d_emond(at)mweb.co.za Guest
Posted: Sun Feb 19, 2006 7:26 am Post subject: Pumping Tires |
To those builders that are past the wheel fairing stage.
How easy is it to get access to the valve, and pump tires??
Dave Emond
# 40159
carl.froehlich(at)cox.net Guest
Posted: Sun Feb 19, 2006 9:34 am Post subject: Pumping Tires |
On my RV-8A I installed the spring loaded air valve door on the wheel pants (available at ACS).
Regardless of having this door or not, you need some sort of valve extensions to pump up the tires. I bought 4 standard metal tire valve extensions from Wal-Mart, and used lock tight to screw them together. Don't screw them together too tight or you will be leaking air when attached to the tire.
I painted a small white line on the tire sidewall such that when the white line pointed to the ground, the tire valve stem is lined up with the access door. Just screw in the now long valve extender through the door into the tire valve stem and you have it.
Carl Froehlich
RV-8A (250 hrs)
RV-10 (tail)
[quote] --
Posted: Sun Feb 19, 2006 5:58 pm Post subject: Pumping Tires |
Dave & Brenda Emond wrote:
Quote: | (at)page Section1 {size: 8.5in 11.0in; margin: 1.0in 77.95pt 1.0in 77.95pt; } P.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman" } LI.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman" } DIV.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman" } A:link { COLOR: blue; TEXT-DECORATION: underline } SPAN.MsoHyperlink { COLOR: blue; TEXT-DECORATION: underline } A:visited { COLOR: purple; TEXT-DECORATION: underline } SPAN.MsoHyperlinkFollowed { COLOR: purple; TEXT-DECORATION: underline } P.MsoPlainText { FONT-SIZE: 10pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Courier New" } LI.MsoPlainText { FONT-SIZE: 10pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Courier New" } DIV.MsoPlainText { FONT-SIZE: 10pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Courier New" } SPAN.EmailStyle18 { COLOR: navy; FONT-FAMILY: Arial } DIV.Section1 { page: Section1 } To those builders that are past the wheel fairing stage.
Dave Emond
# 40159
| If you have the 90 degree tire stem .... that sticks out parallel to the axle ...... all you have to do is get an extender at any good truck tire store. Drill a hole in the side of the wheel pant so you can thread the extender on the tire stem. Paint a white (or your favorite color) stripe vertically on the side of the tire so you can roll the airplane until the stripe is vertical ..... and the extender will screw right on.
The only downside is that the valve stem won't have a cover on it to keep dirt out.
Linn
Tim_Lewis(at)msm.umr.edu Guest
Posted: Sun Feb 19, 2006 9:56 pm Post subject: Pumping Tires |
The valve stems on my RV-10 mains point toward the axle nut, not
parallel to the axle. Poor geometry for servicing. Are other builders
seeing the same thing? Does anybody have insight into a tube part
number where the valve stem is parallel to the axle, like it is with the
RV-6?
Tim Lewis -- HEF (Manassas, VA)
RV-6A N47TD -- 830 hrs
RV-10 #40059 under construction
> Dave Emond
> # 40159
keep dirt out.
Linn
Posted: Mon Feb 20, 2006 1:09 pm Post subject: Pumping Tires |
Thanks for the replies.
Dave Emond
cjhukill(at)cox.net Guest
Posted: Tue Feb 21, 2006 7:49 am Post subject: pumping tires |
I also used the spring loaded doors and painted white line on my RV8, and bought a 5 inch valve core extension at a semi-truck supply house. HOWEVER, since I changed out my tubes to Desser Tire supplied (800 247-8473), Aero Class Leakguard inner tubes ($33 each), I have not had to add any air to either tire! That change was in Nov of 2003. They really work!
Chris Hukill
Installing aux fuel tank in QB fuselage
johnwcox(at)pacificnw.com Guest
Posted: Tue Feb 21, 2006 3:43 pm Post subject: pumping tires |
Hopefully, you all know the added advantages of (tank) nitrogen rather than compressed air for long term pressure and tube maintenance. Just a side note.
John - $00.02
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Hukill
Sent: Tuesday, February 21, 2006 8:01 AM
Subject: pumping tires
I also used the spring loaded doors and painted white line on my RV8, and bought a 5 inch valve core extension at a semi-truck supply house. HOWEVER, since I changed out my tubes to Desser Tire supplied (800 247-8473), Aero Class Leakguard inner tubes ($33 each), I have not had to add any air to either tire! That change was in Nov of [b]2003[/b]. They really work!
Chris Hukill
