Fuel Vent lines
speed3guy(at)comcast.net
PostPosted: Fri Oct 26, 2007 4:34 am    Post subject: Fuel Vent lines Reply with quote
Bill,
On my pre-punched RV-8a the plans call for a 45 degree bulkhead fitting in the hole in the landing gear weldment. The fitting goes in from the bottom with the nut up at the weldment. Orient the 45 degree fitting so that it aims down the gear leg.
Guy
From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of japhillipsga(at)aol.com
Sent: Wednesday, October 24, 2007 11:51 AM
To: rv8-list(at)matronics.com
Subject: Re: RV8-List Fuel Vent lines
Rv-8 fellows, I'm working on my plumbing, fuel and brake. The plans shows the end of the vent tubing out the floor and bent forward. Is there a particular important reason why the drip end is pointed forward as opposed to to the rear ? I think I saw a couple RVs at Sun n Fun with the tubes rearward. Second question: The plans shows the brake lines going to the landing gear weldment and exit down at the leg. What have you all done in the past ? Make a separate hole in the floor near the weldment that you can snap in a plastic sleeve for friction protection or enlarge the gear hole and run it out against the steel leg ? Thanks ahead of time and best regards, Bill of Georgia
[quote] [b]
JAPhillipsGA(at)aol.com
PostPosted: Sat Oct 27, 2007 8:38 pm    Post subject: Fuel Vent lines Reply with quote
Thanks for the help, Bill
