Dennis.Kirby(at)kirtland. Guest
Posted: Fri Oct 26, 2007 1:28 pm Post subject: Powerfin Props |
Richard Neilsen wrote: << Powerfin has the lowest mass, the highest
thrust, but less damage resistance than the Warp Drive. ... I had a 9/16
x 2.5 inch bolt go thru my Powerfin with damage but it got me home from
three hundred miles out. >>
I hafta agree with Rick N. on the Powerfin.
I also run a 3-blade, 72 inch Powerfin behind my 912ul.
Although I enjoy the performance its wide blades provide, and its ease
of adjustment, it is not as robust as a Warp.
I had the oil cap go thru the prop (my fault - failed to ensure it was
secure before flying). Put a big enough gash in the leading edge to as
render that blade unusable. Had to spring $140 for a new blade.
Dennis Kirby
Mark-III, 912ul, in
Cedar Crest, NM
