Fox5flyer Guest
Posted: Sun Oct 28, 2007 11:16 am Post subject: Bending Lexan (polycarbonate) |
Lynn, I'm not sure why he's asking either, but Lexan bends easily in brake.
Depends on what you want to use it for.
Lots of folks use a piece of bent Lexan for a trim tab.
Deke
S5
Northeast MI
Lynn Matteson
Posted: Sun Oct 28, 2007 11:35 am Post subject: Bending Lexan (polycarbonate) |
Hmmmm...ok, I learn something new every day.
Lynn Matteson
flying w/420+ hrs
On Oct 28, 2007, at 4:13 PM, fox5flyer wrote:
<fox5flyer(at)idealwifi.net>
in brake. Depends on what you want to use it for.
Deke
S5
Northeast MI
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Float Flyr
Posted: Sun Oct 28, 2007 4:43 pm Post subject: Bending Lexan (polycarbonate) |
I used a piece of mild aluminium (non-aviation grade) for a rudder trim tab.
The soft aluminium allows me to make corrections to the tab on the ground.
That reminds me when I install the 912 I'll have to reverse that tab.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
dave
Posted: Sun Oct 28, 2007 4:44 pm Post subject: Re: Bending Lexan (polycarbonate) |
Deke,
The reason is Lynn asked in the first place or am I confused here ?
I have bent plenty of lexan but still got alum Turtledeck here .
Dave
Deke
S5
Northeast MI
| Quote: | Michel-
The cost from here (USA) would be prohibitively expensive, but LP
Aeroplastics sells, (and maybe John McBean does too), a domed
turtledeck that resists flexing. Alas, you cannot bend the 'deck for
storage, but on the other hand it doesn't leak water in the rain
either. It (the 'deck) will fit into my cabin if I have to take it
off for some reason...trailering, etc...but just barely.
Lynn Matteson
flying w/420+ hrs
On Oct 28, 2007, at 5:54 AM, Michel Verheughe wrote: |
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Fox5flyer Guest
Posted: Sun Oct 28, 2007 5:30 pm Post subject: Bending Lexan (polycarbonate) |
No, it's probably me that is confused, or perhaps we all are.
Agreed, Lexan bends nicely in a brake. Someone said something about heating
the Lexan first, but I don't think that works very well.
Deke
S5
NE MI
Lynn Matteson
Posted: Mon Oct 29, 2007 2:50 am Post subject: Bending Lexan (polycarbonate) |
I used an aluminum tab as well, Noel, but I'd still like to make it
cabin adjustable. I'd like to make it an electrical servo-operated,
like my elevator trim, but don't want to have to strip the fabric to
do so. I could use a sheathed cable, but haven't really sorted it all
out yet.
Lynn Matteson
flying w/420+ hrs
On Oct 28, 2007, at 8:42 PM, Noel Loveys wrote:
trim tab.
ground.
Noel
N369LM |
Lynn Matteson
Posted: Mon Oct 29, 2007 3:07 am Post subject: Bending Lexan (polycarbonate) |
I think you're confused, Dave. Maybe I started the confusion by
telling Michel that he could get a domed turtledeck that resists
flexing. I should have said that this is just a replacement "window"
to be installed into the aluminum frame that we get from Kitfox. This
does away with the hinge...which doesn't really do much, except leak
water...and stiffens the whole t'deck. I know there are some
aftermarket turtledecks out there that are made entirely from some
kind of plastic, but I haven't seen them in person, nor do I know how
well they work/look.
Lynn Matteson
flying w/420+ hrs
On Oct 28, 2007, at 8:44 PM, dave wrote:
Deke,
Dave
in brake.
Deke
S5
Northeast MI
> Michel-
> Lynn Matteson
> Kitfox IV Speedster w/Jabiru 2200
> flying w/420+ hrs
N369LM |
dave
Posted: Mon Oct 29, 2007 3:18 am Post subject: Re: Bending Lexan (polycarbonate) |
Lynn, I think that is likely the case. I was thinking that you might have meant those one piece plastic Turlte decks. And if so I was suggesting that one could be made from bending some lexan in a brake. And I never mentioned heating although you can heat Lexan to help stress relieve it but you have to be careful. Best think on Lexan after cutting is to smooth out the edges or it is likely that cracks can propagate from en-even edges.
Gotta run --s/b light soon and want to get a flight in 28F here today
Dave
| Quote: | Posted: Mon Oct 29, 2007 7:07 am Post subject: Bending Lexan (polycarbonate)
