Trim troubles
speckter(at)comcast.net
PostPosted: Tue Oct 30, 2007 5:34 am    Post subject: Trim troubles Reply with quote
I have hooked up my MAC trim system for the first time. I have a hat switch
trim control on the stick and switches on the subpanel that duplicate the
hat switch. I am using the new relays from MAC.
The problem is that while the switches on the panel work, the hat switch
does not work. It activates the appropriate relay when it should but no
power goes to the servo. I am stumped as to where to look for the problem
as obviously I have the relay to servo correct, and the panel switch to
relay correct. Since the hat switch activates the relay, where is the
problem?
Any suggestions.
Gary
40274
bhughes(at)qnsi.net
PostPosted: Tue Oct 30, 2007 6:03 am    Post subject: Trim troubles Reply with quote
Gary,
Make sue the two diodes are in the proper location and orientation. Both
the rocker switch and hat switch should provide a ground to the relay
deck. I am assuming you are using Ray Allen's products and the RS2
Rocker \ RAC grip.
Bobby
40116
Tim Olson
How are the stick switches wired? One wire from the pair usually
goes to ground, and the other goes to the relay, so you're
grounding the input to activate it.
problem?
Any suggestions.
Gary
40274
PostPosted: Tue Oct 30, 2007 12:47 pm    Post subject: Trim troubles Reply with quote
I think I have it wired that way, the relay clicks when I activate the stick
but the servo won't move unless I press the panel switch. Both switches
activate the relay though.
Gary
40274
rcnewman(at)mycingular.bl
PostPosted: Tue Oct 30, 2007 1:11 pm    Post subject: Trim troubles Reply with quote
One possibility with a system envolving relays is that when you are pressing a stick button, actuallly two relays are activating and this would apply effectively no voltage to the servo. You may want to listen to all the relays with a straw to hear which ones are actually be activated.
-Bob Newman
Tcw Technologies
Sent via BlackBerry by AT&T
dmasys(at)cox.net
PostPosted: Wed Oct 31, 2007 5:22 pm    Post subject: Trim troubles Reply with quote
Time: 01:47:17 PM PST US
Subject: RE: Trim troubles
Gary
40274
If those panel mounted switches are the rocker switches supplied by Ray Allen, the problem is that if you look closely at the schematic for those switches, they ground both sides of the SPDT circuit when the rocker is in the neutral position. This is supposed to reduce the amount of trim motor run-on, but it perfectly skunks the possibility of having a separate switch in parallel (ie., the one on the coolie hat) to work the flaps or trim circuit.
This little "feature" of the rocker switches caused me to have to re-cut the right side panel to get rid of the rectangular hole for the Ray Allen switch, and put in a standard SPDT spring loaded switch for the panel mount location.
-Dan Masys
RV-10 N104LD flying - 75 hrs.
Tim Olson
PostPosted: Wed Oct 31, 2007 6:50 pm    Post subject: Trim troubles Reply with quote
I don't think it negates all possibilities....with both the relay
system, and the Safety-Trim system, I had a panel mounted Elevator
switch (Ray Allen Type), and 2 stick switches, and all 3 switches
worked fine. You just have to piece together the proper diagrams
from Ray Allen and then it all works together. I know someone
mentioned diodes already, and I think I had a pair in my install
too, but I haven't taken the time to re-think how I put that all
together....but I do know it works.
> From: "gary" <speckter(at)comcast.net>
> Gary
> 40274
-Dan Masys
PostPosted: Thu Nov 01, 2007 8:33 am    Post subject: Trim troubles Reply with quote
I solved the problem. The diodes that are installed to isolate the switches
on the panel from the relay were the issue. I also hooked the stick
switches up to the diodes but it won't work that way, switched it around and
all is well. Ray Allen is not sure why it won't work that way but they said
to try switching it and see if it works.
Gary 40274
Installing windshield
wcurtis(at)nerv10.com
PostPosted: Thu Nov 01, 2007 10:18 am    Post subject: Trim troubles Reply with quote
I just happen to be going over my pitch trim wiring and came to the same conclusion. That is; if you will be installing a relay deck, replacing the provided DPDT rocker switch with a momentary SPDT switch, simplifies the wiring greatly. I built my own relay deck and incorporated a simple two-speed (Normal/Cruise) switch. The switch places or removes a resister in the power path to the servo motor.
http://wcurtis.nerv10.com/90Electrical/RV10PitchTrim.pdf
William
RV10PitchTrim.pdf
 Filename:  RV10PitchTrim.pdf
 Filesize:  17.18 KB
 Downloaded:  495 Time(s)
acs(at)acspropeller.com.a
PostPosted: Thu Nov 01, 2007 12:25 pm    Post subject: Trim troubles Reply with quote
William, doesn't the DPDT switch takes the place of the need to have two
SPDT switches on the panel, i.e one way for forward trim and the other for
aft trim?
The SPDT switches on the pilot and co-pilot sticks each look after forward
trim or aft trim individually. I would have thought the intention would be
to have all three switches operating exactly the same, the only difference
being a fore and aft option in one convenient switch on the panel.
John 40315
PostPosted: Thu Nov 01, 2007 1:19 pm    Post subject: Trim troubles Reply with quote
The caveat was IF YOU WILL BE USING A RELAY DECK. Without the relay deck, yes you would need two SPDT switches. The momentary switches in the pilot stick are SPDT. Replacing the DPDT (center off) panel rocker switch with a momentary SPDT makes all switches the same. Your panel switch will just be another switch like the ones in the stick.
William
pitts_pilot(at)bellsouth.
PostPosted: Thu Nov 01, 2007 1:42 pm    Post subject: Trim troubles Reply with quote
Why are there flap switches on the stick AND the panel???
Linn
William Curtis wrote:
[quote] [quote]--> RV10-List message posted by: "William Curtis" <wcurtis(at)nerv10.com> (wcurtis(at)nerv10.com) The caveat was IF YOU WILL BE USING A RELAY DECK. Without the relay deck, yes you would need two SPDT switches. The momentary switches in the pilot stick are SPDT. Replacing the DPDT (center off) panel rocker switch with a momentary SPDT makes all switches the same. Your panel switch will just be another switch like the ones in the stick. William http://wcurtis.nerv10.com/ ------
Tim Olson
PostPosted: Thu Nov 01, 2007 1:48 pm    Post subject: Trim troubles Reply with quote
Yes, but with a relay deck you can use the original panel switch, and
2 regular sticks switches like the infinity grips use, and use
them all together with no problem. Same with Bob's trim system.
One question William...your pilot/co-pilot switch....when you flip
yours, you disable the pilot if it's on co-pilot. Don't you want
the pilot to always have control, and just have the co-pilot only
be dis-connectable?
stick.
sam(at)fr8dog.net
PostPosted: Thu Nov 01, 2007 1:51 pm    Post subject: Trim troubles Reply with quote
Do you remember the value of the resistor? I would like to slow my trim in cruise as well, this looks like an inexpensive solution.
Sam
William Curtis wrote: [quote] [quote]I just happen to be going over my pitch trim wiring and came to the same conclusion. That is; if you will be installing a relay deck, replacing the provided DPDT rocker switch with a momentary SPDT switch, simplifies the wiring greatly. I built my own relay deck and incorporated a simple two-speed (Normal/Cruise) switch. The switch places or removes a resister in the power path to the servo motor. http://wcurtis.nerv10.com/90Electrical/RV10PitchTrim.pdf William http://wcurtis.nerv10.com/ ------
rnewman(at)tcwtech.com
PostPosted: Thu Nov 01, 2007 2:08 pm    Post subject: Trim troubles Reply with quote
Fellow listers,
Thru this recent thread regarding a trim switch/relay problem I've
offered some troubleshooting ideas to help solve the current issue at hand
and have not brought up any of my commercial interests regarding
Safety-Trim. Now that it seems to be sorted out and the root cause was
determined to be an issue with diodes and the Ray Allen trim switch I'm
inclined to chime in. I realize different folks want different levels of
complexity in the aircraft and I fully support that. As a fellow RV-10
builder and a Glastar builder I have enjoy making the decisions how my
airplane will operate and how complex or not it would be.
I'd just like to make you all aware that one of the benifits of the
Safety-Trim electronic servo controller is that the switch wiring required
to accomplish multiples points of control is greatly simplified over that
traditionally done with a series of relay decks. All of the switches
used in a Safety-Trim system only need to be SPST for each function, each
is just a simple closure to ground. Safety-Trim handles any comflicts
between the pilot and the co-pilot and/or a panel mounted switch asking for
different directions. This benefit is in addition to that of the
run-away prevention technology and 2 speed preset functions also found in
our controller.
For all the details and to see our instruction manuals, please visit
www.tcwtech.com
Thank you,
Bob Newman
RV-10 #40176
N541RV
PostPosted: Thu Nov 01, 2007 4:42 pm    Post subject: Trim troubles Reply with quote
Flap switches? Where do see a mention of flap switches?
William
PostPosted: Thu Nov 01, 2007 4:55 pm    Post subject: Trim troubles Reply with quote
Right now it is variable. Until I'm flying I won't have a specific value for the resistor.
William
Tim Olson
PostPosted: Thu Nov 01, 2007 5:26 pm    Post subject: Trim troubles Reply with quote
Tonight I went about the task of hooking up my rudder trim. Last
week when I finished the Safety-Trim I didn't know 100% that I'd
be adding rudder trim. I just plunged in after I finished
that project. So tonight I finalized the wiring and tomorrow the
entire job will be done.
To do the rudder trim, I decided to run that trim servo through
Bob's controller, instead of aileron trim. I think the elevator
is the axis in desperate need of speed control, but I think the
rudder would be likely to get the 2nd vote, just because you
want to fine tune it so much. Aileron trim I believe would
not benefit from speed reduction. So, I removed the aileron trim
from the Safety-Trim controller. Very easy since it's just 4 wires.
Then, I wired in my rudder trim in it's place. But, I wanted the
stick hat switches to run the aileron trim as before, so those
went to that system instead. I used the standard Ray Allen
switch for the Rudder Trim switch using Bob's box.
That brought me back to the old days of wiring the switches and
how I accomplished it. I believe with relays, I used diodes
on that switch. On Bob's box it's simplified beyond that.
What you do is to hook the RED wire to ground, and that switches
that line to either side of the switch to ground the system
and drive the controller. I think this is what I did on the
panel mounted elevator switch, but I used diodes because the
relay system required it. Using Bob's controller though,
even though those 2 white wires tie together in the neutral
(non-activated) position, it causes no problem with the trim
controller, so it was Red wire to ground, and a white to each
of the 2 wires for rudder trim input. Then it was just a matter
of the 2 wires to the servo, and done.
So anyway, it was a quick job tonight, but now all 3 axis are
trimmable, with the aileron and elevator on the stick (elev.
on the panel too), and the rudder on the panel only.
Can't wait to give it a couple thousand miles of testing
next week.
Bob-tcw wrote:
Fellow listers,
hand and have not brought up any of my commercial interests regarding
levels of complexity in the aircraft and I fully support that. As a
fellow RV-10 builder and a Glastar builder I have enjoy making the
decisions how my airplane will operate and how complex or not it would be.
required to accomplish multiples points of control is greatly simplified
over that traditionally done with a series of relay decks. All of
the switches used in a Safety-Trim system only need to be SPST for each
function, each is just a simple closure to ground. Safety-Trim
handles any comflicts between the pilot and the co-pilot and/or a panel
mounted switch asking for different directions. This benefit is in
addition to that of the run-away prevention technology and 2 speed
preset functions also found in our controller.
www.tcwtech.com
Thank you,
Bob Newman
RV-10 #40176
N541RV
PostPosted: Thu Nov 01, 2007 5:34 pm    Post subject: Trim troubles Reply with quote
Yeah, you got me there!!! Sad . It does say 'trim troubles' doesn't it???
Some folks really do read my drivel!!!
OK, now back to the question:
Why are there TRIM switches on the stick AND the panel???
Linn
[quote] [quote]--> RV10-List message posted by: "William Curtis" <wcurtis(at)nerv10.com> (wcurtis(at)nerv10.com) Flap switches? Where do see a mention of flap switches? William http://wcurtis.nerv10.com/ ------
PostPosted: Fri Nov 02, 2007 4:15 am    Post subject: Trim troubles Reply with quote
It seems to me that the two problems with the stock RV10 trim that Tim
outlines should be able to be solved with less expense than a whole new
system (no offence Tim). The resister that William Curtis suggested solves
one of them (speed), can anyone of you electronics guys design a time out
circuit that we could build and add to our Ray Allen system?
William, what value of resister are you starting with to test the system?
Gary
40274
