IMPORTANT! CJ Weight and Balance calculator
dabear(at)damned.org
PostPosted: Sat Feb 18, 2006 2:56 pm    Post subject: IMPORTANT! CJ Weight and Balance calculator Reply with quote
If you downloaded and are using the earlier version of my W&B
calculator, please delete it. It has an incorrect weight calculation
for oil. Please use this one attached. Also, the offer to change the
sheet to support your datum/stations is still open.
DaBear
DaBear wrote:
Here is a version of what I use for W&B in the CJ. Note I use multiple
stations for the baggage compartment because I have an extended
compartment and control where the weight goes across those 3 stations.
If someone needs it modified for their stations, let me know.
DaBear
CJ_W&B_N6084F.xls
 Filename:  CJ_W&B_N6084F.xls
 Filesize:  23 KB
 Downloaded:  557 Time(s)
