dvanlanen
Posted: Fri Oct 26, 2007 10:42 am Post subject: 601XL - Question Re. Mating Of Elevator To Stabilizer (Piano |
I’m almost ready to fit the elevator to the piano hinge, which is already drilled / clecoed to the stabilizer. Once positioned, has anyone found a good way of “stablizing” the assembly to prevent movement while drilling and clecoing?
Dave Van Lanen
Madison, WI
601XL - Elevator [quote][b]
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Fri Oct 26, 2007 3:54 pm Post subject: Re: 601XL - Question Re. Mating Of Elevator To Stabilizer (P |
As I recall, I fit the two together on a table and after satisfying myself with the position of the hinge I used side clamps to attach the undrilled side in place and then pulled the pin out to separate the hinge halves. I then drilled the hinge starting in the middle and working towards the ends, clecoing as I went. When finished I chose to store the elevator and horiz. stab separately so I just slipped the pin back in one side of the hinge.
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
Tim Juhl
Posted: Sun Oct 28, 2007 2:50 pm Post subject: Re: 601XL - Question Re. Mating Of Elevator To Stabilizer (P |
To anyone following this thread, I gave Dave bad advice. Once I went out to the shop and looked at the elev / stab I realized that side clamps could not be used in that situation. Dave and I have since communicated about it but as I now recall I used tape strips to hold the hinge in place once the proper location was established.
Next time I'll be sure before I open my big mouth and give advice.
Do not Archive
CFII
Champ L16A flying
