by0ung(at)brigham.net Guest
Posted: Thu Oct 25, 2007 7:35 pm Post subject: re patching pin holes in fabric |
Any suggestions for the best way to patch small (1/8" max dia.) pinholes in
Polyfiber fabric? I have a couple on the underside of my fuselage just aft
of the nose cone.
Jimmy Young
FS II, N7043P
| Quote: | >>>>>>>>>>>>>>>>>>>>>>
If it is painted with polly tone,,,, Cut some small circles 1 1/2 inches in
diameter with pinking sheers,,,, paint them on with polly brush,,,, iron
the patches smooth, then cover in silver then top coat.
Just thinking out loud..... if you can get to the 1/8 inch hole from the
inside.... put the patch on the inside and you may not have to do all the
painting. It should stabilize the fabric and stop it from running...
Different paint,,,, then follow directions for your finish.
Boyd young
