rv10(at)sinkrate.com Guest
Posted: Sat Nov 10, 2007 11:11 pm Post subject: grounding question |
What are people doing for ground wires for the nav, landing, and pitot heat? Are you running separate wires for ground or grounding locally to the airframe? This might be somewhat of a “primer war” question as I’ve heard some say always run ground wires and others say ground locally. Aeroelectric says local ground for “non-noisy” items is fine. Just wondering what others have done.
If airframe what kind of hardware do you use to get a solid ground connection? Do you use regular AN nuts bolts and washers or do you use something like a lock washer that has more bite maybe? Do you cover the nut/bolt with anything to slow any corrosion being that you need to clean the primer off the metal at the point of contact?
Yes John I’ll wipe the dust off the 43.13 J
-Ben Westfall
#40579
n8zg(at)bellsouth.net Guest
Posted: Sun Nov 11, 2007 5:07 am Post subject: grounding question |
Ben -
I grounded lights and pitot heat locally by riveting a #8 nutplate to the spar web - one in each wingtip, one near the pitot mount. Socket-head cap screws and internal-tooth lock-washers secure the ring terminals. I didn't add any extra corrosion protection (I'll shoot it with CorrosionX after paint), but I do use a little anti-seize on all nutplates.
-Ben Westfall
#40579
DAVELEIKAM(at)wi.rr.com Guest
Posted: Sun Nov 11, 2007 5:23 am Post subject: grounding question |
I spoke to a fellow -10 builder who is an AP and was told to ground most things locally. Logic was that the structure is a very good conductor and "there is more of it." Also, less wire, less weight and less complexity. I only installed one ground so far for my Gretz pitot and used a nut plate and screw. The friend suggested this because of the locking function of the nut plate and solid mount. I have QB wings and they came primed with a wash primer. I just drilled the holes for the nut plate, deburred, and squeezed in some rivets. Continuity is good. I will probably coat with some ACF-50 or Boeshield after paint. I have an EAA tech counselor visit soon and will pose this question to him.
Only one person's opinion.
Dave Leikam
40496
About to close the left wing.
carl.froehlich(at)cox.net Guest
Posted: Sun Nov 11, 2007 6:29 am Post subject: grounding question |
In my RV-8A I ran a single #14 common ground wire to each wing, with an additional #14 ground wire for the pitot heat. My thought was to avoid mechanical problems associated with using the air frame for ground (getting a solid connection, hardware coming loose, dissimilar metal corrosion between the connector and the air frame, hard point vibration source, etc.). I plan on the same approach in my RV-10.
I also used a Molex plug on the wing wiring to allow for wing removal for paint. The plug is located in the wing root along with female and male BNC connectors for the wing tip antenna. After paint I put RTV on these connections as an additional means for preservation. The RTV is easy to peal off if I ever need to take a wing off again.
Carl Froehlich
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ben Westfall
Sent: Saturday, November 10, 2007 5:21 PM
Subject: grounding question
-Ben Westfall
#40579
| Quote: | | http://www.matronics.com/contribution | 012345678901234
egohr1
Joined: 17 Jan 2006 Posts: 38 Location: Oklahoma City
Posted: Sun Nov 11, 2007 6:29 am Post subject: Re: grounding question |
I have been using local grounding with brass nuts /bolts / and lock washers to minimize corrosion and give a better conductor than steel. The primer is removed under the lock washer to insure good contact.
sanding and wiring while waiting for the finishing kit.
_________________ eric gohr
EGOHR86@alumni.carnegiemellon.edu |
AV8ORJWC
Posted: Sun Nov 11, 2007 7:20 am Post subject: grounding question |
Nuckolls Book works for those with fear of reading the AC43.13. Surface contact area always wins over internal or external lock washers. They just retain the nut. Anti-Corrosion compounds can help as well.
At work, We use my beloved ProSeal on bonding strap attachments to keep environmental contamination to a minimum.
As an aircraft gets up to reaching my own age, corrosion on ground connections produce unique and challenging diagnostic opportunities.
John Cox
#40600
Sent: Saturday, November 10, 2007 2:21 PM
-Ben Westfall
#40579
[quote] [b]
AV8ORJWC
Posted: Sun Nov 11, 2007 8:17 am Post subject: grounding question |
As an alternative to the Funnies or Sports Page this AM. Here you are Ben. Don’t want allergies to flair up from the dust on your shelf.
John
#40600
-Ben Westfall
#40579
AC43.13_Electrical_Bonding.pdf |
99.3 KB |
979 Time(s) |
AV8ORJWC
Posted: Sun Nov 11, 2007 8:34 am Post subject: grounding question |
Answer #3 – Make an appropriately sized monetary contribution to Matt’s Matronics Annual Contribution List for November and receive a free copy of Bob Nuckolls Aero Electric in electronic form… then no dust is likely.
John
#40600
-Ben Westfall
#40579
[quote] [b]
Posted: Sun Nov 11, 2007 9:27 am Post subject: grounding question |
John my punches were inteded to be humerous… more as “beat you to your standard response” than anything.
I own the latest version 11 of Bob’s Aeroelectric Connection and have read it front to back 3 times in the last several months. Believe it or not my AC43.13 is quite tattered. Both were consulted prior to my emails. I like a healthy dose of information prior to actually making any decisions. My experiences in my 32 years of life have proven that book smarts don’t always align with reality so along with the reading and research that goes with all the build decisions (which at times seems like its more than actually building) I like to hear what others have done and will do. I take from those what I feel prudent.
Thanks for your responses they are always valued and welcomed.
-Ben
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John W. Cox
Sent: Sunday, November 11, 2007 8:30 AM
Subject: RE: grounding question
John
#40600
-Ben Westfall
#40579
MauleDriver(at)nc.rr.com Guest
Posted: Sun Nov 11, 2007 3:09 pm Post subject: grounding question |
I'm grounding locally to the airframe (wing tips, tail structure,etc)
per Aeroelectric recommendation. Will have ground bus for sensitive
equipment.
When grounding to the airframe, I referenced Tables 11-14 & 11-15 in
43.13. Very specific advice on grounding to aluminum airframe with
aluminum washers and lock washer application. It was my first use of 43.13.
I have no useful experience with the results in this area.
Bill Watson #40605
Ben Westfall wrote:
-Ben Westfall
#40579
ricksked(at)embarqmail.co Guest
Posted: Sun Nov 11, 2007 8:16 pm Post subject: grounding question |
Ben,
The grounding tabs that Stein sells seem to work quite well riveted to the structure with no paint between. The strobes I ground very close to the battery-airframe ground, the nav lights in the wings, landing lights and pitot heat I ground locally. Everything in the panel gets grounded to the firewall. The lights in the tail I run grounds back to the battery ground area. The headset jacks I do not ground, but use the fiber washers to keep them isolated from ground. Everything from the stick grip(s) I ground under the copilot seat, although most of those grounds are just grounding the switch so when it is pushed it connects that circuit to ground to tell the things to do it’s thing.
Jesse Saint
Saint Aviation, Inc.
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
-Ben Westfall
#40579
[quote] [b]
planesmith(at)hotmail.com Guest
Posted: Tue Nov 13, 2007 8:22 am Post subject: grounding question |
This echo what other have suggested. The plan is to locally grounding the noise producers with a nutplate arrangement removing the primer from under the electrical terminal. Insulating the head jacks with fiber washers and running all of the audio/radio grounds to a single point ground on the fire wall. My understanding this should eliminate the possibility of a ground loop noise. An exception to this is the strobe wire shielding which is grounded only back at the power unit not out at the wing tips, again I've read this helps with the ground loop issue.
Idea Industries makes an anticorrosion gel for aluminum to aluminum and copper to aluminum electrical connections. It is not an aircraft product, however I'm sure there is an equivalent aircraft approved material.
Vern Smith (#324 doors & top)
| Quote: | From: rv10(at)sinkrate.com
Subject: RV10-List: grounding question
Date: Sat, 10 Nov 2007 14:20:32 -0800
.ExternalClass EC_p.MsoNormal, .ExternalClass EC_li.MsoNormal, .ExternalClass EC_div.MsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass a:link, .ExternalClass EC_span.MsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited, .ExternalClass EC_span.MsoHyperlinkFollowed {color:purple;text-decoration:underline;} .ExternalClass EC_span.EmailStyle17 {font-family:Arial;color:windowtext;} (at)page Section1 {size:8.5in 11.0in;} .ExternalClass EC_div.Section1 {page:Section1;}
-Ben Westfall
#40579
get=_blank>http://www.matronics.com/Navigator?RV10-List
p://forums.matronics.com
| Help yourself to FREE treats served up daily at the Messenger Café. Stop by today! [quote][b]
Tim Olson
Posted: Tue Nov 13, 2007 8:50 am Post subject: grounding question |
One correction....
The items that you should feel comfortable locally grounding are
the NON-noise-producers. The noisy items you'll definitely
want to pull back to a central ground point. Things like
a pitot heater though are generally not noisy, so many builders
will do local grounds for nav lights, pitots, and things like that.
I'd recommend going CENTRAL ground for HID's and devices that
have any "frequency" to the power.
Vernon Smith wrote:
| Quote: | This echo what other have suggested. The plan is to locally grounding
material.
-Ben Westfall
#40579
by today!
<http://www.cafemessenger.com/info/info_sweetstuff2.html?ocid=TXT_TAGLM_OctWLtagline>
Posted: Tue Nov 13, 2007 2:18 pm Post subject: grounding question |
Thanks for catching that. Just another good reason to post and contribute.
Vern (#324)
> Date: Tue, 13 Nov 2007 10:49:31 -0600
| Quote: | From: Tim(at)MyRV10.com
Subject: Re: grounding question
--> RV10-List message posted by: Tim Olson <Tim(at)MyRV10.com>
One correction....
> material.
> To: rv10-list(at)matronics.com
> -Ben Westfall
> #40579
> by today!
Boo! Scare away worms, viruses and so much more! Try Winse/trial.aspx?s_cid=wl_hotmailnews' target='_new'>Try now! [quote][b]
Posted: Tue Nov 13, 2007 3:47 pm Post subject: grounding question |
Jesse,
Are you referring to the SA-9900 product from Stein on the accessories page when you say “grounding tabs”? http://www.steinair.com/accessories.htm
Thanks for you input!
-Ben
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint
Sent: Sunday, November 11, 2007 8:15 PM
Ben,
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
-Ben Westfall
#40579
Posted: Wed Nov 14, 2007 3:53 am Post subject: grounding question |
Yes.
Do not archive.
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
Sent: Tuesday, November 13, 2007 6:40 PM
Jesse,
-Ben
Ben,
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
-Ben Westfall
#40579
| Quote: | | http://www.matronics.com/Navigator?RV10-List |
