Vanremog(at)aol.com Guest
Posted: Sat Feb 18, 2006 8:49 pm Post subject: P/N KM610-64 Camloc Flush Button Latch |
Quite some time back someone on the RV-List asked about these push button
latches. I recently did some research and realized that I had listed an
incorrect P/N in my reply and that error is forever ensconced in the archives. My
bad.
These latches are much nicer than the commonly available Hartwell latches
IMO, as they won't pop you on the thumb some cold morning when checking the oil.
For those of you looking to use this really cool latch, they are apparently
still available from a number of Cessna parts outlets and may be found on the
web by simply Googling P/N KM610-64.
GV (RV-6A N1GV O-360-A1A, C/S, Flying 774hrs, Silicon Valley, CA)
sportypilot(at)stx.rr.com Guest
Posted: Sat Feb 18, 2006 10:50 pm Post subject: P/N KM610-64 Camloc Flush Button Latch |
how many of these are needed for the oil door ?
Danny..
Posted: Sat Feb 18, 2006 11:16 pm Post subject: P/N KM610-64 Camloc Flush Button Latch |
In a message dated 2/18/2006 10:52:27 P.M. Pacific Standard Time,
sportypilot(at)stx.rr.com writes:
One would be sufficient, but in the spirit of redundancy, I have two of
these latches on the oil access door. I use only one latch on the gascolator
drain access door on the lower cowling.
Posted: Sun Feb 19, 2006 12:23 am Post subject: P/N KM610-64 Camloc Flush Button Latch |
I found them for 20.00 each is that about right ? , I was planning on adding
to the tube and have the gasolator drain stick out just a little without
a door for it.. whats others doing on that ?
Danny..
Rick Galati
Joined: 10 Jan 2006 Posts: 91 Location: Lake St. Louis MO.
Posted: Sun Feb 19, 2006 4:20 am Post subject: Re: P/N KM610-64 Camloc Flush Button Latch |
| sportypilot(at)stx.rr.com wrote: | | how many of these are needed for the oil door ?Danny..--- |
I never did much care for the rather dominant look produced by Hartwell latches contained within the small area of an oil door and I was not about to install those draggy kit supplied wingy things on it either! Looking for ideas over two seasons of AirVenture, I would cruise the RV line endlessly and never did see an RV with KM610-64's installed. It was only later when I spotted a student checking the oil on a rental C-172 that I finally had my inspiration. I'd like to think I was the first person to install these nifty latches on the RV oil door but apparently not. Oh well.
I installed these KM610-64's a few years back, ordered and purchased from my (then) FBO out of a C-172 parts catalog for a mind bending $30.00 each. A few weeks later, I came across the same new latchs from a vendor in the Flymart at Airventure for $7.50 each. I think it was B&B Aviation Parts. Anyway, when I loudly complained to my FBO about the ripoff, he cut the price in half...to $15 each. As the photo's illustrate, I installed two of the camlock latches on the oil door. More than one RV builder has reported the oil door bowing out in flight due to air pressure with only one latch (of any type) installed, so I bonded the cutout cowl waste material onto the back of the oil door to stiffen it considerably. In addition, since the grip reach on the latches is not all that much, I bonded aluminum strips under the upper cowl for the latches to achieve a firmer hold. They work great.
http://img79.imageshack.us/img79/2166/oildoor01403wn.jpg
http://img367.imageshack.us/img367/9172/oildoor04409tb.jpg
http://img367.imageshack.us/img367/6949/oildoor05400wd.jpg
Rick Galati RV-6A "Darla" 109 hours
rocketbob(at)gmail.com Guest
Posted: Sun Feb 19, 2006 4:45 am Post subject: P/N KM610-64 Camloc Flush Button Latch |
The only trouble with these latches is the contact area to the cowling is
very small and the latch will wear at the point of contact, so will the
aluminum piece they ride up against.. I've replaced these a couple of times
on our club C-172's, and have tig welded them back into shape also.
Bob Japundza
RV-6 flying, F1 under const.
adding
Danny..
lhelming(at)sigecom.net Guest
Does anyone have a picture of a KM610-64?
Indiana Larry, RV7 SunSeeker 80+ hours flying
"Please use the information and opinions I express with responsibility, and
at your own risk."
Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Sun Feb 19, 2006 2:23 pm Post subject: P/N KM610-64 Camloc Flush Button Latch |
In a message dated 02/19/2006 2:29:33 AM Central Standard Time,
No gascolator...
Mark - do not archive
_________________ From The PossumWorks... |
Mark Phillips in TN
Just to confuse the issue, you might want to examine this alternative:
http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=5077
Has worked well for 2 yrs/280 hrs, & entertains the hell out of folks at
fly-ins!
Posted: Sun Feb 19, 2006 8:10 pm Post subject: P/N KM610-64 Camloc Flush Button Latch |
I think having it stick out just a bit would make attaching the lower
cowling a hard thing to do. I suggest your drain tube be just short of
sticking out.
at your own risk."
Posted: Sun Feb 19, 2006 9:01 pm Post subject: P/N KM610-64 Camloc Flush Button Latch |
I have seen them on the glass planes , I don't want the firewall penatration
but I love the idea, plus I don't want to
install the cable pull inside.. ( man I should have listened and ran all the
wire prior to installing the forward top skin)
I am sick of running wire.. I ordered the 610-64's 20 each, oh well, anyway
I have a question, does the
dynon remote compass work ok in the wing tip? or is it best under the emp
fairing.. ?
Danny..
seiders(at)bellsouth.net Guest
Posted: Mon Feb 20, 2006 6:23 am Post subject: P/N KM610-64 Camloc Flush Button Latch |
Drilled a hole in cowl below gascolator large enough to insert drain fuel
testor. Works fine.
Dick
At 05:22 PM 2/19/2006, you wrote:
No gascolator...
jacklockamy(at)verizon.ne Guest
Posted: Mon Feb 20, 2006 7:37 am Post subject: P/N KM610-64 Camloc Flush Button Latch |
To solve the problem of 'wear' where the camlock contacts the fiberglass cowling, I installed a small strip of stainless steel (1" x 1/2" x .030) under the cowling lip and attached with a couple of flush rivets.
Jack Lockamy
Camarillo, CA
