jindoguy(at)gmail.com Guest
Posted: Wed Oct 24, 2007 11:37 am Post subject: Ivo Props |
Anyone running a two blade Ivo prop on a 447. Do you run it with or without the spacer blocks? I have a brand new prop. When I unpacked it, I could tell by finger calibration that the blades were thinner than the spacers. I thought they would squeeze down when the prop bolts were torqued to 200 in. lb. per instruction sheet. Did the torque and there is still a .015/.020" (calibrated eyeball) gap between the plates and the blades. The holes in the blades are loose enough that the blades move, both in the plane of prop rotation and fore and aft.
When I called Ivo, the response was, "take out the spacers, they're just for looks". ??????
The only Ivo I have is a three blade that came on a 377 powered Minimax. Torques up just fine. I'm torn between following instructions from Ivo and putting them on the Bridgeport and milling them down. This aircraft is not mine, I'm just the delivery agent, and I'm not comfortable with either of these solutions.
Rick
ElleryWeld(at)aol.com Guest
Posted: Wed Oct 24, 2007 12:08 pm Post subject: Ivo Props |
if it wer mine I would Mill the spacer blocks down to match the blades thicknes
I had a 66" two blade IVO on a 447 for 600 hours with no problem and still going
But you can do what ever you want
Ellery in Maine Building MK3Xtra
Posted: Wed Oct 24, 2007 2:23 pm Post subject: Ivo Props |
1. The prop is brand spanking new, shipped from Ivo within the last month.
2. I flycut .018 off one side of each spacer to fix it.
Rick
On 10/24/07, ElleryWeld(at)aol.com (ElleryWeld(at)aol.com) <ElleryWeld(at)aol.com (ElleryWeld(at)aol.com)> wrote:[quote] if it wer mine I would Mill the spacer blocks down to match the blades thicknes
ez(at)embarqmail.com Guest
Posted: Wed Oct 24, 2007 2:28 pm Post subject: Ivo Props |
Please call IVO.Something isn't right. They probably sent you the wrong block set.
I surely would not run it that way.
Gene
On Oct 24, 2007, at 3:36 PM, Richard Girard wrote:
[quote]Anyone running a two blade Ivo prop on a 447. Do you run it with or without the spacer blocks? I have a brand new prop. When I unpacked it, I could tell by finger calibration that the blades were thinner than the spacers. I thought they would squeeze down when the prop bolts were torqued to 200 in. lb. per instruction sheet. Did the torque and there is still a .015/.020" (calibrated eyeball) gap between the plates and the blades. The holes in the blades are loose enough that the blades move, both in the plane of prop rotation and fore and aft.
Rick
| [b]
rowedenny(at)windstream.n Guest
Posted: Wed Oct 24, 2007 4:20 pm Post subject: Ivo Props |
Rick,
This story has cured me of any chance of ever buying another IVO prop, used to have one for the Loehle, but sold it before I had very much time on it.
Makes me wonder if your prop blades are the right thickness.
Their attitude is ridiculous.
Denny Rowe
beauford173(at)verizon.ne Guest
Richard:
I have a 2 blade on a 447...
The fact that IVO recommends (and sells) stainless steel tape pieces to stick across between
the blade base and the spacer block in order to detect slight blade movement in the hub (if tape breaks, the blade
has moved) is what is known in the intel business as an "indicator".... It appears to 'ol Beauford that, based on this,
the IVO folks consider blade shifting in the hub to be a significant and undesirable event. If I were you, I'd want
100% of that 200 in/lb. directly on the blade bases...
The rubber spacers may or may not be real players in this matter and I have often wondered about their role....
While assembling my prop, and noting the casual way they fit against the blade bases, it doesn't
surprise me that IVO says they are only ornamental.... just looking at my assembly, I personally don't
see how they do much to fix the blade base into the hub with any precision-- it looks to me like a blade
would really have to shift a lot before they would become a factor in restraining it.
I'd be inclined to go along with IVO advice and put all of the hub pressure (torque) on the blade bases... they
are structural...(I don't think the rubber spacers are).... and then mebbe try some torque seal between the hub and the
blade base to see what is moving and what is not...
Worth what ye paid fer it...
Beauford
FF076
Brandon FL
Posted: Wed Oct 24, 2007 5:34 pm Post subject: Ivo Props |
Gene, As I said, "When I called Ivo, the response was, "take out the spacers, they're just for looks"." So much for calling Ivo.
Once the Minimax is sold, I'll never have to deal with them again. I did go back and read the warning on the web site, apparently it's only applicable to engines with 3:1 gearboxes, so I probably could have gotten away with running without them, but now they're fixed.
Rick
Rick
[b] http://www.matronics.com/Navigator?Kolb-List http://forums.matronics.com [quote][b]
Posted: Wed Oct 24, 2007 5:42 pm Post subject: Ivo Props |
Denny, The blades are pressed in mold, the spacers are cast in a mold, too. So I doubt anything has changed, unless their plastic molding guy has let the mold go to hell. There's no evidence of that, the parting line looks clean, so I guess that's the way they've always been. Makes me appreciate the Warp Drive and the Powerfin all the more.
Rick
On 10/24/07, Richard Girard <jindoguy(at)gmail.com (jindoguy(at)gmail.com)> wrote:[quote]
Rick
Rick
[b] http://www.matronics.com/Navigator?Kolb-List http://forums.matronics.com [b]
herbgh
Posted: Wed Oct 24, 2007 6:31 pm Post subject: Ivo Props |
Rick and all
Brings to mind my little bout with Ivo props... Eveyone said that a three blade 60 inch ground adj IVO would work on my Firefly with the 447.. They were correct...A call to IVO cleared the matter up.. My blades were labeled 10+ at the base..Meaning that they were made with a minimum pitch below which I could not adjust for the 447.. I switched to blades that did not have the + and all was well..
IMHO---IVO blades are good for certain applications and likely bad for others.. I have never had a problem flying in front of them.. with and without the filler blocks..I use a three inch spacer.. As IVO said ...the spacers are just for looks... Herb
On Wed, 24 Oct 2007 20:42:23 -0500 "Richard Girard" <jindoguy(at)gmail.com (jindoguy(at)gmail.com)> writes:
[quote] Denny, The blades are pressed in mold, the spacers are cast in a mold, too. So I doubt anything has changed, unless their plastic molding guy has let the mold go to hell. There's no evidence of that, the parting line looks clean, so I guess that's the way they've always been. Makes me appreciate the Warp Drive and the Powerfin all the more.
Rick
Posted: Wed Oct 24, 2007 6:33 pm Post subject: Ivo Props |
jb92563
Joined: 23 Mar 2007 Posts: 314 Location: Southern California
Posted: Thu Oct 25, 2007 7:13 am Post subject: Re: Ivo Props |
Since we are talking about props, does anyone have experience with Power-Fin props?
I just wanted to hear some pro's and con's before I make a buying decision.
I'm looking for a 42" 2 blade prop with about 26 pitch ground adjustable.
Comments? Opinions?
_________________ Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
Do Not Archive |
Posted: Thu Oct 25, 2007 8:22 am Post subject: Ivo Props |
I have a 72" three bladed F model Powerfin. Between the IVO, Powerfin and
Warp Drive. Powerfin has the lowest mass, the highest thrust, but less
damage resistance than the Warp Drive. I don't how the IVO compares in
damage resistance. I had a 9/16 x 2.5 inch bolt go thru my Powerfin with
damage but it got me home from three hundred miles out. If a exhaust system
goes thru the prop only the Warp Drive will get you home. Anything larger
than an exhaust system will likely put an end to you flight but Powerfin
will break off before causing redrive/engine damage.
Note! Props are like religion, people defend their props very aggressively.
Putting on my flame retardant clothing.
Rick Neilsen
Redrive VW powered MKIIIC
d-m-hague(at)comcast.net Guest
Posted: Thu Oct 25, 2007 8:47 am Post subject: Ivo Props |
At 11:13 AM 10/25/2007, jb92563 wrote:
Power-Fin props?
Comments? Opinions?
As Rick Neilsen said, ditto on the damage resistance. You pay for the
lightweight construction. I knew a guy who had a Powerfin on his
MKIII. He was constantly getting damage from small stones thrown up by the
wheels. He would repair the damage and keep on flying... until one day the
prop exploded on takeoff at about 50' altitude. From where I was watching,
it looked like he made the classic mistake of not flying the plane first,
instead concentrating on shutting down the engine... and stalled and
pancaked it in from 50'. The plane was a total loss, he had serious back
injuries requiring lengthy hospitalization, and luckily his passenger (a
paying customer on his first "introductory lesson", he was a BFI and the
plane was an "ultralight trainer") wasn't hurt.
We picked up pieces of the prop all over the airport. It appeared that
there must have been some internal damage / delamination that was only
masked by the surface repairs and filling he did
Not the prop's fault, perhaps, I blame the repair, but still a delicate
prop for a pusher with the wheels in front.
I'm kinda glad I have a wooden prop on my Ultrastar.
Not sure Powerfin makes a 2 blade anyway. I have a 48" 2 blade wooden
adjustable from GSC on one of my PPG's, and that's definitely what I'd go
for again if I was in the market for an adjustable. Lighter than anything
but a Powerfin, and less cost than any other adjustable.
-Dana
But do you trust the _government_ with semi-automatic assault rifles?
Posted: Thu Oct 25, 2007 10:02 am Post subject: Ivo Props |
Ray, I have a four blade 70" Powerfin on my HKS powered trike. Ditto to all on the lack of damage resistance. I screwed up and left my bifocals hanging on the neck or my T-shirt. They slipped off and went through the prop. They were cheapy $5 Dollar General bifocals at that. Put a 1/4" divot in one blade and an 1/8" nick in another. Mighty expensive 2nd hour in the trike. I did a field repair to keep flying that evening, then grounded the ship until I got two new blades. I like it, but if you have a robust enough gearbox, i.e. "C" or "E", if we're talking Rotax, I'd go with a Warp Drive for damage resistance.
Rick
On 10/25/07, Dana Hague <d-m-hague(at)comcast.net (d-m-hague(at)comcast.net)> wrote:[quote]--> Kolb-List message posted by: Dana Hague < d-m-hague(at)comcast.net (d-m-hague(at)comcast.net)>
| Quote: | --> Kolb-List message posted by: "jb92563" <jb92563(at)yahoo.com (jb92563(at)yahoo.com)>
Power-Fin props?
Comments? Opinions?
-Dana
But do you trust the _government_ with semi-automatic assault rifles? [quote][b]
JetPilot
Posted: Thu Oct 25, 2007 10:01 pm Post subject: Re: Ivo Props |
On a trike we have a Rotax 447 and a 2 bladed powerfin. This prop is really nice on the 447, very quiet and smooth and lots of thrust. We considered a warp drive, but it is just to heavy for the B box on the 447. The hub assembly and the way it goes together is very nice, very simple and foolproof. A 447 does not have many parts to come off, so I'm not to worried about putting stuff through the prop. We do keep an extra blade just in case though, it was only a little extra, and if we pick up a rock we can have it flying again within half an hour
I have a 3 blade Warp Drive on my MK III with a 912 S. The 912-S has a is a lot more complicated, harder to catch everything in a preflight, and has a lot of stuff that can come off, and I would only want a strong warp drive on this engine.
As far as damage to the engine, consider this. If you have a weak prop on a plane, and you put something big through it, the prop will probably explode and OVERSPEED your engine like crazy. So to think you are protecting your engine from damage by having a weak prop that will break is just foolish. Chances are you will do far more damage to your engine from the overspeed than from an impact with a muffler or something similar if you have the strong warp drive prop. If the 447 could handle the weight of the warp, we would have put a warp drive prop on that engine..
Wooden props suck, they are very weak, even weaker and more prone to damage than the powerfin. We had a wood prop on the 447, it broke horribly with just a very slight impact by a strap bouncing off the tip, not catching, just bouncing off the tip The wood prop was also much louder and had worse performance than the powerfin. Wood comes loose at the hub, and changes balance with time. The powerfin is far better in every way than a wood prop. I would never ever buy any kind of wood prop.
Kolb MK-III Xtra, 912-S |
lucien
Joined: 03 Jun 2007 Posts: 721 Location: santa fe, NM
Posted: Fri Oct 26, 2007 5:08 am Post subject: Re: Ivo Props |
My .02 on the IVO,
First off, Do NOT run the IVO in 2 blades without the bumper blocks... do NOT ask my why I know this is extremely hazardous even with the bolts torqued down properly..... I'm surprised that IVO said this was ok. are you sure you dialed the correct number?
If you must run it without them, AT LEAST put the two bolts in and washer up the gap with large area AN washers.
NO, the assembly is NOT strong enough with only the blade roots securing the works, the hub must squish on something all the way around with all 6 bolts installed....
As for the Powerfin, I've run several different sizes on various planes along with the warp drive, IVO's and a couple different woodies. Generally, the Powerfin gives the best thrust, especially the F model, due to the somewhat higher blade area than the other props. But, also because of the larger blade area, it usually runs at a lower AOA than other thinner bladed props like the IVO and warp drive, so it doesn't work as well on a faster plane unless you add more pitch or reduce diameter.
On a slower plane like a trike with a single-surface wing, there's no better choice than the powerfin, IMO.
As for the warp drive, I'm now a complete warp drive believer. My FS II (or soon to be Bob's FS II) has a 68" warp drive on it and it's the best overall performer I've tried on the plane (I've tried the recommended 68" 3 blade F model powerfin on it and, while it had slightly better thrust than the warp, it unloads more at faster speeds than the warp does).
My titan has an IVO medium on it and it's ok. Not completely wonderful but not bad either.
As for the larger Kolbs running the 912, it sounds like the warp drive in at least 70" is the best compromise...
LS
_________________ LS
Titan II SS |
Posted: Fri Oct 26, 2007 5:21 am Post subject: Ivo Props |
Lucien, Unless someone at 1-800-367-7767 gets a charge out of answering the phone, "Ivo Prop", and somehow knew it was Ron I was going to be asking for, I'm pretty sure it was the right number.
Rick
On 10/26/07, lucien <lstavenhagen(at)hotmail.com (lstavenhagen(at)hotmail.com)> wrote:[quote] --> Kolb-List message posted by: "lucien" <lstavenhagen(at)hotmail.com (lstavenhagen(at)hotmail.com)>
My .02 on the IVO,
LS
LS
FS II
http://forums.matronics.com/viewtopic.php?p=141926#141926 [quote][b]
Posted: Fri Oct 26, 2007 5:32 am Post subject: Ivo Props |
I have most of my Kolb time with a 3 blade 65" Powerfin. The hub is
very well designed
and repitching is easy. Due to a suspected harmonic problem
attributable to the 3 cyl suzuki
I have switched to a backup 2 blade 70" Warpdrive. My impressions
for comparison
are of the apples to oranges variety because of the different size
and configuration.
The Powerfin has a wider high thrust blade but suffers with a drag
penalty and a narrower
speed range per pitch setting. The Warpdrive has less drag (free
horsepower) and
longer legs. I get more top end and still have great climb rpm.
Both are excellent props.
BTW, I stuck one of those Balance Masters contraptions behind the
prop and it seems to
alleviate a lot of the "rum-rum". Time will tell.
BB
lucien
Posted: Fri Oct 26, 2007 6:05 am Post subject: Re: Ivo Props |
| jindoguy(at)gmail.com wrote: | Lucien, Unless someone at 1-800-367-7767 gets a charge out of answering the phone, "Ivo Prop", and somehow knew it was Ron I was going to be asking for, I'm pretty sure it was the right number.
Rick
Well regardless of what they told you, the hub if run with 2 blades and no other support in the gaps WILL dramatically increase the likelihood of a very expensive and possibly dangerous accident.
Again, the hub secured only with 2 blade roots is NOT strong enough to hold together reliably under the normal conditions of usage in flight. Do NOT try to fix this by torquing the remaining bolts down more than 200 in/lbs, or by installing and torquing the other two bolts with no support in the gap!
Again, do NOT ask me why I know this, tho I will merely say that I've verified this danger first-hand!
You can correct this partially, like I said, with stacks of wide AN washers as thick as the gap secured by the other two bolts to the specified torque (200 in/lbs) as a field repair. But the overall strength of the hub is still compromised somewhat and it really shouldn't be run like that all the time.
The bumbers, though, do result in a fully secured hub with no worries and the prop works great thus properly assembled...
Caveat Emptor!
LS
Titan II SS |
Posted: Fri Oct 26, 2007 9:21 am Post subject: Ivo Props |
IVO users,
In my opinion Lucien is right about the risks involved in running an
IVO without the filler blocks installed.
Here is why I believe it is unsafe.
When the bolts are tightened the two bolts without the spacer blocks
will cause the aluminum faceplate to warp. This distortion of the
face plate compromises the "uniform" clamping pressure on the prop
blade root. As Lucien said this distortion can be prevented by
stacking washers of the same thickness as the blade root.
If you do decide to run a two blade IVO without the spacer blocks or
washers, do your lawyer a favor. Make certain you first get a signed
approval document from IVO .
Gene
On Oct 26, 2007, at 10:05 AM, lucien wrote:
> Rick
Caveat Emptor!
LS
LS
FS II
http://forums.matronics.com/viewtopic.php?p=141935#141935
