		| Author | Message |
		| rmfitz(at)direcway.com Guest
				|  Posted: Tue Feb 21, 2006 8:27 am    Post subject: Starting the -52 in cold weatherStarting the -52 in cold we |   |
				| A couple months ago I posted a question about "blubbering" after take-off.
There were many helpful suggestions both on and off-list,  thank you.
 I did find a bad plug but the problem persisted until, out of
 curiosity, I opened the manifold drain after priming (7 strokes) and was
 shocked by how much raw gas poured out.  Apparently gas was pooling in
 the manifold  and laying there during level run-up. Once a stable climb
 angle was established, at full power, it was sucked (or blown) into the
 bottom cylinders causing the temporary roughness.  I now prime, pull 4
 blades, and drain the manifold before starting.
 This is just theory at this point since it's winter and and I've only
 made a few flights but so far the problem appears to be solved.
 Now about that "eggcup" of gas it takes for a hydraulic lock;  are we
 talking parakeet or ostrich?
 bob
 52BN
 Rob Rowe wrote:
  	  | Quote: |  	  |
 Russian manual recommends 2-3 minutes in summer between priming & starting, rising to 3-4 minutes in winter due to lower fuel vapourisation rate.
 They also warn about over-priming as this "washes" oil off the cylinder walls & presents a hydraulic lock risk too ... it only needs an eggcup of liquid.
 If you've a manifold drain, leave it open during priming & you will be surprised as to how much fuel can pour out even with 6 or 7 cylinder primes.
 Rob R.
 http://forums.matronics.com/viewtopic.php?p=13718#13718
 | |  |  | - The Matronics Yak-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Yak-List
		| Back to top |  |
		| Rob Rowe
				|  Posted: Tue Feb 21, 2006 9:44 am    Post subject: Re: Starting the -52 in cold weatherStarting the -52 in col |   |
				| Bob wrote
  	  | Quote: |  	  | Now about that "eggcup" of gas it takes for a hydraulic lock; are we
 Good question!
 Confess the "egg cup" is apocryphal ... however my layman calculations suggest the following (I'm sure those more knowledgable will correct me);
 Engine capacity = 10.161 litres
 ... giving 10.161 / 9 cylinders = 1.129 litres per cylinder swept volume
 ... with a compression ratio of 6.3:1 (+/- 0.1)
 ... this allows 1.129 / 6.3 = 0.179 litres (179 ml) cylinder volume at TDC
 So 179 ml of fluid produces a full hydraullic lock ... even c.80 ml would double the compression to 12.6:1 ... so maybe two (chicken!) egg cups for a full lock and one to stress a plug core / seals etc.
 Bottom line ... not very much liquid!
 Rob R
		| Back to top |  |
