mprather(at)spro.net Guest
Posted: Fri Nov 02, 2007 2:51 pm Post subject: Final Review |
Going from 12V to 14V absolutely won't hurt the avionics. It also doesn't
sound to me like the operation should cause any significant inductive kick
which would lead to a high power voltage excursion.
Consider that with the bus loaded (at least on some systems), if the
engine is brought to idle RPM, the bus voltage may sag significantly below
14V. Increasing the RPM or reducing the bus load will increase the
voltage back to the regulator setup.
DO160 (the standard to which Avionics manufacturers should design their
products) allows for much larger swings than this..
Matt-
| Quote: | Bob, and all,
I have just completed a Velocity. She just passed the FAA cert and, I am
going thru the process once more of looking at all of my work and
hopefully
asking all the right questions.
I have built a Velocity XLRG. She has a 300 HP Lycoming IO-540. The
electrical design is my own with major influence from Bob Nuckols and this
list. Thanks for that. She has two equal batteries (Odessy 925) and a
single alternator (B&C 60 amp). One mag and one elec ign.
DC1 is direct wired into the main bus. DC2 is direct wired into the
Avionics/Essential bus. The battery contactors have separate pilot
controlled on/off switches. They share a common hot bus bar thru separate
schokey diodes. In normal ops I plan to have both battery contactors
closed
for start. Electrically the batt outputs will be isolated at this point.
I
have a 40 amp relay that is pilot controlled, to parallel the batteries
after the engine is started. I have a Garmin 480 GPS/NAV and a TruTrak
Digi
II VSGV and a GRT EFIS Horizon I to protect from starting circuit voltage
sags and surges.
Here is my question.
After start, when the engine is stable at idle power, I will close the
alternator field. This action will cause the main bus (through a 60 amp
current limiter) up to a nominal 14.2 volts. Then I plan to close a two
way
solid state "bus tie" relay which sits electrically between the two bus
terminal blocks. This will bring the Avionics-Ess bus to the same 14.2
volts and will serve as my DC2 charge wire path.
So is this 12 to 14.2 voltage boost going to hurt my avionics if they are
already on? Should I leave them off until I have tied the system
together?
The amp loading on either bus as this point in the checklist is going to
be
minimal.
Terry Miles
bobf(at)feldtman.com Guest
Posted: Fri Nov 02, 2007 4:24 pm Post subject: Final Review |
Simple question - why does anyone have their avionics "ON" when starting the engine, or the alternator for that matter - or when shutting down? Leave it all off til stable then turn on the avionics master. If you are worrying about unstable voltage with an air restart, you have bigger problems than whteher the EFIS comes back up quick (it does, seen the GRT do it in about 10 secs in a Cozy)
bobf
On 11/2/07, Terry Miles <terrence_miles(at)hotmail.com (terrence_miles(at)hotmail.com)> wrote:[quote] [quote] | Quote: | Bob, and all,
I have just completed a Velocity. She just passed the FAA cert and, I am going thru the process once more of looking at all of my work and hopefully asking all the right questions.
I have built a Velocity XLRG. She has a 300 HP Lycoming IO-540. The electrical design is my own with major influence from Bob Nuckols and this list. Thanks for that. She has two equal batteries (Odessy 925) and a single alternator (B&C 60 amp). One mag and one elec ign.
DC1 is direct wired into the main bus. DC2 is direct wired into the Avionics/Essential bus. The battery contactors have separate pilot controlled on/off switches. They share a common hot bus bar thru separate schokey diodes. In normal ops I plan to have both battery contactors closed for start. Electrically the batt outputs will be isolated at this point. I have a 40 amp relay that is pilot controlled, to parallel the batteries after the engine is started. I have a Garmin 480 GPS/NAV and a TruTrak Digi II VSGV and a GRT EFIS Horizon I to protect from starting circuit voltage sags and surges.
| 0123456789[b]
Gilles.Thesee(at)ac-greno Guest
Posted: Fri Nov 02, 2007 4:42 pm Post subject: Final Review |
Robert Feldtman a écrit :
| Quote: | Simple question - why does anyone have their avionics "ON" when starting the
Robert,
Some installation have an EFIS to monitor engine or system parameters :
voltage, RPM, oil pressure, temperatures, etc...
I would be reluctant to wait for the *voltage* to be stable before
having any indication of revolutions or oil pressure at engine start.
Switching everything down for starting or shutting the engine is an old
habit from sooo long ago.
| Quote: | whteher the EFIS comes back up quick (it does, seen the GRT do it in about
10 secs in a Cozy)
I've just spent two days flying an airplane with a moving map GPS. This
poorly engineered device kept resetting any time the voltage was
sagging, when maneuvering the flaps on the ground, for instance.
A real nuisance. BTW, 10 seconds seems a bit long in flight.
On the other hand the little Dynon, or the Enigma are rock stable
whatever the usual voltage variation....
Correctly designed aviation electronic devices are impervious to
ordinary voltage fluctuations.
Best regards,
Gilles
http://contrails.free.fr
Terry Watson
Joined: 09 Jan 2006 Posts: 290 Location: Seattle, WA USA
Posted: Fri Nov 02, 2007 5:33 pm Post subject: Final Review |
Gilles,
Can you tell us the make and model of the flakey EFIS, and a little more
about the circumstances?
Terry
Posted: Sun Nov 04, 2007 4:13 am Post subject: Final Review |
Terry Watson a écrit :
| Quote: | Can you tell us the make and model of the flakey EFIS, and a little more
Terry,
The instrument is some sort of Becker moving map about 6-7 years old.
Considering the behaviour, I did not try to determine the exact
denomination
Anytime the voltage sags, the unit reboots : for instance on the ground
with the engine idling, one must not move the electric wing flaps lest
the GPS reboot...
Also, the display is not really sunlight readable : we had to use a map
as a shade to accurately read the map. The associated Dynon is not much
better in this respect, BTW.
Best regards,
Gilles
