zodiacjeff(at)msn.com Guest
Posted: Sun Oct 07, 2007 8:26 am Post subject: Jabiru engine coughing |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> What do the Jabiru engine experts suggest?
Lynn
Hi Lynn,
I won't claim any expertise with the 3300 but I really enjoy mine.
Why not contact Andy Silvester, your local distributor in FL, to ask him. Andy is always tactful and thorough in his answers and usually prompt. He will be the person you'll need for replacement parts and advice through your Jab flying days.
http://www.suncoastjabiru.com/ A phone call Monday would be ideal.
My suggestion would be you check all fuel strainers (if any) and especially the gascolator screen for foreign matter. Check the coil to magnets gap on both coils - should be .010. Go to Pete's valuable info site http://www.usjabiru.com/technical-tips.html and see if the "idle adjustment" settings are correct. Is this a "newer" engine with hydraulic lifters? If solid lifters, when did previous owner do last adjustment? How many hours on engine?
Any possibility of water in gas since you're now in FL?
best of luck jeff HDS/3300 305 hours
IFLYSMODEL(at)aol.com Guest
Posted: Sun Oct 07, 2007 3:42 pm Post subject: Jabiru engine coughing |
Hey Jeff: I forgot to include in my first message that I had checked the magnetos (New coils, rotors and caps less than 50 hours ago) and they showed about 15 RPM drop per side, but the engine did the same thing on left, right or both mags. The engine is the older, solid lifter variety and the previous owner states, as well as his log book entries, that the lifter clearances have been checked. I did not find any water in the fuel. The engine has less than 150 hours since new.
Lynn
See what's [quote][b]
tonyplane(at)bellsouth.ne Guest
Posted: Sun Oct 07, 2007 8:53 pm Post subject: Jabiru engine coughing |
Lynn,
Don't know if it will help, but I once had the terminal end of one of my spark plugs (the little screw on tip) come completely loose.
I noticed it when I removed the plug wire and saw the threaded end where the tip screws on. The tip was still in the plug wire boot end. I had had a "more than normal" rpm drop on a mag check (usually it is not really noticeable) and was going to check my plugs to see if one was fouling.
I have found some of the terminal tip ends loose during my preventative maintenance checks and now always make sure they are all tightened.
Could you better describe the conditions under which the cough occurs? Could you also better define the "cough"? And of course, if you do find the problem. please let us all know the corrective action.
Based on my experience, I believe you are really going to like flying behind the Jab.
Tony Graziano
Zodiac 601XL; JAB 3300A; N493TG; 304 hours
Subject: RE: Jabiru engine coughing From: IFLYSMODEL(at)aol.com ([email]IFLYSMODEL(at)aol.com?subject=RE:%20Jabiru%20engine%20coughing&replyto=cb1.1dbcbcf9.343a7eea(at)aol.com[/email]) Date: [b]Sun Oct 07 - 4:42 PM[/b] | Quote: | | Quote: | Hey Jeff: I forgot to include in my first message that I had checked the
Lynn
