a.s.elliott(at)cox.net Guest
Posted: Mon Oct 08, 2007 8:48 am Post subject: Aileron trim wiring? |
Gang:
To make wing closing and final assembly easier, and perhaps necessary future maintenance, I am planning put a Molex connector in the aileron trim cable. My idea would be to leave enough attached to the aileron to come into the wing and make a small maintenance loop, then the connector. Connector will be accessed through the same panel as the bellcrank.
Anyone see any problem with this approach?
Andy Elliott, Mesa, AZ
N601GE (reserved)
601XL/TD/QB, Corvair, building...
Posted: Mon Oct 08, 2007 9:35 am Post subject: Aileron trim wiring? |
Another approach is to not run the wire inside the wing. I have seen it run up under the top skin along the rear spar between the spar and the aileron/flaps. I think this was on Dragonfly Aviation's 601XL. They may have done this if the trim was a retrofit and the couldn't/wouldn't open the wing..
-- Craig
dredmoody(at)cox.net Guest
Posted: Mon Oct 08, 2007 9:42 am Post subject: Aileron trim wiring? |
None at all Andy. It will give you peace of mind vis a vis repair / replacement a any future point of need.The electrical amp hours are so minimal for a tim servo that an aditionla connector is not likely to have a down side except to lock the halves together before buttoning up that area.
Dred
Posted: Mon Oct 08, 2007 9:47 am Post subject: Aileron trim wiring? |
Dred
DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Mon Oct 08, 2007 9:59 am Post subject: Re: Aileron trim wiring? |
It should work OK, at least I hope so, because I am doing basically the same thing. I am using a 9-pin d-sub connector as suggested by Bob Nuckhols.
Good luck,
_________________ David Gallagher
Cincinnati, OH area |
