shoskins(at)MCHSI.COM Guest
Posted: Sat Nov 03, 2007 2:38 pm Post subject: How small battery for the B&C BC320 starter? |
Greetings Aeroelectric list.
After 21 years of hand-propping my Continental O-200 I may finally install a starter because I will probably be installing a fuel injection system.
The thing I don't like is 10 pounds for the starter and another 25 lb. for the battery. What is the smallest battery I can likely get away with? It usually starts within a pull or two, so I don't think that I'll need a starter/battery combination strong enough to taxi the aircraft.
Thanks.
Sam Hoskins
Quickie Q-200
Murphysboro, IL
mwcreek(at)frontiernet.ne Guest
Posted: Sat Nov 03, 2007 3:19 pm Post subject: How small battery for the B&C BC320 starter? |
Sam,
The Odyssey PC680 Battery weighs 15 lbs and is used to start O-540’s in several planes I know of:
http://www.odysseybatteries.com/batteries.htm
You should be able to get by with something even smaller such as a PC545 at 12 lbs.
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Sam Hoskins
Sent: Saturday, November 03, 2007 3:35 PM
To: Aerolectric List
Subject: How small battery for the B&C BC320 starter?
Thanks.
Sam Hoskins
Quickie Q-200
Murphysboro, IL | Quote: | | http://www.matronics.com/contribution | 012345678901234
Posted: Sat Nov 03, 2007 3:37 pm Post subject: How small battery for the B&C BC320 starter? |
I forgot to mention - I do have high (9:1) compression pistons.
SRH
On 11/3/07, Sam Hoskins <shoskins(at)mchsi.com (shoskins(at)mchsi.com)> wrote:[quote]Greetings Aeroelectric list.
Thanks.
Sam Hoskins
Quickie Q-200
Murphysboro, IL
[quote][b] http://www.matronics.com/contribution http://www.matronics.com/Navigator?AeroElectric-List http://forums.matronics.com
www.MistakeProofing.net/blog/
618-967-0016 ph.
312-212-4086 fax [quote][b]
dstroud(at)storm.ca Guest
Posted: Sat Nov 03, 2007 4:53 pm Post subject: How small battery for the B&C BC320 starter? |
I start my Lyc 0-235C winter and summer with an $18 lawn garden tractor battery.
David Stroud Ottawa, Canada
C-FDWS Christavia
Fairchild 51 under construction
medorrisjr(at)hotmail.com Guest
Posted: Sat Nov 03, 2007 5:25 pm Post subject: How small battery for the B&C BC320 starter? |
Forgot??
Marvin
| Quote: | Date: Sat, 3 Nov 2007 18:34:52 -0500
Subject: Re: How small battery for the B&C BC320 starter?
SRH
On 11/3/07, Sam Hoskins <shoskins(at)mchsi.com (shoskins(at)mchsi.com)> wrote: | Quote: | Greetings Aeroelectric list.
Thanks.
Sam Hoskins
Quickie Q-200
Murphysboro, IL
| [/b] [quote][b]
Posted: Sun Nov 04, 2007 5:04 am Post subject: How small battery for the B&C BC320 starter? |
I found this article about Odyssey batteries, as used in boats. There is a lot of background on WHY the Odyssey is better.
http://www.swordfishingcentral.com/odyssey-batteries.html
Sam
On 11/3/07, Michel Creek <mwcreek(at)frontiernet.net (mwcreek(at)frontiernet.net)> wrote:[quote]
Sam,
The Odyssey PC680 Battery weighs 15 lbs and is used to start O-540's in several planes I know of:
From: owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com) [mailto:owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com)] On Behalf Of Sam Hoskins
Thanks.
Sam Hoskins
Quickie Q-200
Murphysboro, IL 012345
618-967-0016 ph.
Posted: Sun Nov 04, 2007 8:28 am Post subject: How small battery for the B&C BC320 starter? |
Thanks for the article, Sam. I hadn’t seen that article before; it is consistent with other reviews I’ve read before (don’t remember where).
Mike C.
Sent: Sunday, November 04, 2007 5:02 AM
Subject: Re: AeroElectric-List: How small battery for the B&C BC320 starter?
Sam
Peter H
Posted: Sun Nov 04, 2007 1:27 pm Post subject: How small battery for the B&C BC320 starter? |
Sam,
The subject came up earlier, when using electronic fuel injection there is a need to plan so that the endurance of the battery is at least half the endurance of the fuel, so that a failed alternator would not stop the fan away from a landing place. The electrical load for the fuel injection includes the load for the pump at least 8A total. The Odyssey batteries are designed to deliver a high current for big cranking start but endurance is better with some others formulated for lighting and IT back up. I chose an HGL 33-12 which is a major overkill for endurance over 4hrs and weight 24lb.
The very big HGL range is sealed glass matt low maintenance good endurance. The Odyssey has the big reputation for cranking in aviation.
Peter H
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Michel Creek
Sent: Sunday, 4 November 2007 9:13 AM
Subject: RE: AeroElectric-List: How small battery for the B&C BC320 starter?
Sam,
Thanks.
Sam Hoskins
Quickie Q-200
| Quote: | | http://www.matronics.com/Navigator?AeroElectric-List |
| Quote: | | http://forums.matronics.com | 01234567890123456
Posted: Sun Nov 04, 2007 2:02 pm Post subject: How small battery for the B&C BC320 starter? |
Good consideration, Peter. I think will be using two batteries and one alternator. I'll use my existing battery which was designed for my original endurance bus, then I'll add a second for cranking. I'll have to get busy and run some numbers.
Sam
On 11/4/07, Peter Harris <peterjfharris(at)bigpond.com (peterjfharris(at)bigpond.com)> wrote:[quote]
Sam,
Peter H
From: owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com) [mailto:owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com)] On Behalf Of Michel Creek
Sam,
Thanks.
Sam Hoskins
Quickie Q-200
618-967-0016 ph.
Peter H
Posted: Sun Nov 04, 2007 4:13 pm Post subject: How small battery for the B&C BC320 starter? |
Sam,
Bob has got a variety of circuits to suit almost every need with proper consideration for power and back up, if you check out the “Z files”.
Peter H.
Sent: Monday, 5 November 2007 7:59 AM
Sam
Sam,
Peter H
Sam,
Thanks.
Sam Hoskins
Quickie Q-200
| Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 012345678901
234567890123456789 | Quote: | | http://www.matronics.com/contribution | 0 | Quote: | | http://www.matronics.com/contribution | 1 | Quote: | | http://www.matronics.com/contribution | 2 | Quote: | | http://www.matronics.com/contribution | 3 | Quote: | | http://www.matronics.com/contribution | 4 | Quote: | | http://www.matronics.com/contribution | 5 | Quote: | | http://www.matronics.com/contribution | 6 | Quote: | | http://www.matronics.com/contribution | 7 | Quote: | | http://www.matronics.com/contribution | 8 | Quote: | | http://www.matronics.com/contribution | 90123
Posted: Sun Nov 04, 2007 5:06 pm Post subject: How small battery for the B&C BC320 starter? |
I know. My copy of the AeroElectronic connection is out at the hangar.
Sam,
Bob has got a variety of circuits to suit almost every need with proper consideration for power and back up, if you check out the "Z files".
Peter H.
From: owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com) [mailto: owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com)] On Behalf Of Sam Hoskins
Sam
Sam,
Peter H
Sam,
Thanks.
Sam Hoskins
Quickie Q-200
Murphysboro, IL 012345678901
23456
789012345678901234
618-967-0016 ph.
walter.fellows(at)gmail.c Guest
Posted: Sun Nov 04, 2007 5:19 pm Post subject: How small battery for the B&C BC320 starter? |
Wow, the website has a vicious set of pop-ups. This review seems to be to good to be true, is this one brand of battery really so superior?
Sam,
Peter H.
Sam
Sam,
Peter H
Sam,
Thanks.
Sam Hoskins
Quickie Q-200
23456789012345678901234
[quote][b] http://www.matronics.com/contribution http://www.matronics.com/Navigator?AeroElectric-List http://forums.matronics.com [quote][b]
klehman(at)albedo.net Guest
Posted: Sun Nov 04, 2007 6:21 pm Post subject: How small battery for the B&C BC320 starter? |
The TYPE is superior but there are other equivalent units to the Odysey
IMO such as the Dekka series by East Penn Mfg.
Even the 15AH one in my $30. Chinese automobile booster has survived
much more abuse than I expected. I've even run a 1 kw inverter off it
for power at the airport.
Ken
Walter Fellows wrote:
| Quote: | Wow, the website has a vicious set of pop-ups. This review seems to be
