taildragon(at)msn.com Guest
Posted: Wed Oct 10, 2007 8:52 am Post subject: Aircraft Designator Code |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]-->
Does anyone remember the RV-10 Aircraft Designator Code (for flight plan form)?
Tim Olson
Posted: Wed Oct 10, 2007 9:28 am Post subject: Aircraft Designator Code |
Yup..... RV10
In the olden days, like last year, we had to use HXB, which
is homebuilt experimental, with a B speed range. Now
we can use RV10.
Tim
Roger Standley wrote:
form)?
rnewman(at)lutron.com Guest
Posted: Wed Oct 10, 2007 9:46 am Post subject: Aircraft Designator Code |
I believe it will be either -hxa or -hxb where the a or b is the
catagory approach speed. I know my slow Glastar is -hxa
plan form)?
coop85(at)cableone.net Guest
Posted: Wed Oct 10, 2007 3:14 pm Post subject: Aircraft Designator Code |
Unless you are using DUATS. For some reason they still haven't incorporated
the RV10??? I use HXB and then put RV10 in the remarks.
Marcus
glastar(at)gmx.net Guest
Posted: Wed Oct 10, 2007 9:03 pm Post subject: Aircraft Designator Code |
Hello Bob,
according ICAO your Glastar should be GLST (at least that is what I'm
using since 4 years).
and yes RV10 is in the database, to check
<http://www.icao.int/anb/ais/8643/index.cfm>
br Werner
Bob Newman wrote:
>>> taildragon(at)msn.com 10/10/2007 12:48 PM >>>
plan form)?
Ray.R.Doerr(at)sprint.com Guest
Posted: Thu Oct 11, 2007 8:25 am Post subject: Aircraft Designator Code |
DUATS still does not accept RV10, I had to use HXB when filing via DUATS
on my way to 5T6 this past weekend.
Thank You
Ray Doerr
Tim Olson
Posted: Thu Oct 11, 2007 2:57 pm Post subject: Aircraft Designator Code |
Weird that DUATS doesn't and DUAT does. I didn't have good luck
filing a couple times with Golden Eagle (DUATS), but today I filed
with Voyager (DUAT) and it took it right away and within an hour
I was in air picking up a clearance to Atlanta. I filed as RV10/G.
Pretty nice day. I flew LOP for a while at 9K, and then took a
brief stint at ROP. I gained an easy 10kts over my LOP flight
phase, but it sure changes the range....so a couple minutes I was
kicked back again in the low 160's with flows around 10gph.
Tim
<Ray.R.Doerr(at)sprint.com>
Thank You
Ray Doerr
jfrjr(at)adelphia.net Guest
Posted: Thu Oct 11, 2007 4:14 pm Post subject: Aircraft Designator Code |
Tim: Rumor has it that you will be in Maine this coming weekend. If that
is true we would love to take you and yours for a lobstah' dinnah'. We are
free all weekend. Could fly into either AUG or WVL. Home phone is 207 395
2842 and cell is 207 322 6167. Jay Rowe #40301 (working on the cowling).
49 Bytes |
6731 Time(s) |
Tim Olson
Posted: Fri Oct 12, 2007 4:45 am Post subject: Aircraft Designator Code |
Well, that was the plan originally but it looks like the weather
up there will be cold, windy, and rainy...the same junk we
just lived through in WI a couple days ago. So we started
out with heading to GA and were then deciding between coming
up the coast and seeing NC/SC/W.VA, and then home, or going down
into FL. The kids I think won out so we're now on the run to sqeeze
in a day of Mickey Mouse and in-laws before we zip back home.
The RV-ten sorry, my keyboard is losing it's number keys... is
a great x/c machine that can get you a long way in a days flight,
but the problem is, if you leave home without a firm plan on where
to go, you can really get stuck in the "mulling it over" phase.
Sometimes it's tough to have choices. ;
I appreciate all the invites we get, and we'll probably take some
of them up sometime, but traveling with the kids usually means
their votes count more than my vote, so more often than not I'm
trying to zip on to the destination.
I think we'll have to give Maine another shot in the spring or fall.
If anyone has great suggestions for sights to see in any far eastern
states .... ones that kids would like, send them to me offline as
I really need to come up with some eastern vacation plans that aren't
just visiting beaches, or mom-n-pop museums. I need things that
kids really would find fun. we're going to spend some time trying to
hit all forty nine mainland states over the next few years, before they
get out of H.S.
Thanks for the invite!
Tim
[quote] Tim: Rumor has it that you will be in Maine this coming weekend. If
that
are
395
LloydDR(at)wernerco.com Guest
Posted: Fri Oct 12, 2007 5:12 am Post subject: Aircraft Designator Code |
Speaking of all 49 Mainland states, the SOCAL guys and gals are planning
a trip for Alaska in early July next year. With that much lead time a
bunch of us 10 drivers should join in and go north together for a great
family trip. I talked with Trish and the kids and they are definitely up
for Alaska during the summer, what does everyone think? It is always
better/ more fun to fly in a gaggle and we have been checking out a
bunch of different sites on flying Alaska and there is some incredible
day trips to be had once you get there.
Thoughts? We could even start an annual RV10 builder/family fun trip?
Dan
N289DT RV10E
Jack.Phillips(at)cardinal Guest
Posted: Fri Oct 12, 2007 5:17 am Post subject: Aircraft Designator Code |
Tim, if your travel plans do end up including North Carolina, plan to
stop at FFA, First Flight Airport at Kill Devil Hills on the Outer
Banks. Land where the Wright Brothers first flew. You can walk from
the airport to the Wright Bros Memorial and the Museum there at the
National Park. Landing there should be on the "To Do" list of every
history-minded pilot.
If for any reason you are in the Raleigh area, let me know and I'll take
you to dinner and pick your brain for avionics ideas for my -10. Might
be able to get you up in my Pietenpol for a totally different kind of
flying (low and slow, open cockpit)
Jack Phillips
Raleigh, NC
#40610
Deems Davis
Posted: Fri Oct 12, 2007 7:43 am Post subject: Aircraft Designator Code |
Alaska! That's always been on my 'places to fly' list (August is
usually the better weather month) count me in, assuming I actually
complete this thing before then !! :-\
Deems Davis # 406
'Its all done....Its just not put together'
http://deemsrv10.com/
Lloyd, Daniel R. wrote:
Posted: Fri Oct 12, 2007 9:17 am Post subject: Aircraft Designator Code |
I sent Duats an Email and they said they have now added the
RV10.
Thank You
Ray Doerr
Mr.Doerr,
Your request to add aircraft type RV10 (Van's) is now available.
Thank you
Robert O. Street
CSC Duats
Asst Database Manager
Chantilly, Va 20151
Tim Olson
Posted: Fri Oct 12, 2007 10:44 am Post subject: Aircraft Designator Code |
Way to take the bull by the horns Ray! Thanks!
Tim
RV10.
Thank You
Ray Doerr
Mr.Doerr,
Thank you
Robert O. Street
CSC Duats
Chantilly, Va 20151
ddddsp1(at)juno.com Guest
Posted: Fri Oct 12, 2007 12:22 pm Post subject: Aircraft Designator Code |
Deems,
How is this for a plan.................Fly to Osh 08.........then to Alaska............return to Portland in time for Van's Homecoming...........then a short flight HOME. Bet we could get a few to bite on that journey!
Dean 805HL
110.4 hours
_____________________________________________________________
Senior Dating Online. Click Now!
Posted: Fri Oct 12, 2007 4:05 pm Post subject: Aircraft Designator Code |
Great work Ray. I was taking the route through Vans for some reason
thinking it was a FAA thing and got nowhere. Thanks for your effort.
Marcus
Posted: Fri Oct 12, 2007 4:36 pm Post subject: Aircraft Designator Code |
OK, you’re killing me now. I have to talk my dad into going, and 3 other planes to fit my wife and kids too.
Jesse Saint
Saint Aviation, Inc.
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
From: ddddsp1(at)juno.com [mailto:ddddsp1(at)juno.com]
Sent: Friday, October 12, 2007 3:21 PM
Subject: Re: Aircraft Designator Code
Deems,
How is this for a plan.................Fly to Osh 08.........then to Alaska............return to Portland in time for Van's Homecoming............then a short flight HOME. Bet we could get a few to bite on that journey!
Dean 805HL
110.4 hours
Senior Dating Online. Click Now! [quote] [b]
apilot2(at)gmail.com Guest
Posted: Fri Oct 12, 2007 7:19 pm Post subject: Aircraft Designator Code |
IMHO, having learned to fly in Fairbanks, and spending 22 years there accumulating ~800 flying hours, August is not the best month to go. Usually rainier than average. August is duck hunting season, with low fog in river areas common. June and Sept are the drier months, Sept. has much less mosquitos competing for the airspace. July and Aug are peak tourist months, highest prices and competition for motel rooms. Keep an eye on forest fire predictions as well, as that can cause IFR conditions as much as clouds. However, whenever you go, keep in mind that typical visibility under whatever ceiling exists will be 40-80 miles, except under fire smoke conditions. So low level flying following roads or rivers is safer than elsewhere, as long as power lines and the rare radio towers are avoided.
Figure last frost around Memorial Day...snow drifts in mountainous areas well into June. 1st frost and or snow can arrive mid-Sept. Weather along the Alaska Highway definitely turns nasty by early-mid Oct.
On 10/12/07, Deems Davis <deemsdavis(at)cox.net (deemsdavis(at)cox.net)> wrote:[quote] --> RV10-List message posted by: Deems Davis <deemsdavis(at)cox.net (deemsdavis(at)cox.net)>
Deems Davis # 406
Posted: Sat Oct 13, 2007 6:52 am Post subject: Aircraft Designator Code |
Cold, windy and rainy...Tim, I thought that was the type of weather that
made you WANT to go flying. I do understand the Disney and In-laws thing,
of course. I would offer to take you out to dinner myself, but I don't
think you are coming quite this far south. Normally it's X35, but right now
it's SESM (any takers out there?).
Jesse Saint
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
Tim Olson
Posted: Sat Oct 13, 2007 7:42 pm Post subject: Aircraft Designator Code |
No no no....not all 3. I just like the cloudy and rainy stuff, but
not when it's cold or windy. I'm not a fan of ice, or turbulence
you can't climb away from.
Well, we had our day at 3 of the parks today, so tomorrow if we
can avoid that glob over iowa we should be home again.
Tim
now
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
