Gear Legs tire changing
kahuna
PostPosted: Mon Oct 22, 2007 11:24 am    Post subject: Gear Legs tire changing Reply with quote
Dont all RV's have a platenet on the axel nut to hold the wheel pant
bracket?
I dont see how a hollow axel nut to take the pipe will work if you have to
mount the wheel pant bracket to the axel nut.
"Tim Bryan"
<n616tb(at)btsapps.c
om> To
Sent by: <rv-list(at)matronics.com>
owner-rv-list-ser cc
ver(at)matronics.com
Subject
RE: Gear Legs
10/22/2007 01:29
PM
Please respond to
.com
Greg,
There is an excellent tool from Avery just for this purpose. I use it and
love it. You end up drilling a hole in the center of the wheel nut and
installing a bracket over it to replace the rivenut for the wheel pants
n616tb(at)btsapps.com
PostPosted: Mon Oct 22, 2007 11:37 am    Post subject: Gear Legs tire changing Reply with quote
Mike,
Check out the last link in my message below. It has a picture of the little bracket that goes over the hole in the axle nut. This little bracket has the platenut on it for the wheel pant.
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Michael W Stewart
Sent: Monday, October 22, 2007 2:22 PM
To: rv-list(at)matronics.com
Subject: RE: Gear Legs tire changing
Dont all RV's have a platenet on the axel nut to hold the wheel pant bracket?
I dont see how a hollow axel nut to take the pipe will work if you have to mount the wheel pant bracket to the axel nut.
"Tim Bryan" <n616tb(at)btsapps.com>
Sent by: owner-rv-list-server(at)matronics.com
10/22/2007 01:29 PM
Please respond to
To
cc
Subject
RE: Gear Legs
Greg,
There is an excellent tool from Avery just for this purpose. I use it and love it. You end up drilling a hole in the center of the wheel nut and installing a bracket over it to replace the rivenut for the wheel pants. It is an easy conversion, an inexpensive jack jig, and makes lifting a wheel and removing it quite safe and easy. Check it out here.
http://www.averytools.com/p-181-rv-jack-stand.aspx
I see they have the already modified axle nuts as well.
http://www.averytools.com/p-179-modified-rv-axle-nuts-for-rv-jack-stand.aspx
Here are the brackets for wheel pant connection
http://www.averytools.com/p-180-rv-jack-stand-kit-bracket-kit.aspx
You can purchase all this as a kit.
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com)] On Behalf Of Greg Williams
Sent:
Monday, October 22, 2007 11:57 AM
To:
Subject:
Gear Legs
Hi folks,
I'm getting stuff ready to do my first annual condition inspection on my recently purchased, completed RV7. (I'm having a GREAT time flying!!) I want to change tires and was really nervous about the wing jack when I swapped tires 9 months ago. I was told to put a piece of pipe inside the landing gear strut before removing the nut and jack it up. Does anyone have their gear leg out in the open and could give me a measurement? Mine is all wrapped up in wheel pants and tough to get to right now. I think a 1" pipe is about right but need to know the inside diameter of the gear leg tube.
Thanks in advance.
Greg
?RV-List">http://www.matronics.com/Navigator?RV-List
u>http://forums.matronics.com
 Filesize:  105 Bytes
 Viewed:  2326 Time(s)
 Filesize:  73 Bytes
 Viewed:  2325 Time(s)
 Filesize:  73 Bytes
 Viewed:  2328 Time(s)
