michaega(at)verizon.net Guest
Posted: Sat Oct 27, 2007 10:27 am Post subject: new 912uls for sale with prop |
have an 912uls up for sale that has near everthing you need for the kitfox setup. Only a couple items keeping but you may find through this Kitfox list.
I believe the Rotax 912uls was built in Mid 2005 (still checking exact date) new and has never been started. When I bought the complete Kitfox 7 kit there was with very little work completed. Two items not included with the sale are the oil tank and radiator.
Included is a complete 912uls, carb heat air intake box, drip pans for carbs, rectifier,
electrical component and high performance exhaust system, Rotax engine ring mount, throttle cable with split feeds to each carb, choke cable split feeds and other odd and ends that I may find. Also a new 70" carbon fiber 3 blade warp drive prop with optional 2" prop spacer, aluminum spinner and backing plate and the protractor to adjust blade angles.
Sell all for13,500
George
graeme(at)coletoolcentre. Guest
Posted: Sun Oct 28, 2007 1:07 am Post subject: new 912uls for sale with prop |
George
Where are you in Australia USA
Some idea of location would be goog.
Graemecns
