm meter. Thinking that when the key switch is in the
off position, the resistance across the p-leads should measure close to dead
short and, it does. By the same logic, I thought that when the mag was
ungrounded the resistance across the p-leads (I used a shielded wire with
the shield grounded at the magneto through the key switch, no local
grounding). But when I measured across the p-leads at the magneto the
resistance only went from 0.2 ohms to 0.4 ohms when I turned the key. Not
an appreciable increase in resistance but it was consistent (happens every
time) and measurable. I thought maybe I had a faulty key switch but not so,
I removed one p-lead from the mag and made the same measurement and the
resistance with the key in that mag's position read infinite. I suspect
that there is some thing about magnetos I don't know and that this is not a
problem but would like to be sure. Anybody ever done this test? Did you get
the same results? Thanks.
Dean
RV-6A N197DM
closer to 1st flight.
- The Matronics Engines-List Email Forum -
http://www.matronics.com/Navigator?Engines-List
apilot2(at)gmail.com
PostPosted: Sun Nov 11, 2007 6:36 am    Post subject: Magneto P-leads Reply with quote
Was the P lead connected to the magneto when you measured resistance to ground? If so, and the points were closed, you were measuring resistance of the points. You need the P lead off the mag, or the points open to get a good resistance reading. I've seen a couple instances, (with old P-leads) of the internal insulation cracking and grounding to shield, but not too likely with relatively new wiring.
On Nov 11, 2007 12:59 AM, DEAN PSIROPOULOS <dean.psiropoulos(at)verizon.net (dean.psiropoulos(at)verizon.net)> wrote:
[quote] --> Engines-List message posted by: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net (dean.psiropoulos(at)verizon.net)>
glcasey
PostPosted: Mon Nov 12, 2007 5:32 am    Post subject: Magneto P-leads Reply with quote
Dean,
I'm a little confused about which resistance you are concerned about,
but here is what you can expect to measure: If the switch is
disconnected from the mag, a reading of the resistance from the P-
lead terminal to ground will be either (with the points closed)
essentially zero, or (with the points open) almost zero. The circuit
inside the mag is from ground through the primary ignition coil
winding to the points and back to ground. The P-lead is connected to
the connection between the coil and points. If the mag is rotated so
the points are closed only the point resistance is in the circuit,
which should measure as zero. When the mag is turned so the points
are open the only connection to ground is through the coil primary
winding, which will measure at something very low, but not zero. It
will probably be less than 1 ohm. I use this difference to set the
timing, eliminating the need for the "buzz box" that mechanics
normally use. You can, if you like, check the connected ignition
switch by turning the mag until the points are open (ignition switch
has to be in the "on" position to know this) and watching the
resistance of the P-lead to ground while turning the switch on and
off - there should be a small but noticeable change in resistance.
Oh, and when the switch is in the "R" position the right mag is on
(switch is open) and the left mag is off (shorted to ground).
Hope I didn't confuse things more.
Gary
Time: 12:01:57 AM PST US
From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net>
Subject: Magneto P-leads
electronic on
in the
close to dead
was
wire with
key. Not
(happens every
not so,
the
suspect
is not a
Did you get
Dean
RV-6A N197DM
Gary Casey
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Engines-List All times are GMT - 8 Hours
